Poslednji Windows mobile sam koristio pre ~8 godina na HP Jornadi (sa 56k modemom :d), pa sam "malo" zarđao, a prijatelj ima problem.
Našao sam uputstvo na: http://www.htc.com/au/faqs.aspx?p_id=297&cat=264&id=118112
Ali koliko vidim, ovde je smor da se ponovo povežeš. Da li ima neki shortcut da se uključi ova konekcija, odnosno da se vrati funkcionalna konekcija?
Na Androidu imam widget koji to radi. Jedan klik.
Q. How do I disable my 3G/GPRS Data Connection?
Follow the steps below to ensure that your phone will never connect to a GPRS/3G Data Connection.
1. Go to Start > Settings > Menu > All Settings > Connections > Connections
2. Tap Add a new modem connection > then under Select a modem, select Celluar Line (GPRS) > Name the Connection "Offline" >Tap Next.
3. In the Access point name text box input "Offline" and tap Next.
4. On the next page tap Finish.
5. On the second Connections Menu, tap Manage existing connections and select "Offline" then click OK.
