blackbear
- Significant API improvements are available for JS-ctypes, a foreign function interface for extensions.
- Crash protection for Windows, Linux, and Mac when there is a crash in the Adobe Flash, Apple Quicktime or Microsoft Silverlight plugins.
- CSS Transitions are partially supported.
- Full WebGL support is included but disabled by default at this time.
- An experimental Direct2D rendering backend is available on Windows, turned off by default.
- Web developers can use Websockets for a low complexity, low latency, bidirectional communications API.
- Web developers can update the URL field without reloading the page using HTML History APIs.
- More responsive page rendering using lazy frame construction.
- Link history lookup is done asynchronously to provide better responsiveness during pageload.
- CSS :visited selectors have been changed to block websites from being able to check a user's browsing history.
- New HTML5 parser.
- Support for more HTML5 form controls.
..i ja bi dodao brzina, 4.0 beta1 definitivno brza od 3.6.
link..
