MACCHANGER za Windows7
Probah par programa ali ne jedan mi ne radi na Windows7? Jel ima neki koji provereno radi na windows7-ci?
Mislio je na mac adresu ne na ip adresu
Na XP-u sam koristio SMAC 2.7 ali u Windows 7-ci on nece da radi.
Što se mlatite sa tim programima kad imate u drajveru od mrežne karte?
Alo, to ne radi, probao!
Izgleda da na nekim adapterima (izgleda samo realtek) pod x64 OS-om poput viste i sedmice nije moguće menjati mac adrese, verovatno zbog drajvera. Čim nemože da se menja u preko podešavanja u device-manageru (podešavanjima mrežne karte), verovatno ni programi neće moći da promene adresu.
Ono sto sam do sada nasao, nista nije bas tako prakticno...:
It's full working in my Windows 7 Professional: ( MAC ADDRESS CHANGE )
Tested if USB chipset Realtek 8187L .
1- Download and install Windows XP mode ( http://www.microsoft.com/windows/virtual-pc/download.aspx )
1.1 -open XP mode Click on window of Virtual Machine ( USB ) and click in your wireless hardware for ADD.
1.2 - Processor and mainboard needed virtualization technology SUPPORTED.
2- Install DRIVER to your wireless driver and test if full work.
3-IN {WINDOWS XP MODE } Download and install ( SMAC 2.7 = Spoofer MAC ADDRESS ) ( http://www.klcconsulting.net/smac/default.htm#smac27 )
Obs.: Serial Number is needed for full change MAC ADDRESS.
4 - in XP MODE changer your mac address using the software.
5 - On window of Virtual Machine Click in USB and disconect your hardware wireless of virtual machine.
On windows 7, your mac address is same of in WINDOWS XP MODE.
Use IPCONFIG /ALL or your wireless software to check MAC ADDRESS.
How To Change MAC Address In Windows 7
http://www.techskipper.com/computer-hacks/general-os-tips/how-to-change-mac-address-in-windows-7/
http://www.youtube.com/watch?v=3_7y9_FMWmQ&feature=related
Neke kartice cak i nemaju tu opciju, kao sto je npr. realtek. Jednostavno ne postoji "Network address" opcija.
JEDNO PITANJE? DALI JE MOGUCE PROMENITI NA MREZNIM ILI WIRELESS KARTICAMA MAC ADRESU U SVE NULE
Nije, i sta bi time dobio ?
Pisi malim slovima.
Fizicka adresa se ne menja vec se u registry bazi ubaci izmenjena MAC adresa. Veoma lako je otkriti izmenjenu MAC adresu i pored toga dobiti pravu fizicku.
sj..0 sam ruther nemogu ni kablom ni antenom da se nakacim, ustvari prvo nisam mogao kablom pa neko vreme sam se kacio antenom a sad sam ga za...o do kraja kliknuo sam na enable gde je mack filtering misleci da cu da osposobim da mi radi preko kabla, *** kad se nerazumem. sad kako su mi drugari rekli da sam ukljucio da mi ruter prepoznaje kartice koje imaju mac adresu sa svim nulama.na koji nacin da promenim u sve nule ili mi ostaje da pazarim nov ruter..
Pa resetuj router. Pogledaj sa svih strana.. mora da ima negde neka rupica ili neko dugmence za reset.
Reci nam tacno koji je model routera pa ti neko moze reci sta da radis.
eee hvalaaaa nasao sam rupicu gurno sam tanku zicu i iskljucio sam iz struje saceko sam par minuta i to je to resio si mi problem yooyo hvala ti puno cheers Dzaba bile te nule izmisljene na routeru kad nema kartice koja moze da radi sa nulama.
Interesu je me dali bi mogao sa dve wireless kartice da umrezim dva racunara ono kao sa mreznim karticama ,hvala jos jednom
