Blogspot i lični domen?
qwertybre
Banned
Banovan
Zna li neko ovo: imam registrovan .com domen (i hosting) i blog na blogspot.com
Mogu li nekako da namestim da se blog otvara preko postojeće COM adrese? Da li mi tada treba hosting? Znači, ne želim preusmeravanje...
Hvala, znam za to, ali mi nije jasno kako se radi sve ono što se traži sa DNSom:
Update the DNS Settings
DNS stands for Domain Name System, and a DNS server determines what site a given address takes you to. So far, you have a domain name but none of the servers on the internet know what to do with it yet. To take care of this, you need to do two things:
* Create a CNAME record for your blog's address, which should be a subdomain of the form www.example.com.
To create a CNAME record for your domain with the DNS, associating your domain with:
ghs.google.com.
The exact procedure for doing this varies depending on your domain registrar, but you can find instructions for many common registrars here. If yours isn't listed, or if you run into other difficulties, you can contact your registrar directly and they'll be able to help you out.
* Create 'A' NAME records for your naked domain (blog.com)
Note: The following information applies to naked domains only!! If you're setting up a subdomain then this does NOT apply to you! :)
Creating A records for your naked domain is important as it allows Google to redirect people who use in your naked domain name (blog.com) to your blog page (www.example.com). If you do not do this, visitors who leave off the www will see an error page.
There are four separate A records you will create, and can be done from the same control panel you accessed your CNAME records. Simply point your naked domain (example.com, without the 'www') to each of the following IP addresses:
216.239.32.21
216.239.34.21
216.239.36.21
216.239.38.21
Your DNS setup is now complete!
CNAME ne mozes podesavati za naked domain (npr. example.com) nego moras www.example.com ili npr. blog.example.com. Ne znam kako da ti pomognemo osim da nam das screenshot control panela gde imas DNS podesavanja.
Ako vec imas hosting onda mozda bolje staviti WordPress, kod bloggera uvek stoji onaj njihov toolbar na vrhu stranice.
