Nije stvar u tome, SKIDROW je u .nfo-u ponižavao emulator i ljude koji su dopunjavali values.db sa tog foruma a on je u stvari krao(krali pošto je to grupa) values.db od tih istih ljudi i još je uzeo stariji .db
While we worked on this release, we noticed that several news
webpages, forums, blogs etc. posted information, including a
screenshot of a Ubisoft server attack message, which showed
our group name.
First of all, that picture is a fake, nor would any member of
Skid Row cause such riot, as we ‘re only here to compete with
our game release competitors, nothing else.
Neither do we encourage anyone to take such actions, no matter
how much we agree, that DRM ‘s like this one, are only hurting
those that do want to buy the game or have bought it.
Another point is those news medias, we mentioned before, post
anything these days, no matter if it ‘s a joke or not. Beware
what you ‘re posting, just because you want to prank someone.
This release is an accomplishment of weeks of investigating,
experimenting, testing and lots of hard work.
We know that there is a server emulator out in the open, which
makes the game playable, but when you look at our
content, you will know that it can ‘t be compared to that.
Koliko ja vidim nisu nista lose rekli ni o kome specijalno a svako svog konja logicno hvali. 😛
Pa dobro... bar ne moram više da ubijam web server da bih igrao 😛
As there are many questions regarding the Skidrow crack lets make some things clear:
It's nothing else then the server emulator - only a different approach. The drm is NOT cracked (otherwise the ACII gamefile would be patched). What skidrow did is the following:
Most communication needed for ACII is handled via ubiorbitapi_r2.dll. When you start the game the UbisoftGameLauncher pops up, loads this dll, calls some functions from the dll to get server addresses, checks for updates, does a SSL-Handshake, checks your Ubisoft-Account and CD-Key -> if valid launches the game via LoadProcess. ACII also uses the ubiorbitapi_r2.dll and establishes the same connection to retrieve the needed Values.
What skidrow did:
they replaced the ubiorbitapi_r2.dll with their own version and hardcoded values. So no "external" emulator is needed as the functions inside of the dll are used to emulate the server responses. Imagine it like this:
-UGL loads the DLL and calls the function "mg:😱rbitdll::OrbitSession::ClaimCdKey" -> then the dll would connect to ubis servers to retrive information if you have a legit CD-Key and return "true" or "false" (to make it simple)
Skidrow simply replaced the "mg:😱rbitdll::OrbitSession::ClaimCdKey" with their own one that always returns true without connection to the servers.
I wouldn't even be surprised if they used the values that were collected here. Why else would they protect the dll? They simply were not interested in "pulling the pants down" as it is pretty obvious how they did it. There's no magic, no cracked DRM, simply a different kind of server emulator running in "memory" and hidden inside of this little dll.
Evo sad i pravo objašnjenje o navodnom "cracku":
Koriste ga, zna se. U pitanju je 1908 values koji ima jedan FAKE PAIR. I Ide istim redoslijedom kao i taj values samo što počinje sa SKIDROW. Znači identičan onim ruskim vluesom.
i Sa SKIDROW-om i sa Emulatorom. Čak neki i pričaju da ne mogu se neke opcije u grafičkom meniju snimiti sa SKIDROW-im lijekom i da na pojedinim sajtovima SKDIRO dobija da je NUKED(to jeste da ne valja )
Znaci sve sve,ali onaj post credits deo sa Dezmondom...Zavrsio igru krenuli credits,ja otisao do druge sobe i samo cujem odjednom nesto se desava,neka sirena,kad dodjem u sobu imam sta i da vidim 🙂 Lepo su se setili kako da pokusaju da nas nateraju da gledamo credits 🙂
Igra dobila jako cudan kraj,neocekivan totalno,zbunjujuc,bar meni...Narocito zbog onog dijaloga koji imaju Dezmond i ovi ostali iz Ordera kada beze iz onog sklonista..Sve u svemu,vise od ocekivanog.Cekamo 3. deo.
Pricao sam telefonom onda, o cemu se radi o kako kazes dijalogu kad beze iz sklonista?
Btw, presao sam celu naravno, otkljucao Altairov armor, kupio Altairov mac, otkrio sve viewpointse, i sad cu da pokusam da sakupim svo blago. 🙂
Kad si poslednji put video trojanca ili spyware u kreku koji je zvanično scensko izdanje? Dakle ne ono što si skinuo sa sajtova koje hostuju kurta i murta nego ono što izađe na nfohumpu?Ovo mi je bilo bitno, ja sam uvek za eksterne aplikacije koje simuliraju orginalni sistem igre... posto krekovi su mi sumnjivi (sta znas kakav trojan, spyware ti uvale tamo). A fala bogu ova solucija ne zauzima resurse racunara kao ludo.
:dAjd da stavim u spojler,mozda neko nije presao igru jos uvek😉
Odprilike je fora da na neki nacin templari nisu glavna pretnja,kako to kaze Stillmanka.Na to Dezmond valjda zbunjeno pita da li je u pitanju Sunce,na sta ona kaze da je bilo nekih nagovestaja da Zemljino magnetsko polje slabi i da to moze dovesti do toga da planeta postane jako nestabilna.Sve u svemu i njihov zakljucak je da su nahebali u svakom slucaju 😀 Bas me je zbunilo ovo jer Minerva kaze Dezmondu da se to vec desavalo i kako sada oni "Bogovi" misle da je doslo vreme za drugu rundu svega toga.A valjda je isto spominjala i neku veliku vatru na zemlji koja je ubila covecanstvo koje su oni kasnije ponovo stvorili uz pomoc njihove tehnologije..Valjda sam dobro popamtio i pokopcao..
Na kraju ce ispasti da su Assassini GreenPeace borci :d
Nukers Information:
We noticed our release was nuked a few places for using stolen
public available values.vb codes.
Let's point out that, even if our dll has the very same
values, then anyone can get these values and the values are
still required to emulate the ubiorbit api calls. The data
values are transfered via IPC, as we didn't use any kind of
server emulation at all and therefore can't be compared to
the public server emulator out there.
It's sad that there are people out there, who only focus on
make you look bad, when you actually have accomplished
something of a larger scale.
If the scene is based on finding holes in everything, then you
can start nuking Command and Conquer 4 Tiberian Twilight for
using exact same method as the public server emulation
release, SecuROM cracks with emulated vm calls, Steam function
emulation and RELOADED's new Solidshield method.
We didn't mention RELOADED, to make them look bad, but to give
people insight in, that alternative routes needs to be found
to get around the protections these days.
Things are not getting easier these days, as publishers like
EA and Ubisoft, have already begun to release games which
require you to be online when you play.
You can bet more will jump on that gameplay only online wagon.
Firms like Capcom, Square Enix Eidos, THQ, SEGA and Activision
has already shown interest in doing so.
Maybe the same people who bitch that we used the values.vb
codes from the public server release, should at least prove
their accusations. Keep in mind, the values are required for
the game to function properly and the values are always the
same, because they never change.
What reason will you use, when we pre the next Ubisoft game?
