Stone Giant DX11 Benchmark
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700XT
Storage
1 TB SSDa + 3TB HDDa
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
Novi mucitelj DX11 grafickih karti. :)
Instalaciju tešku oko 395MB možete preuzeti klikom na ovaj link. :)
BitSquid and Fatshark are excited to announce that the Stone Giant demo, using the upcoming DirectX11 game engine BitSquid Tech, is available for immediate public download.
Key features of the BitSquid Tech (PC version) include:
• Highly parallel, data oriented design
• Support for all new DX11 GPUs, including the NVIDIA GeForce GTX 400 Series and AMD Radeon 5000 series
• Compute Shader 5 based depth of field effects
• Dynamic level of detail through displacement map tessellation
• Stereoscopic 3D support for NVIDIA 3dVision
“With advanced tessellation scenes, and high levels of geometry, Stone Giant will allow consumers to test the DX11-credentials of their new graphics cards”, said Tobias Persson, Founder and Senior Graphics Architect at BitSquid. “We believe that the great image fidelity seen in Stone Giant, made possible by the advanced features of DirectX 11, is something that we will come to expect in future games.”
“At Fatshark, we have been creating the art content seen in Stone Giant”, said Martin Wahlund, CEO of Fatshark. “It has been amazing to work with a bleeding edge engine, without the usual geometric limitations seen in current games”.
Sad sam malo gledao, zanimljiv demo, ima i neki benchamrk, ustvari ne izbacuje rezultat ali na enter on napravi jedan prolaz i moze da se meri frapsom. eni je na tesselation high u 1080p ovaj rezultat:
Frames, Time (ms), Min, Max, Avg
3064, 83616, 19, 54, 36.644
Evo malo poredjenje teselacija High i bez teselacije:
off:
high:
Jos nesto, tesselation off:
Tesselation medium:
Tesselation High:
Kod mene je onaj prolaz kada se pritisne enter u 1920x1080 tesselation high avg = 32 fps
kod mene isto 32 fps, minimum 17, max 47, ali klokovan 5850 900/1250
a na 1000/1250 je 34, cpu fenom 2 X2 550 na defoltu
Meni su karte na 860/1240.... Bez overkloka verovatno bi bilo par FPS manje....
Sve na def. ~34 fps
34 a na def sve?
I5 @4GHz, 5850 default 30fps
I5 @4GHz, 5850 920/1250 38fps
BTW nema potrebe da se pali fraps ili nesto slicno, na F4 se pali Performance Statistics gde se vidi fps, belezi awg i svaki prolaz zasebno ;)
x2 550@ x4 3.7ghz, 5850 900/1250...34fps
x2 550@ x4 3.7ghz, 5850 1000/1250...36fps
Ja kad upalim statistics izbaci mi preko 100FPS avg. :D A trebalo bi 36 kao sto realno pokazuje fraps, tako da ima potrebe, jer brljavi test....
Meni radi savrseno. Probao sam cak i uporedo, isto pokazuju. Ne znam sto tebi brljavi
Zato shto ima crossfire?!
E daaaaa, to sam prevideo. Bilo bi lepo da to neko jos potvrdi.
@Zerbah Ti si test provrteo na 470-ki? Jel to na I7 i na kojim clockovima?
Pitam jer sam primetio da Borab ima isti cpu kao ti pa cisto da napravimo poredjenje izmedju 470 i 5850.
A cudno mi je i to da i7 def daje veci pfs nego i5 na 4GHz.
Karte na 910/1240:
3144, 82440, 20, 56, 38.137
Da, kod mene je i7 860 @2.83 (tj. default) i GTX470 takodje @default.
jel "smem" ja da poteram bez teselacije? da ne bude da vam kvarim temu :D
Sto da ne..... Meni je oko 60FPS avg. bez teselacije....
Frames Time (ms) Min Max Avg
5307 85172 45 93 62.309
meni smrzava mashina na pola uchitavanja kad poteram 5850 CF. ima li neko ideju shta bi moglo biti?
Damn... kako bi te sada istrollovao ali necju :d . Skini DX 11 / XNA
[email protected]
4GB hyperx 1066
Gtx260OC
2010-04-24 23:07:54 - stone_giant
Frames: 5066 - Time: 91435ms - Avg: 55.405 - Min: 42 - Max: 86
Edit: Ugasio Vsync
2010-04-24 23:12:25 - stone_giant
Frames: 6772 - Time: 91751ms - Avg: 73.808 - Min: 51 - Max: 106
And now ladies and gentlemen... Ponekad je dobro imati CRT kantu chisto radi ovakvih rezolucija :D
    368 KB · Pregleda: 122
Bnch_Press je napisao(la):
[email protected]
4GB hyperx 1066
Gtx260OC
Edit: Ugasio Vsync
Mogao si napisati rezoluciju makar pa da ljudi mogu da se porede
pa standard valjda... 1600x1200 vidish da imam kantasti crt
damn... nigde ne pishe rez.... sry...
Prva dva su u gore pomenutoj rezoluciji a potonji je u sajber 2048x1536. Ochigledno je da ovde fiziks ima veliki uticaj jer je nemogucje da sa trenutnom konfom imam vishe fps-a od burazera (Midgard) mada mu nije bilo svejedno :D
Evo i u ovom 16x10 rezhimu 1920x1080
2010-04-25 02:22:21 - stone_giant
Frames: 4561 - Time: 86957ms - Avg: 52.451 - Min: 38 - Max: 79
Ne bi trebalo da je do CF, jer ja pokrecem bez problema, jedino meni nece fullscreen, pa idem ALT+enter i tek onda radi CF, inace kad niej fullscreen onda radi kao jedna karta a ne CF....
@ Midgard i Bnch_Press:
Kako vi to merite ? Prodje vam po 5000 frejmova sa frapsom ? Vi onda ne merite prolaz nego samo upalite fraps onako....
Prvo enter da krene prolaz pa odmah F11 da vam radi benchmark i prekinete na kraju prolaza.
34 a na def sve?
Da grafika na def.
Cpu na def. ( Auto klok, turbo on).
Zasto bi ga drzao na besnom oc-u kada nema nista od igara...
