CineBENCH 11.5
TheBear
http://downloads.guru3d.com/CineBENCH-11.5-download-2475.html
CINEBENCH is a real-world cross platform test suite that evaluates your computer's performance capabilities. CINEBENCH is based on MAXON's award-winning animation software CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such as Spider-Man, Star Wars, The Chronicles of Narnia and many more.he test procedure consists of two main components - the graphics card performance test and the CPU performance test.
Main Processor Performance (CPU)
The test scenario uses all of your system's processing power to render a photorealistic 3D scene (from the viral "No Keyframes" animation by AixSponza). This scene makes use of various different algorithms to stress all available processor cores.
In fact, CINEBENCH can measure systems with up to 64 processor threads. The test scene contains approximately 2,000 objects containing more than 300,000 total polygons and uses sharp and blurred reflections, area lights and shadows, procedural shaders, antialiasing, and much more. The result is given in points (pts). The higher the number, the faster your processor.
Graphics Card Performance (OpenGL)
This procedure uses a complex 3D scene depicting a car chase which measures the performance of your graphics card in OpenGL mode. The performance depends on various factors, such as the GPU processor on your hardware, but also on the drivers used. The graphics card has to display a huge amount of geometry (nearly 1 million polygons) and textures, as well as a variety of effects, such as environments, bump maps, transparency, lighting and more to evaluate the performance across different disciplines and give a good average overview of the capabilities of your graphics hardware. The result given is measured in frames per second (fps). The higher the number, the faster your graphics card.
Moj skor:
Evo i mog skora.
    54 KB · Pregleda: 97
Evo i mojih rezultata:
i7-920 @2.66GHz GTX260 @576/1000
Opengl 35.24 fps
Ref. Match 99.5%
CPU 4.71 pts
CPU (Single Core) 0.96 pts
MP Ratio 4.89x
i7-920 @4GHz GTX260 @675/1100
Opengl 51.80 fps
Ref. Match 99.5%
CPU 7.04 pts
CPU (Single Core) 1.45 pts
MP Ratio 4.86x
    88.5 KB · Pregleda: 65
Ne znam, neki bag kod mene verovatno.... Ne znam ni ja kako, ali to mi pise i u System Properties...
