nemoj ti, zajedno sa tim iz kurira da dobijes jedan samar od Mrkonjica xD
Offtopic: Sto se Kurira tice, zapaliti redakciju sto pre i uhapsiti urednika i ostale zaposlene, toliku kolicinu bljuvotine nikad nisam nigde video, samo pogledajte naslove u tim novinama i sve ce vam biti jasno.
Izvinjavam se moderatorima.
Eno i Blic kaze da je PS3 razbijen :d
Kako da igram igrice i da spamujem po benchu iz tvorza? 🙁 Hvala ti.. :d
Geohot PS3 exploit FIX and tutorial by xorloser
As I’m sure everybody heard, the memory access exploit for the PS3 hypervisor was released recently by geohotz. I was finally able to replicate his hack so I thought I’d take the time to help out others who may also have trouble due to being linux n00bs like me 🙂 If I were to post everything at once it would be too much work and I’d never get around to it, so I’ll post bits at a time to ensure I actually do post it heh. Today’s post will talk about the software side of the exploit.
Please note that the geohotz exploit software was hardcoded for the v2.42 firmware, I have made a small fix that attempts to dynamically support all firmware versions. I have only tested and used it on v3.15 however.
Geohot: PS3 100% Hacked, no need for rootkey and more
Today I verified my theories about running the isolated SPUs as crypto engines. I believe that defeats the last technical argument against the PS3 being hacked.
In OtherOS, all 7 SPUs are idle. You can command an SPU(which I’ll leave as an exercise to the reader) to load metldr, from that load the loader of your choice, and from that decrypt what you choose, everything from pkgs to selfs. Including those from future versions.
The PPU is higher on the control chain then the SPUs. Even if checks were to be added to, for example, verify the hypervisor before decrypting the kernel, with clever memory mappings you can hide your modified hypervisor.
Ah, but you still didn’t get the Cell root key. And I/we never will. But it doesn’t matter. For example, we don’t have either the iPhone or PSP “root key”. But I don’t think anyone doubts the hackedness of those systems.
I wonder if any systems out there are actually secure?
Today I validated my theories about running the isolated SPUs on the PS3 as crypto engines. The PS3 is 100% hacked. So where my homebrew at?
PS3 Hypervisor and Bootloader Dumped
PS3 Hacker CJPC has managed to dump the PS3 hypervisor and LV1 and Bootloader LV0 via PS3 RAM. He has provided a brief explanation of what he did and a download file to the exploit can be found in the VIA link:
"We are happy to report that the PS3 Hypervisor LV1 and Bootloader LV0 are dumped from the PlayStation 3’s RAM after getting our SX28 Hardware a few days ago, utilizing code for glitching and mashing buttons for hours - the exploit eventually will get triggered!
We tried a few different ways to dump out the real memory - the biggest “problem” was the fact that you can’t just simply use File I/O code in a kernel module. Furthermore, you can’t call the lv1_peek function from user mode either.
Luckily, resident DEV kakarotoks was up to the challenge. After some trial and error (and too many PS3 crashes!) he made a kernel module which maps the “real” PS3 memory to a device in /proc. The /proc area lets the kernel and userland interact some.
Basically, the device /proc/ps3_hv_mem is created when the kernel module is inserted. Once it is inserted, you can use dd to read the device. By doing this, the device gets passed arguments, which is passed along to lv1_peek - which in turns reads out the real memory.
Be advised, don’t go beyond the PS3’s upper memory limit. At around 260MB, the PS3 tends to crash - it does not like trying to read beyond RAM limits! So, for usage:
First, run the exploit, and get it triggered and working - that’s the hard part!
Next, download the attached file, inside are three files, a Makefile, the ps3_hv_mem.c and a pre-compiled version. Stick these in a folder, and run make. It will then compile a kernel module for you (ps3_hv_mem.ko, or use the pre-compiled one). Then simply type: sudo insmod ps3_hv_mem.ko
Enter your password and check /proc for a ps3_hv_mem entry, or your dmesg. If it is there - let the dumping begin!
You can dump out the PS3 Hypervisor and Bootloader (and the rest of the real memory) via dd. You can use the command:
dd if=/proc/ps3_hv_mem of=PS3_Memory_Dump.bin bs=1024 count=10K
That command will dump out 10485760 bytes, or about 10MB - which nicely includes the goodies like LV0 and LV1. Finally, you can also increase the count, which will increase the amount dumped (multiply by blocksize)."
Sony anwers to Geohot’s PS3 hack with a patent
Recently a new patent by a SONY employee was published on the patent site at faqs.org. It seems it is SONY’s answer for Geohot’s progress. Take a look here:
“A method, system, and computer-usable medium are disclosed for controlling unauthorized access to encrypted application program code. Predetermined program code is encrypted with a first key. The hash value of an application verification certificate associated with a second key is calculated by performing a one-way hash function. Binding operations are then performed with the first key and the calculated hash value to generate a third key, which is a binding key. The binding key is encrypted with a fourth key to generate an encrypted binding key, which is then embedded in the application. The application is digitally signed with a fifth key to generate an encrypted and signed program code image. To decrypt the encrypted program code, the application verification key certificate is verified and in turn is used to verify the authenticity of the encrypted and signed program code image. The encrypted binding key is then decrypted with a sixth key to extract the binding key. The hash value of the application verification certificate associated with the second key is then calculated and used with the extracted binding key to extract the first key. The extracted first key is then used to decrypt the encrypted application code.”
zaradio je on mnogo vise od toga sto je hakovao ajfon.. je*e se njemu za tvojih 100e 🙂
suvise se ovde dana/nedelja drvi o ovome,a nista konkretno. samo to kazem. 🙂
Ako neko zna, a lenj je da podeli svoje znanje = je tome da ne zna.
Kako je lepo "etiketirati" pismenije ljude od sebe.
Ako znaju više onda nisu nikad izašli iz kuće.
Ako rade dobro plaćen posao to nije kreativno. 😀
Vidiš, nazire se razlog zašto si ti nezaposlen a tvoja žena ima 20k platu. 🙂
