Gamerski full komp do 650e
Milosnis018
CPU & Cooler
AMD Ryzen 7 7700 3.80GHz & BE QUIET! Pure Rock 3 black
Matična ploča
ASROCK B850M Pro-A WiFi
RAM
EXCELERAM 32GB DDR5 6000MHz CL30
GPU
AMD Radeon RX 6650 XT: PowerColor RX 6650 XT
Storage
PNY 1TB CS2150 M.2 PCIe M.2 & Patriot P210 2048GB
PSU
MSI MAG A850GL PCIE5 850W
Kućište
CHIEFTEC Visio GM-30B-M-OP
Monitor
ASUS TUF 32'' VA VG328QA1A 90LM08R0-B01E70
Ostale periferije
Sony Playstation 5
Laptop
LENOVO IdeaPad 1 Ryzen 7 5700u 40gb ddr4 1TB NVMe
Tablet
XIAOMI Redmi Pad Pro
Mobilni telefon
Honor Magic 7 Pro & Motorola Edge 40
Pametni uređaji
HUAWEI Watch GT5 Pro
Steam
jomilos84
Pristup internetu
  1. Kablovski internet
Burazer iz Bg-a želi da mu sastavim gamersku kofiguraciju do 650e
Skoro sam sastavio konf. za mene na ovosm sajtu ali želi grafiku Ati 5850, i da su sve komponente iz Gigatrona (u komšiluku mu je)
Da li može da prođe ova konf. ?
Ploča: Gigabyte MB - SOCKET AM2 - GA-MA78LMT-US2H 6.712,00 din
http://www.gigatronshop.com/products/show_product/18102/4
Procesor: AMD Athlon II X4 620 8.482,00 din
http://www.gigatronshop.com/products/show_product/16499/5
Grafika: SAPPHIRE HD5850 1G GDDR5 22.370,00 din
http://www.gigatronshop.com/products/show_product/17451/10
Hard: HDD SEAGATE DiamondMax 500GB 32MB,SATA II-300 4.179,00 din
http://www.gigatronshop.com/products/show_product/13324/6
Ram memorija: TRANSCEND DDR3 2GB 1333 4.071,00 din
http://www.gigatronshop.com/products/show_product/17691/11
Optika: LG DVD-RW - GH22NS50 1.840,00 din
http://www.gigatronshop.com/products/show_product/17743/13
Napajanje: LC POWER SUPERSILENT 600W LC6600 V2.2B… 4.635,00 din
http://www.gigatronshop.com/products/show_product/10674/9
Kućište: KME CX3867 USB + Audio crno 1.833,00 din
http://www.gigatronshop.com/products/show_product/17771/8
Tastatura i miš: GENIUS FULL PACK SlimStar C110 Serb PS2 Black 828,00 din
http://www.gigatronshop.com/products/show_product/16122/14
Monitor: Acer 21.5 Wide V223HQb FULL HD 12.300,00 din
http://www.gigatronshop.com/products/show_product/16356/7
Ukupno 67250 - 2% za online oko 66000
Lično, bilo bi mi krivo da dam tolike pare za konfu i da imam taj monitor, miša i tastaturu. Nije gejming samo grafička.
Kapiram da je ograničavajući faktor 5850 (mislim, trećina cene, ne mogu shvatim) i što mora sve iz gigatrona, ali ima rešenja da se uzme jednako sposoban gejming računar sa boljim perfierijama (ne mora logi od 150e, ms za par hiljada din ima lepe kombinacije) i makar 23-24" ekranom. Ima po gradu se nađe onaj 24" Benq ima još dvi i hdmi... danas sutra će neko možda hteti da zakači PS3, a onda znači hdmi ili dvi.
Meni se ne svidja hdd, preskoci maxtor. Vidi promeni cpu i mb, mada ne znam sta da preporucim,ne znam sta imaju .Za igre je dual x2 550 b.e. core bolji od tog 620
Pa iskreno nisam bas odusevljen mashinom.
Stavio si sve u "KME" kuciste.
taj LC Power je dobar ali ne znam da li je dovoljan za 5850.
Samo 2GB rama.
I taj Acer monitor.
Ali posto tvoj brat iskljucivo zeli bas tu graficku, mislim da nisi mogao bolje da sklopis.
Nisam ni ja oduševljen, daleko od toga, ne može sve u tih 650e
Bitno mi je da li će moći ovaj procesor i napajanje da radi kako treba uz ati 5850?
Ram je najlakše kasnije dodati
Monitor će da ga služi, kasnije ako hoće neka kupu plazmu
Promeni napajanje. LC6600 iz silent serije je stari tip napajanja i nece ti biti dovoljno dobro za 5850. Minimum dodaj oko 5-10e i uzmi nesto od GP3 ili Pro serije.
hm nisam bas odusevljen konfiguracijom ali ... sta sad 🙂
jedino sto mogu da "posavetujem" jeste da se tvoj brat predomisli u vezi grafike jer ..... realno:
- najvise gube na vrednosti,
- najlakse se menjaju
- 5770 je i vise nego dovoljna karta za sve igre danas koliko sam upoznat ... pogotovo na 21" monitoru, ako i postoje neke zahtevnije ... oh .. pa nece umreti ako ih ne odigra sad.
- topla preporuka za razliku u parama .... monitor ... BenQ G2420HD ... 16k dinara.
sto se tice problema ... hoce li 600W napajanje terati 5850 ..... hoce naravno nemoj da te lazu i plase sa drugacijim pricama ...
ne valja mu ta maticna ploca i ima bolju za te pare...ova em je "mala" ploca em mu ne treba integrisana grafika,a tu je i 760 cipset...bolje da uzme msi 770 c45 ili biostar a770e3...hdd nek uzme samsung 500gb f3...i nek preskoci gigatron jer na forumu ima dosta prituzbi na njih prilikom reklamacije i slicnih stvari
Da li te ploče mogu da izvuku max iz AMD X4 Phenom II 965, 3.40GHz/8MB 64Bit BOX Black Edition ?
Burazer je odustao od ATI 5850, ali bi onda želeo ovaj procesor i grafiku ATI 5770.
Nerazumem,stavljti phenoma na plocu sa losom naponskom za quad core procesr i cenom od 55e.
Gledaj da ti neki minimum bude msi 770-g45,a bilo bi pozeljno i GB ma 770t-ud3p.
ko te je slagao da g45 ima jace fazno napajanje od c45 i da nece da radi phenom2 (955be i 965be) na njoj? onda mi je cudno kako radi 15-tak compova koje sa sastavio sa tom plocom i tim procesorima...najnovija revizija 965be c3 ima potrosnju od max 125w sto ploca savrseno moze da podnese...jedina razlika izmedju g45 i c45 je jos jedan pci-e slot(4x)...koliko ja vidim na msi-jevom zvanicnom sajtu su podrzana oba phenom-a tako da tu nista nije sporno...
Niko me nije slagao,procitaj malo pa ces videti da g45 ima malo bolju naponsku od c45,a ja nigde nisam rekao da phenom 955be nece raditi na c45 nego da nema smisla stavljti ga na maticnu sa losom napaonskom za quad proc.😉
sastavio sam podosta computera sa obe ploce i koliko vidim obe imaju isto fazno napajanje...naravno da ima smisla stavljati quad-a na tu plocu jer ce savrseno raditi...nije mozda preporucljivo previse klokovati ili ocekivati neki veliki oc potencijal sa njom ali ce raditi savrseno...kad ove jeftine biostar ploce sa 4 faze rade dobro(sa quad-ovima ili sa "otkljucanim" quad-ovima),a jos su i naklokovane onda ce i msi koji ima vise faza raditi dobro tj jos bolje
