undertaker_84_
Koje je najbolje izdanje filma Outlander u 1080p BDRip?
Itekako vredi
najbolje moguce za taj film(ove)
RELEASE.NAME..: The.Usual.Suspects.1995.720p.BluRay.DTS.x264-ESiR
RELEASE.DATE..: 30.05.2007
THEATRE.DATE..: 19.07.1995
RUNTiME.......: 1:46:04
SiZE..........: 4,35 GB
ViDEO.CODEC...: x264
FRAMERATE.....: 23.976
BiTRATE.......: 4372 kbps
RESOLUTiON....: 1280x544 (OAR)
AUDiO.........: English DTS 5.1 1,5 mbit (DTS core from DTS-HD)
SUBTiTLES.....:
SOURCE........: The_Usual_Suspects_Blu-Ray_1995-PerfectionHD
Complete name : K:Blu-Ray 1080pThe.Usual.Suspects.1995.BluRay.1080p.DTS.DUAL.x264.dxva-EuReKAThe.Usual.Suspects.1995.BluRay.1080p.DTS.DUAL.x264.dxva-EuReKA.mkv
Format : Matroska
File size : 8.29 GiB
Duration : 1h 46mn
Overall bit rate : 11.1 Mbps
Encoded date : UTC 2009-12-28 07:27:40
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 46mn
Bit rate : 8 955 Kbps
Nominal bit rate : 9 232 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.238
Stream size : 6.66 GiB (80%)
Title : x264 - 2 passes @ 50% of the original bitrate
Writing library : x264 core 80 r1376M 3feaec2
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=2 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9232 / ratetol=1.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:0.50
Language : English
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 46mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.12 GiB (14%)
Title : DTS 5.1 @ English 1536 kbit/sec
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 46mn
Bit rate : 448 Kbps
Stream size : 341 MiB (4%)
Title : AC-3 5.1 @ Turkish 448 kbit/sec
Language : Turkish
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Turkish
Text #2
Format : UTF-8
Language : English
Pa ne znam, ja sam ovo nasao:Postoji
HDxT-ov encode ne vidim na sajtu.Kod:RELEASE.NAME..: The.Usual.Suspects.1995.720p.BluRay.DTS.x264-ESiR RELEASE.DATE..: 30.05.2007 THEATRE.DATE..: 19.07.1995 RUNTiME.......: 1:46:04 SiZE..........: 4,35 GB ViDEO.CODEC...: x264 FRAMERATE.....: 23.976 BiTRATE.......: 4372 kbps RESOLUTiON....: 1280x544 (OAR) AUDiO.........: English DTS 5.1 1,5 mbit (DTS core from DTS-HD) SUBTiTLES.....: SOURCE........: The_Usual_Suspects_Blu-Ray_1995-PerfectionHD
RELEASE NAME..: The.Usual.Suspects.1995.720p.BluRay.DTS.x264-HDxT
RELEASE DATE..: 31.01.2010
DURATiON......: 106 min
SiZE..........: 4.37 GB
ViDEO CODEC...: x264, L4.1
FRAMERATE.....: 23.976 fps
BiTRATE.......: 4390 Kbps
AUDiO.........: English DTS 5.1 @ 1.5 Mbps
SUBTiTLES.....: Engish, Greek - ASS
CHAPTERS......: Yes
SOURCE........: The Usual Suspects Blu-ray 1080p MPEG-2 DTS-HD MA 5.1
Mystic River 2003 1080p BluRay DTS x264-CtrlHD
RUNTIME.........: 02h:17m:00s
SIZE............: xx.xx GB
VIDEO CODEC.....: x264, 2pass, L4.1
FRAMERATE.......: 23.976fps
VIDEO BITRATE...: xxxx Kbps
RESOLUTION......: 1920x800
AUDIO1..........: DTS 5.1 English @ 1.5 mbps
AUDIO2..........: Vorbis 2.0 English @ 80 kbps
SOURCE..........: Bluray 1080p VC-1 (THX davev205)
IMDB............: http://www.imdb.com/title/tt0327056/
IMDb RATING.....: 8.0/10 (108,546 votes) # 214
Tag-List of non-HDB encodes
0tv,1920,2hd,442,4hm,aaf,aas,adhd,affinity,afterfx,aitb,alb06,amiable,anon,anonymous,arigold,auhd,-avchd,avs720,azazel,babylon,backtorg, bajskorv,bamhd,barehd,bdisc,besthd,bia,bjm,blind,blueprint,bluetv,bollocks,bone,booya,btt,c0da,c0pycu1,c100,calix,cbgb,cdd,cddhd,cdgirls, chakra,chara,chd,chdbits,chronohd,cinefile,cinefox,circle,-classic,conclave-mendoi,creep,crimson,ctu,ctusports,culthd,cumbuckets, cybermen,dantv,dardus,darling,darm,-dbr,dcp,ddhd,definite,definition,defused,-details,deviant,dfa,dhd,dich,digitaldelboy,dimension, dimeventskorv,dixxx,dnb,dot,down,dpxxxhd,dreamrip,-dtv,dvsky,dynasty,e7,elia,empirehd,endor,eolith,ergo,erotixxx,esexxx,etach,eureka, everlast,felony,fhd,flhd,forcebleue,fpg,fresh,fringe,frostii,fsihd,ftp,futv,gay4life,-get,qextreme,-gg,gnarly,goddlik3,gore,gothic, gradejar,grond,halcyon,hangover,hashies,hd1080,hdbrise,hdclub,hdcp,hdex,hdi,hdlife,hdmi,hdq,hdriderz,hdtunes,hdvd,helix,hqr,hhh,hidt, hint,hornyeurosluts,-hubris,-hushhush,hv,iak,iapula,idhd,idyll,ieva,iguana,ika,imbored,-immerse,imnaked,ind,infamous,ingot,insects, inspired,inyf,-ion,japhson,jtv,kamvid,karas,kfv,khpp,killahurtz,kmk,koenig,krm,krylle,ktr,kwt,kyr,lchd,lichi,-lipan,lmao,lmi,lolcats, lunar,m.3.3.w,magicbox,main,mainevent,manila,marryxmas,mausz,mav,medieval,megui,-melite,metis,mil,mind,mint,miragetv,mistake,mistress, mkv,moa,momentum,moviestars,msr,must,mv4u,mvgroup,mvmhd,mysilu,-myteenvideo,nbs,ngr,nodlab,nodlabs,nogrp,nogroup,nosegment,notilus, notseen,novo,nsubs,ohrly,omicron,oni,orenji,orpheus,oxo,parvati,patrisse,payxxx,phd,piephd,ping,pix,porndoctor,pornoholic,possessed, potus,ppq,prodji,profile,progress,pronclips,prophets,qhd,rank,rap,reavers,-red,refined,remax,resistance,reveille,rockriot,rrr,rta, rullstol,saints,saizen,sargasso,sayid,scenehd,seancehd,sector7,sentry,septic,sex4ever,sex4free,sexorcists,sexors,sexsh0p,sfm,shadow, -shd,sheldon,shitsony,sig,sight,silu,sinners,siphd,sitv,smeg,snoopy,sos,sotir,sow,speshal,sstv,sunspot,svd,svenne,syi,sys,-sz,tadashi, tdm,tbs,telescovery,terra,thugline,timelords,titul,tmg,tokus,tomeku,treble,trick,trim,td,tva,tx,umf,ureshii,useless,vark,vcdvault,vico, voa,vti,w4f,wankaz,wde,web-dl,whatelse,wide,wigwag,wiki,wire,wpi,wshark,wwii,-x264,xdr,xpress,xtm,xxx4u,xxx4u2,xxxtime,yestv,yongyan, youforgottorepackthis,younghuie,-yt,z@x,zaff,zart,zero-raws,w0rm,-wb,-wao
* (C)Z
* AE
* AJ8
* AJP
* Arucard
* AW
* BG
* BoK
* CRiSC
* Crow
* CtrlHD
* D4
* DiGG
* DiR
* DiRTY
* disc
* DBO
* DON
* DoNOLi
* D-Z0N3
* EbP
* ESiR
* fLAMEhd
* FPG
* FSK
* Ft4U
* fty
* Funner
* GMoRK
* GoLDSToNE
* H2
* h264iRMU
* HDB
* HDC
* HDBiRD
* HDL
* HDxT
* H@M
* hymen
* HZ
* iLL
* iOZO
* J4F
* JAVLiU
* JCH
* k2
* KTN
* KweeK
* lulz
* M794
* MAGiC
* MCR
* MdM
* MMI
* Mojo
* NaRB
* NiX
* NWO
* OAS
* ONYX
* PerfectionHD
* PHiN
* PiNG
* Prestige
* Prime
* PXE
* QDP
* QXE
* Redµx
* REPTiLE
* RuDE
* S26
* sJR
* SK
* SLO
* SPeSHaL
* SrS
* Thora
* tK
* TM
* toho
* tRuEHD
* TSE
* V
* VanRay
* ViNYL
* XSHD
* YanY
* Z
* Zim'D
Pa da, ali "720p has a widescreen aspect ratio of 16:9," To znachi da to nije 720p, kako kazhu, zar ne?http://en.wikipedia.org/wiki/Aspect_ratio_(image)
Zato što većina filmova nije u formatu 16:9, oni koji jesu imaju 1280x720![]()
720p filmovi i jesu uglavnom 4.42GB zbog DVDa... a za veće, player sa HDD-om ili (HT)PC.![]()
