Aliens Vs Predator
Alien Vs Predator 3 Marine Onslaughter
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/Dv8Tq_aBCuI&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Dv8Tq_aBCuI&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
Celo vreme tamaniti jedne te iste aliene moze da dosadi, valjda ce i u Marine kampanji biti neke jurnjave sa Predatorom....
^naravno da ce biti. ako si igrao predhodne igre iz AVP serijala, onda znas kako izgleda kad si marinac...j*bace te i alieni i predatori kolko oces :D
ово је било само 3 минута игре :)
Evo ga i Predator Gameplay Trailer.
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/0RpPsXpNAMM&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/0RpPsXpNAMM&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
Obavezno odgledati ova dva duza sa pocetka igre dok jos nisu obrisali.
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/TfWClKfcZaA&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/TfWClKfcZaA&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/vIWDeIth4e0&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vIWDeIth4e0&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
Woohoo krvi do kolena :) gejplej nije los, ne deluje dosadno.
Izgleda da ipak neću zažaliti što sam preorderovao igru sa steam-a.
Ja koliko se secam marinac nije imao sta da trazi u melee borbi ni u filmu ni igri, pogotovo ne sa alienima, a ovaj ih resava kundakom ko od sale.. glupost
Nekad bilo sad se spominjalo ...
Sada marinci šamaraju aliene onako usput dok se naganjaju sa predatorom :D :d
Jooj sad ce verovatno oni neki opet da pocnu kako je igra arkada i kako nema veze sa simulacijom :D
Sto se mene tice za igru tog tipa je najvaznije da je igriva, zabavna, da ima dobru pricu, dobru atmosferu u igri a i da dobro izgleda.
jel i tebi pise download starting vec duze vreme ?:)
edit:nvm,krenulo je :p
Searching for games mi stoji u nedogled?! To kod mene samo tako ili... :trust:
    137.9 KB · Pregleda: 80
Takođe. :S:
Uspeo sam da se nakachim, posle jedno 30-ak minuta.
Mp je skroz bez vez, po meni nije vredno skidanja i "muchenja" sa nalazhenjem servera. :S:
    226.9 KB · Pregleda: 115
    128.7 KB · Pregleda: 106
    157.5 KB · Pregleda: 109
    129.6 KB · Pregleda: 90
Načekao sam se da bi me dva puta ubacivao u lobby i ubrzo disconnect-ovao sa server-a, pre nego što se igra učita.
Sigh...
Ja sam cekao mozda po minut da bih usao na bilo koji server. Inace, po mom misljenju multi je osrednji, nista specijalno, cak na momente sa lagom je iritantan i dosadan.
Ceako dva puta po 5 minuta, i nista; na kraju sam obrisao demo. Bolje da su dali jednu misiju sa marincem.
Hurray, uspeh da se nakačim i ostanem u igri! :d
Okušah se sa svim rasama. Utisci? Hajdemo redom.
Hardverska zahtevnost nije velika, kao što se i očekivalo. Mašina iz potpisa, sa svim video podešavanjima na najvećim mogućim vrednostima pri rezoluciji od 1280 / 1024... Ni u jednom trenutku FPS nije pao ispod " idealne granice " od 60 FPS-a. ( Nisam bio u mogućnosti da izmerim tačan FPS, ali... S obzirom da monitor koji koristim ima refresh rate od 85HZ, stekao sam utisak da je FPS tokom svih partija bio zakucan na tih 85 FPS-a. ( V-Sync uključen. ))
Dizajn nivoa... Jednom rečju, tmuran. A kao takav, krajnje " deprimirajući ". Preovlađuju tamne boje, kao što smo mogli videti iz SS-ova ranije. Ne baš tako smislen dizajn mape koju igrah. ( Alien ima preveliku prednost u vidu mogućnosti kretanja u odnosu na preostale dve rase. )
Gameplay... Ehm, preovlađuje utisak tromosti u pogledu prethodne igre istog serijala. Raspored kontrola je loš. Na primer, predodređen taster za trčanje je Q u stilu, press and hold, što otežava kretanje ka levoj strani. Kod Predatora, V-Mode je na F, a ne na V kao u prethodniku. Cloak-Mode na R, a ne na C, itd. Mada, sve ovo pada u vodu jer je kontrole moguće menjati... Ali eto, začudio me je takav raspored kontrola. Što se tiče samog " batinjanja ", Marinac teško da šta može učiniti melee attack-om. Batinjanje Aliena u trejleru je bila puka slučajnost. :p Kao Predator / Alien, potrebno je oko tri, četiri udarca ubiti Aliena i Predatora, dok Marinac-a nešto manje. ( Mislim na basic attacks. ) Trofejni, iliti kako se već nazivaju, frag-ovi su nepraktični jer animacija istih traje dosta dugo te je velika šansa da dok lomeći Aliena na pola već drugi stoji iza vas, pomno čekajući da vam žigoše glavu. Spomenuo sam prednost Aliena... Mapa je mračna, sama po sebi. Još kao Alien, možete uništavati izvore svetlosti što vam još više olakšava lov. Recimo, ako se šetkate niskim hodnicima, čekujte viseće Aliene kako vas sa lakoćom peckaju repom! :p Marinci su mahom camp-ovali, očekivano. Mada, ni to nije Bog zna kakva " strategija " jer čim radar otkuca više od par movement-a, znajte da nećete još dugo živeti. Predator, očekivano... Cloak and hunt! No, da ne dužim dalje...
U svakom slučaju, očekivao sam više... No, dobro.
Dakle, kao jedno od mogucih resenja za sve nas koji imaju problem sa nalazenjem igre je da se medjusobno add-ujemo na Steam-u pa da lepo sami izorganizujemo neku partiju. Moj nick na Steam-u je isto kao i ovde, dakle Shimec, pa ko zeli da me add-uje moze slobodno.
EDIT:
Dzabe moja incijiativa kada ja ne mogu nikoga da add-ujem zbog toga sto nemam ni jednu igru sa Steam-a. Damn!
Koja je fora, meni nece da nadje igru, koje djubre od demo-a...
Da usao sam i ja u igru posle 10-20 minuta i nista ne valja, toliko je tromo kretanje i akcija losa nemam reci, grafika je ok i optimizacija, mozda bude koliko toliko ok u single-u u sta sumnjam.
Za multi uopste nije, bolje da su se usresredili na singleplayer kampanju da urade sto bolju.
Ako su vec hteli neki MP a da valja, bolje je da su ubacili jos jednu kampanju sa marincem koju je moguce igrati u coop modu. E to bi vec bilo super.
Uf,to bi bilo ekstra. Takodje i sa predatorom,i alienom...mada sad verovatno previse trazim :)
Nije uopste los ovaj multi, daleko je zanimljiviji od cod mw2. Jedino smeta lag misa koji ne znam kako da resim, verovatno ce to biti ispravljeno.
Dobar je balans i sa sve tri rase moze da se dobro igra, a opet ostaje osecaj nadmocnosti sa predatorom i staha sa marincem. Brzina kretanja je taman kakva treba da bude.
P.S. Kome nece da se konektuje, samo ostavite igru u pozadini da se konektuje i pogledajte posle nekog vremena, kad tad ce uci u igru.
