Sony Playstation 3 - opšta diskusija i blic pitanja (II)
PS3 josh od 1939 :p
Pa ko veruje :)
U februaru ce im sajt biti online i moci ce da se kupi, samo nigde ne pishe cena :)
Nisam pogledao video(prokleti MAG se skida 100 godina), ali tekst zvuci totalno neuverljivo ;).
A jos stoji windows prozor :banana: :banana: :banana:
I ne samo to :) :
"First point I would like to make, is that he launches the program from the 'Whats new' feed button. Second, since when does the PS3 have window management, and with a Windows XP theme to boot. Third, since when does a system patch stay at the XMB. Fourth it takes roughly twice as long to 'patch' as it does to copy the entire Blu-ray game."
"Look at the time at 0:49 - After lunching ps3 in clock (in right top) is 14:56 and after pressing ps button is 14:53"
1) XP je samo grafika, pise vam u tutorialu.
2) Pise i da pravi neke probleme sa podesavanjima sistema (vreme, datum itd. cini mise). Ok, lak izgovor.
After Installing Zpack my PS3 is freezing, I can backup and play games without problems but the PS3 clock is showing sometimes the wrong time/wrong date and things like that?
Yes, while installing and using Zpack the PS3 OS is "slowed down" (Asymmetric Scheduling is changing) The Zpack USB Dongle is taking Control of scheduling and of the resources. We noticed the problem with the PS3 clock and controller assignment. But when you mount your games everything will be working. Tip: after installation - while turning on your PS3 with Zpack disconnect your ext. hard disk.
3) Virtua Tenis ne zauzima ni blizu 25GB.
4) Ovo je navodno patch, nije flash celog FW-a.
Lako je moguce da je fake, ali videcemo vec.
Virtua Tennis 3 zauzima oko 4.5GB pa ajde da kazemo da je to ok. A i ovo sve shto je Ragnarok rekao se opet nekako poklapa. Ne znam zashto bi to uradio sa vremenom a onda u tutorialu objasnio da postoji problem, mogao je odmah u montazi to da sredi :)
100e nije mnogo s obzirom da su neki ovde kupili PS3 kada je izashao, za 800e i igre placali po 150 :d
Say, el ste se to vi nalozili na pirateriju :D.
Unistice vam konzolu ta poshast :p.
Da proci ce PS3 ko PC. Nece imati sta da se igra. :smash: :smash: :smash:
Kod onih proslih gluposti sam jos i pratio i interesovao se, ali sad me bas boli uvo. Necu ni probati, cak i da je sve istina. Sto se tice ovog, a i svakog sledeceg playstation-a, oridjinali forever za mene :)
+1
http://www.gamingbits.com/index.php...ll be published after review by Administrator.
PlayStation 3 gamers looking for keyboard and mouse controls on first-person shooters will soon be able to use any combination of their choice. Penguin United is getting ready to introduce PS3 gamers to the Eagle-Eye Converter.
"One of the drawbacks with playing first-person shooters is the lack of speed and accuracy offered by traditional controllers," stated Richard Huang, President of Penguin United. "We found a simple solution by bypassing the controller and transferring the button features directly to the computer keyboard. The Eagle-Eye offers an amazing alternative for fans of shooting games."
a za potpun doživljaj generišemo BSOD i resetujemo konzolu (obavezna reinstalacija igre i ponovno skidanje patcheva) obično pred sheckpoint. :)
Ovo za obavezno skidanje patcheva vec imamo.
Konačno se neko razuman pojavio i na PS3 tržištu :D
hmm.. i sad zamisli borisa kako pegla mw2 (najbolji fps ever) i uleti u partiju gde svi imaju k+m. izivljavace se po jadnom risbou :(, pa ce on da se razocara o cod serijal :(
salu na stranu, iako ce dosta pojedinaca da se odusevi zbog ovog (ako bude radilo kako treba), opet se vracamo na pricu kakav ce ovo uticaj imati na online..
Nesto sumnjam da ce biti upotrebljivo.
Ako igra nije razvijana za K+M, mogu oni da se cimaju koliko hoce, to i dalje nece biti "pravi" osecaj.
Ekvivalent ovome su FPS portovi sa konzola(ili FPSovi gde su konzole bile vodeca platforma), lako se primeti da to nije to.
Pa ček, kako MW2 nije razvijan za k&m? Kapiram da će posle ovoga developeri razmišljati o k&m support igrama.
Možda neće biti pravi osećaj ali će makar imati taj uticaj da ću možda sada i kupiti neki FPS jer neću morati da biram izmedju toga da mi treba dve sekunde da se okrenem za 180 stepeni i toga da mi treba 2 sekunde da nekoga nanišanim jer sam stavio preveliki sensitivity - šta se dešava sa ovim FPS igricama danas, zar nisu mogli da ubace quick turn dugme ili makar da lupam stave L3/R3 + analog kao funkciju kojojm imaš duplo veću brzinu rotiranja? :)
Meni je FPS igriv na ds3, nije to to, ali moze da se igra.
Ko zna, da je ovo ranije najavljeno, mozda bismo i dobili pravu verziju Dragon Age-a na PS3.
Sony PS3 hackovan? stara verzija konzole sa Linuxom?
PS3 hack plays Blu-ray backups, should send Motorstorm values soaring (video)
By Tim Stevens posted Jan 5th 2010 7:25AM
The PS3 has thus far proven to be something a tough nut to crack for those wanting to play backups on non-modified consoles, but word on the web is that a technique has been found that will make it possible -- if the stars happen to align properly for your hardware configuration. What you need is a PS3 model capable of running Linux, Ubuntu, Windows XP on top of that, a suite of utilities, a copy of the original Motorstorm, and a Blu-ray burner. Get all that configured properly and you should be able to use the technique at the read link to play those copies of games that have thus far been expensive coasters. Given the complexity of this approach we can't be 100 percent sure it's legit, but for what it's worth there is video "proof" after the break, and should you attempt this feat of hackery yourself please do let us know how you get on.
http://www.engadget.com/2010/01/05/ps3-hack-plays-blu-ray-backups-should-send-motorstorm-values-so/
Sa http://www.maxconsole.net/?mode=news&newsid=38204
Here is a rough summary of what is required:
Step 1: Install Ubuntu on your PS3 (or kubuntu)
Step 2: Install Windows XP on Ubuntu
Step 3: Install CloneCD on Windows XP and connect to network another PC so has seen in My Network Places. I do not know if AnyDVD HD is necessary, but I installed it for me
Step 4: Open CloneCD, select new image, insert the game, select “Protected PC Game”, change the extension to ISO.
Step 5: Ripper Blu-Ray on PC via network favorites.
Step 6: Burn with ImgBurn (or CloneCD) in 1X on the PC or has been ripped game
All the details are available to view at haxnetwork (However the site some months ago was virus infested for us so be careful).
Toliko puta prazvaka prica, i svaki put je zavrsila u kanti. Sta ce bre mis za PS3 ? Ko kaze da ne moze FPS da se igra na DS3 taj ne treba ni da ima PS3. Treba sam covek da se uigra. Igrao sam KZ2 i R2 bolje na DS3 nego sto cu ikada neki FPS na PC-u. Treba samo da naprave za sledecu generaciju DS da pecurke budu malo tvrdje i sa manjim hodom, i naravno DS3 mora, ali mora biti tezi. Nisam verovao kako Xbox kontroler dobro lezi u ruci zbog tezine.
