WD TV Live
Ko ima stariji 1080P TV bez HDMI ili ima problem sa HDMI postoji nacin da se Live natera da prikazuje 1080P preko komponentnog kabla (zvanicno je dostupan 1080i ali sa originalnim fw ima nacin da se natera da prikazuje 1080P)
Razlika je ocigledna u brzim scenama
Sam standard propisuje da je 1080i maximum, ali nema razloga da radi i vise... jedino sto treba obratiti paznju je na duzinu i kvalitet kabla..
Od kada? 1080P@60Hz preko komponentnog kabla je samo vestacki ugasen, hardware od Live-a, kabla i TVa ga potpuno podrzava
Component video is capable of carrying signals such as 480i, 480p, 576i, 576p, 720p, 1080i and 1080p[1], and new high definition TVs support the use of component video up to their native resolution.
...However, the most significant source devices are the major gaming consoles, with both the Playstation 3 and the Xbox 360 supporting 1080p analog.
Evo i detaljnog uputstva ako nekom zatreba (problem sa HDMI, nema dovoljno HDMI portova na TVu...). Ali zahteva originalni (ne updateovani FW) i mora posle svakog restarta da se primeni:
WDTV Live woes: or how to get 1080p over COMPONENT
« on: October 25, 2009, 03:24:50 AM »
swartz
Newbie
Sup y'all
This might not be interesting to anyone who got WDTV Live to work over HDMI without any issues.
But there are some (like myself) who had the misfortune of not being able to enjoy WDTV Live to its full potential.
First, without going into much detail, I could not get WDTV Live to work in HDMI at all. WDTV Live boots to WD logo, screen flickers, and then TV says no HDMI input error.
More info here: http://www.avsforum.com/avs-vb/showthread.php?p=17370554#post17370554
I have tried everything, different cables, different settings, etc. I have tried it ALL. Does not help. My HDTV works with Bluray player and laptop over HDMI, but not WDTV Live. WDTV Live works fine with another TV. So its not broken per se. I returned one WDTV Live box to the store and got another one. Same problem: can't connect over HDMI.
So when I say I tried it all I really mean it. So the conclusion is that either my TV or WDTV live (or both) suffer from the dreaded HDMI handshake problem. When I contacted both device manufacturers they blamed each other and no one wanted to do anything. So much for support. Once they got my money, it's mission accomplished for these guys. Why care anymore, eh?
I waited for WDTV Live to come out for a while. Heard plenty of god reviews about the original WDTV and the hacked firmware appeal.
But I wanted network right out of the box. Needless to say, wen I finally got WDTV Live and couldn't get it to work was a HUGE disappointment.
If I were to keep WDTV Live I wanted 1080p on my TV to work, period... or WDTV Live would be punted out the bloody window. Why should I settle for less, right?
Oh I nearly smashed the damn thing after countless wasted hours. But... it didn't all go to waste it turns out.
I discovered what I think is a bug. I now believe there is an artificial limitation that prevents WDTV Live to just have an option of 1080p over COMPONENT cables.
For whatever reason (hollywood interests prolly) WDTV Live officially does not support 1080p over composite cables.
Coz' you know that's like unprotected hi-def video and all... Like HDMI/HDCP ever stopped anyone really serious about pirating content.
All this protection nonsense only prevents legit consumers (like myself) from enjoying their products.
See official WD knowledge base answer ID 3798 for WD answer regarding 1080p over component.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3798
No explanation as to why, just not supported. Dare to explain? Surely, there is no physical limitations.
For doubters, 1080p is possible over component. See: http://en.wikipedia.org/wiki/Component_cable
But I digress...
To see this bug/glitch at work, try this:
1. Connect WDTV Live to a TV capable of 1080p over component (you can leave HDMI cable disconnected)
2. While using component input on your TV, go into A/V Settings on WDTV Live box
3. Select Component as source
4. Select 1080i @ 60hz (the highest option for me)
5. Select RGB for color space. If you select YUV this glitch wont work fully (only lasts in confirm resolution screen, when OK-ed, reverts back).
6. Click OK to confirm resolution change. And confirm that your TV is now 1080i over component.
7. Now go to A/V setting again and select HDMI (yes now go to HDMI even tho HDMI might not be connected)
8. Select 1080p@60Hz (the highest for me).
9. Select AUTO in Color Space (although RGB High or Low should both work, not sure about the last option there).
10. Your screen will flicker and you will get the Confirm Resolution change - check your TV's info what resolution it is in. BAM! 1080p over component, something WD says is not supported.
11. Don't forget to click OK in this screen. The screen will stay in 1080p over component (if you hadn't set Color space in step 5 to RGB, but rather to YUV this step will revert back to 720p over component)
12. You can now play 1080p content over component at full quality. Counter to what WD is officially "supporting".
After following these steps my TV confirms it's getting 1080p over component. I can also visually confirm difference between 1080i and 1080p modes on the TV. In 1080i I can visually spot interlaced lines especially when there is a lot of action on TV with high black/white contrast. While 1080p does not exhibit this interlaced line effect.
There is one limitation however:
WDTV Live does not save this setting properly when powered down.
So if you turn your WDTV Live off or place it in standby it will revert back to 720p when back on.
So you have to do this sequence of steps every time it turns on or never turn it off (duh!).
I hope someone like b-rad would be able to make this setting save properly. I have little hopes of WD officially supporting this. And, unfortunately, my bet is this glitch will be fixed in the next official firmware release from WD.
So if you're like me with a 1080p TV and WDTV Live not cooperating with each other, there is still hope to get full 1080p picture on your HDTV although not through HDMI like you might want.
So far I confirm this bug existing on two separate WDTV Live boxes with either the official firmware from WD or with b-rad's hacked firmware v0.1.4.
I hope that some may find this information interesting so that is why I post this.
I just ask that if someone could test this out on their set ups and either confirm or deny it would be most welcome to myself and others, I'm sure.
Thank you!
http://wdtvforum.com/main/index.php?topic=2513.0
Od uvek... standard je glupo definisan (CEA specification, CEA-770.3-rev C), sta da ti kazem.. bilo je inicijativa da se promeni, ali je ne bitno... dosta uredjaja podrzava 1080p i van stanadrda...
Ima i laksi nacin koji radi sa novim FW (opet mora pri svakom restartu):
HDMI output handshake problem/1080p via component figured out
« on: November 24, 2009, 08:51:17 AM »
So just got my WDTV live yesterday. I have been using the original WDTV #1 for10 months now connected to my TV via HDMI with no problems. I now connect the live via the same HDMI cable and same setting as the original WDTV and my TV briefly shows the GUI of the live then flickers and says not supported. I connected the Live to my PC monitor via HDMI and everything works great. I can also see the Live via component and this works fine.
Been searching all of the net and this forum and tried everything from 3 different cable, cutting some of the plastic back for the cable to expose more of the connection, resetting the Live and my TV, and tries varies powering order with no success. When I connect via component and try to change to HDMI output it keeps going back to the component. I have also installed the latest firmware. All by HDMI cables or gold plated and 1.3b.
I found this thread http://wdtvforum.com/main/index.php?topic=2513.0 to be very interesting but cannot open the bin file. Any help would be appreciated in opening this file.
TV is vizioVOJ370F
I did figure out how to get 1080p via component. I did the fallowing:
1-plug in the live via component with HDMI cable not plugged in
2-Set up the Live via component output to 1080i and save setting.
3-turn off the live.
4-plug in the HDMI cable while keeping the component connected
5-Power back on the Live and I see 1080p on my TV via the component
This does hold this setting when I turn off the Live. Does not hold this setting if I unplug a cable.
**Update....I have noticed that it will change back to 720p via the component but all I do is change my TV to HDMI 2 until the TV screen says "not support" then change the input back to component and it's back to 1080p
So for now getting 1080p via component but frustrated because want the HDMI like the original WDTV to get the digital audio.
Would appreciate any help or thoughts on this.
Thanks
Ja nešto nisam našao u meniju stavku output hdmi kako bih prebacio na 720p mode. Šalje mi sliku u 1080p pa mi plasma downscale-uje na 1080i :( Što je prilično lošije nego 720p, ona bela linija u menijima mi je malo iskrzana, kao da nema antialiasing...
Jel' postoji opcija 720p preko hdmi-ja i gde je to u menijima?
Settings-audio/video-video output,potvrdis hdmi i onda ti izbaci opciju rez.
Ne znam napamet ali javljam ti kada stignem sa posla (koliko se secam sve je na full (read/write). Inače, probao sam i sa USB wireless adapterom i b-rad firmware-om 0.2.21 i radi. (adapter je Zyxel 220 v2).
poz
Nego ja spojio pc sa wd live-om Lan kablom i shareovao foldere u windowsu medjutim na WD-u ne nalazim nista.
Mozes malo detaljnije objasniti proceduru?
Tek sad vidim opciju 720p, nije bila vidljiva dok nisam isključio iz struje, a pre toga radio firmware. Isprobavamo dalje...
Ljudi, jel' ima još nekoga da mu ispadne zvuk iz sinhronizacije čim se malo premotava napred nazad i nikako ponovo više ne može da se sihnronizuje, mora start od početka?
Meni je sve povezano preko rutera koji dodeli IP adresu Live-u i dovoljno je na Live-u pokrenuti Automatic da bi podesio sve kako treba (subnet, ip, ...).
Nisam povezivao direktno PC i Live ali mislim da ti prvo treba mrežni kabl za direktno povezivanje (Crossover kabl).
poz
Samo da javim zainteresovanima da na wdtv live radi cccam sa dreamboxa 800 i to prilicno dobro. Jos nisam uspeo da nabudzim drajvere za smargo reader, ali bice i to uskoro nadam se, cim izadje optware za live... Onda jos da namestim nzbget i rtorrent i mogu slobodno da gasim ubuntu htpc/cccam masinu, da ne vuce dzabe struju 24/7/365 :) Mlogo dobar ovaj live, nemam reci!
PROBLEM sa novim FW - NE UPDATEOVATI LIVE!!!
WD TV Live boxes left bricked by firmware update
In its short stay on retail shelves the WD TV Live HD media box has picked up an avid community of users for the unassuming unit -- at least until they tried to update the firmware of the last couple of days. Forum reports show formerly operational units with nothing but a blank screen after download the v1.101.12 update. For its part Western Digital has acknowledged the problem and pulled the update from its site, but given the poor ratio of successful upgraders to mourners in the thread, we hope it sees loyal customers out of RMA hell and back to 1080p video playing bliss quickly. Until then, we'd keep clear of that "upgrade now" screen until the next patch has been thoroughly vetted.
S obzirom da se pojavio poznati problem sa novim firmware-om da li neko zna ima li nazad? Naime, na ekranu piše da postoji problem i da se ubaci fleš sa novim firmware-om ("Insert a USB drive with firmware to recover your WDTV") ali na žalost, ne detektuje mi uopšte fleš da sam ubacio u USB. Zna li neko rešenje ili mora na rma?
Da da ni slucajno updejtovati na 12 ,nema zasad resenja nazalost. Ne znam zasto niste lepo stavili od pocetka B-radov 0.2.2.1 radi kao sat. Na WD sajtu stoji da mora na RMA jer nema nacina da se povrati koji ****** covece.
Cholak->Koji Win koristis? Ja sam uspeo konacno u 7-ci da sherujem sta ja hocu a za XP nikad nije ni bilo problema.
7-cu koristim sa crossover kablom.Vidim na lapu diskove povezane na WD Live,mogu cak i filmove da reprodukujem ali nikako obratno?JLZ :d
posle nekoliko dana experimentisanja i dva formata kompa :D moj je zakljucak je da je problem u media serveru u 7-ici. Tj. kada jednom pokrenete media server(ukljucite media streaming opciju, ili pokuste da pustite nesto iz WMPa direktno na WD) od tada nastaju problemi. kao da ovaj media server gusi pristup sharovanim folderima. i situacija se onda samo pogorsava... prvo samo uspori, onda kasnije moze da se uloguje, ali ne da otvori fajlove, zatim ne moze da vidi da je ista sharovano ili kaze da nema media fajlova i na kraju uopste ne vidi komp a drugoj strani mreze. :D
ali zato ako ne ukljucite media server, share radi super.
Kako mislis crossover kablom? Pa treba ti obican UTP cat 5 lan kabl a ne crossover.
Sto se tice 7-ce share radi ali nekad kao sto rekoh nestane na tren.
Bojkicu sta ce ti media server? Samo sherujes foldere i cepaj.:smoke:
Hmmm nestaje i dalje preko LAN kabla sa vremena na vreme(posle 5-10 minuta) pa se povrati mreza, veoma cudno. Izguglao sam ovo i nasao resenje evo vec sat i po nije se prekinulo. Ako nekome zatreba ili ako ima problema nek proba ovako:
"Apparently Windows 7 sharing when set to everyone, is not truely everyone. Annoymous clients dont get access. You have to do some registry magic to make it work but this worked!
Configure the folder you want to share:
1. Select the folder (NOT drive)
2. Right-click and choose 'Share' from the menu
3. From the drop-down box select the Everyone (All users in this list) account, making sure permissions are set to 'Reader'
4. Click the buttons Add, Share and Done.
Here are some further registry 'tweaks'
WARNING: This requires editing your PC's registry which, if edited incorrectly, can cause Windows systems to become unstable and unusable. So, follow the instructions below at your own risk. - we are not responsible for any damage caused by following these steps.
1. Navigate to the following location in the registry editor.
MACHINE\System\CurrentControlSet\Control\Lsa\
2. On the right side, double-click on 'everyoneincludesanonymous' and change the 'Value data' from '0' to '1'
3. Double-click on 'NoLmHash' and change the 'Value data' from '1' to '0'
4. Navigate to the following location in the registry editor:
MACHINE\System\CurrentControlSet\Services\LanManServer\Param eters
5. Double-click on 'restrictnullsessaccess' and change the 'Value data' from '1' to '0'
6. Close the registry editor and restart PC.
After I did this, just go to Video -> Network shares -> chose ur pc and viola...all the folders u set to share is now there!
nije da mi treba... trenutno ga ne koristim jer mi je vaznije da WD uvek vidi sharovane foldere.
media server je zanimljiv samo zato sto mozes da pustis nesto iz druge sobe na wd direktno sa kompa, a da ne moras ni da dolazis do wd-a. npr. muziku u stanu ili tako nesto. valjda ce da rese te konflikte uskoro.
Sa ovim se slazem u potpunosti ako pustas preko WD-a muziku a ne moras da budes ispred njega.:)
Dkrstic->Ispada zvuk iz sinhronizacije kada pustas preko mreze? Znaci kada ubrzavas film? Ako je to onda se meni desavalo ali preko Wifi adaptera samo.
Posto sam sproveo i LAN kabl sa njim nemam problema.
Ma meni se dešava i sa usb-a i sa mreže. Ovaj novi fw, 12-ca, koji je skršio mnoge ;)
Krsticu nemam pojma zasto ti se to desava, jesi probao b-radov custom 0.2.2.1 fw?
Uhhh kako me nervira ova 7-ca :smash::smash::smash:
Sve je radilo juce i danas ok preko mreze, medjutim veceras sednem da gledam neku seriju i izbaci could not connect posle toga restartujem i opet isti error posle nekih 10-15 minuta.
Ok uradim reboot PC-a i WD-a i posle toga gledam 2-3 sata nista sve ok, WTF?:mad:
Uglavnom desava se i da preko kabla nekad pukne e sad nema sanse da provalim da li je do Wina, KIS2010 ili permissions na ovoj 7-ci grrrr
Nisam probao, razmišljam se...
Jel' preporuka s tvoje strane? Daj neki razlog, u release info ne videh ništa korisno za nelinuxaše :)
S obzirom da do vikenda "moram" da nabavim nov wd media,i pratim(laicki) sve teme,..moze li par vas da mi kaze,vredi li uzimati live ili onaj druga generacija,..,ima li problema sa firmware ili ne,prodao sam prvi wd,.pa nije mi povezivanje sa netom neophodno,al nije ni lose,..zanima me ostalo,da li je sem toga naprednije dovoljno od provg modela,ili da sacekam....Puno hvala drugari !:type:
Ako ne planiras preko mreze uskoro da ga koristis (a i nezgodno je razvlaciti LAN kabal do TVa) najbolje uzmi WDTV Gen2 40e je jeftiniji od Live-a (oko 100e je nov u prodavnici). Oba (Live i Gen2) pustaju 1080P, MKV i DTS zvuk, imaju isti cip (brzi i bolji i ima DTS za razliku od WDTV Gen1)
Pa probaj nista te ne kosta:D. Imas na b-rad-ovom sajtu sta je sve on promenio i zasto, jer ja sam moj odmah flesovao sa 0.2.2.1 zato ne mogu da ti kazem razliku!
