pitanje vezano za graficku
Nuc
Zeleo bih da updateujem GPU hardware
Da li je moguce da odem i kupim npr ATI Radeon HD 4870 ili neku slicnu, lepo ubodem to u Mac i da ne moram da idem kod ovlascenog Apple distributera a naravno da sve to radi kako treba
Isto tako bih stavio na njega i WD VelociRaptor 150GB/10.000rpm i na njega SnowLeopard
U pitanju je MacPRO 2xDualXenon 2,66GHz ili QuadXenon 2,26GHz ... mozda sam i pogresio ... na njemu je trenutno Tigar
nadam se da znas anglijski , mrzilo me da prevodim:
The difference between the MAC and PC versions of the ATI card are few.. VERY few. In fact there are only two.
#1 is the Apple Tax!, of course Apple wouldn't sell anything for their computers and not get anything out of it.. HUGE mark up on video cards makes them more money. The MAC version is $420 in canada directly from Apple, and the PC version (with 1gb of RAM mind you vs 512mb on the MAC version) will run you about $180 on sale.
#2 is the special EFI BIOS that enables the MAC Pro to recognize the card when inserted.
Now physically the cards are identical, both using the same RAM, same GPU, with minor changes on the MAC side to make it fit better into the MAC Pro case, most cards even use the SAME BIOS! So the PC version will work perfectly fine in the MAC Pro. By now you may be asking yourself, how the heck can I make the PC card work inside the MAC so that both MAC OS and Windows sees the card.. the answer is simple, find someone who has the MAC card, stuff it into a PC and clone the BIOS using free software available on the internet, then buy the PC version of the same card, (not sure if it'll work with the 1gb version, may only work on the 512mb. You may have to be brave and test it out) and use the same program that cloned the BIOS from the MAC version onto the PC version.
Sometimes this is tricky because the PC card BIOS has to support the size of the MAC BIOS, (because of the EFI information it makes the BIOS file larger than a PC version which doesn't include the EFI info.) As long as it'll fit into the BIOS you can flash the BIOS with the MAC file and it will work like a charm.
There are a few good sites that even provide you with copies of the BIOS files so you don't have to do any extra work hunting down a card to clone. Many people have used this work around for the previous MAC cards, including the ATI X1900 and the NVIDIA 8800GT. I myself have cloned an 8800 and even tweaked the GPU speed to get a little extra performance boost.
Have fun and good luck.. oh, and be careful not to fry your BIOS as this will void your warranty. But chances of that happening are pretty slim, I just like to warn people ahead of time.
Može, naravno. Odeš na http://netkas.org/, malo, ali stvarno malo vremena provedeš tamo čitajući i sve saznaš...
OK ... bacicu se na citanje vezano za GPU ... a niste mi rekli za HDD ili se to podrazumeva ... ovaj raptor je SATA2
dosta sam citao
jos samo da stisnem zube i probam OVO resenje :)
Nemaš šta da stišćeš zube i da probavaš. To će da radi, samo ispoštuj proceduru koju su naveli, skini sve od update-a za sistem i obavezno napravi backup sistemske particije (za ne daj Bože).
Po meni imaš dve varijante - jedna je da flešuješ PrC karticu sa Mac BIOS-om, a druga je da koristiš PrC karticu sa PrC BIOS-om, samo da koristiš Natit ili već nešto sa driver injector-om, ako ti ne treba dual display mogućnost. Onda ne mijenjaš ništa, sve se svodi na instalaciju drajvera, pardon - kext-ova...
Cek, zar ne bi mogao jednostavno da instalira hackitosh drajvere za 4870?
Bas kao svi mi siromasi sto imamo instaliran MacOS na PC-u?
interesantno pitanje ali mislim da ne bi radilo - jer se ne radi samo o driveri za Mac OS X vec o samoj boot proceduri u kojoj je ukljucen EFI na Mac-u odnosno u slucaju PCja BIOS (kasnije modifikovan EFI).
da demantujem sebe, ide se preko flasha - ali opet...na mojoj krsh konfi mek leopard leti. cim ga instalirash resio si problem. pa apple bi morao da porazmisli o svojoj `moja 4850 je bolja od PC verzije` prici. mek je sada manje/vise PC u fensi kucistu.
npr. da svoj OSX sada pocinje da prodaje i PC populaciji koja je mnogo veca od meka.
