Half Life 2 Cinematic mod
ATI`
- The Cinematic Modification adds Hires-Textures to all human characters, some non-human characters, nearly all items, walls and vehicles (and the vending mashine of course). (Hint: If you prefer the original Low-Res Textures, delete or rename the "materials" folder inside the Mod.)
- It replaces the original HL2 music with a more classic score in the style of large Hollywood productions, that fits to the specific game-situations. More orchestral, more ambient, with unique themes for combines and Alyx. (Hint: If you prefer the original HL2-music score, delete or rename the "sound" folder and the "scripts" folder inside the Mod.)
- It adds a new weapons-balancing and strengthens all the weapons to a more realistic level. No more firing numerous rounds at the combines; kill them with 3 to 5 direct hits, just like in real-life combat, but beware: Your opponents weapons are comparable. After 3 to 5 direct hits (or 1 direct headshot) you *will* be killed. (Hint: If you prefer the original Weapons balancing, delete the file "skill.cfg" inside the Mod's cfg-folder)
- The additional Insane Hires Props are previous unreleased Hirestextures for nearly all props in the game, even little items like binders, computerparts, doorlocks and so on. The huge amount of details will give your HL2 virtually the look of a render-intro, but be warned: The amount of new textures will tax your hardware to the limit. Better don't use this pack with outdated DirectX8 cards. Don't even think about it, unless you are using a 256+ MB card.
[YOUTUBE]HwWeXPgEbtE[/YOUTUBE]
[YOUTUBE]xDl8bRVlc0Q[/YOUTUBE]
Jel ovo izashlo ili tek treba?
Izaslo. Nisam uspeo da probam jer trazi instaliran steam klijent.
Jaooooo, mrzim ih... Uh SLEPCI!!!
Aj probacu ja ovih dana posto imam neku fush veziju stema klijenta pa javljam.
Jos samo da skinem 3.2 giga :D
Znaci:
* The 'normal' HD version, with a lot of HD textures and characters. This version requires a fast pc with at least 4GB of ram and a high-end grapichs card. A 64bit Windows version is required.
* The LE version, the Light Edition, does not include the HD characters, new soundtracks and gameplay changes or tweaks. This version works with a 32bit Windows, however this is untested and unsupported.
Jako dobro izgleda... Produbili su ambijent i celokupan dozivljaj igre. Sve pohvale...
E da, takodje bitno iz gornjeg linka:
*** TO PLAY THIS MOD, YOU MUST OWN HALF-LIFE 2 / EPISODE ONE / EPISODE TWO FULLY INSTALLED AND UNLOCKED! (= started at least once) YOU CANNOT PLAY THIS MOD WITHOUT EPISODE TWO CONTENT! ***
Kako cu da se nauzivam, bas sam pazari0 orange box ...
Zbog ovoga cu kupiti orange box
A i jedva cekam BLACK MESA mod za HL1 :D :D
Black Mesa je mod za HL2 koji ubacuje HL1 u engine od HL2.
Hm mozda instaliram 32-bit Win 7 zbog ovoga. Imam 4 GB ram, ali 32-bitni Win 7 vidi samo 3.25 GB
Moja greska :D razumeli smo se ;)
Jac u da probam ovu iight verziju, nisam lud za HD teksturama likova... a i kako videh gameplay je sadrzan u jednom .dll fajlu :D
Pa moze neko da gaokaci ;)
A i da budem iskren ne svidja mi se u HD verziji ova Adriana Lima umesto Alyx..
Black Mesa
Nece BlackMesa skoro sudeci po svemu :(
Jel probao neko full HD mod, interesuje me hardverska zahtevnost :)
Zbog HL2 sam 2004. kupio R9800pro i upgradeo-vao makinu, ovo izgleda fenomnalno, mada Alyx izgleda cudno:(
Ja pustio DL, bice za 3h pa cu da javim kakvi su utisci.
Kako stvari stoji kad se BlackMesa konacno pojavi Source ce biti jednako zastareo kao sto je bio GoldSrc u trenutku pocetka radova na modu. U prevodu, dzabe su krecili :p
Ali ce onda imati materijala za BlackMesa HD ili Cinematic :)
@rushko: To je zato sto je model radjen po izgledu Adriane Lime :D klasican geek :D
Ali mislim da je ostavio klasican samo HighRes model klasicne Alyx :D
Ja cu tek posle utorka da probam, pa javljam jel radi
Jeli ovo standalone installer ili moze da se doda na vec innstaliran hl2 i epiyode ??? Mislim na full HD mod?
Ovo je napisao Ben Rektum:
Prestize me COLT :D
Odlični , hardverska zahtjevnost je povećana ali ništa strašno za današnjemašine . Ja sam na ATI-ju dobio uz sve namaxed - out 24x supersampling AA 60-85 FPS . Mada vise mi se sviđa OBican AA multisampling 8x i 130 - 230 FPS . Ovi su se zaista potrudili , jer igra izgleda bolje nego EP2...
