Pomagajte izludecu (2600XT)
sumanut
Video govori sve ... nepodnosljivo je!
[YOUTUBE]LGP-REYswCg[/YOUTUBE]
Ima li leka?
UPDATE:
U biosu radi normalno, kada uninstaliram drajver isto radi normalno, sa drajverima se ponasa kao na snimku, stalno dize i spusta obrtaje.
Znaci nesto je do drajvera, samo sta? Skinuo sam najnovije i instalirao, ista stvar se desava ...
BTW sad kad sam skinuo catalyst controll center i podigao cpu i mem klokove dokle moze i sve radi ... ima li neki drajver sa kojima se moze ici preko ovi klokova iz ccc?
Postoji način
Make a profile in catalyst after turning on Overdrive and make sure clock and memory settings are correct.
For Vista
Then go to the following location and open the following file for editing "C:\Users\Your Windows ID\AppData\Local\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
For XP
Then go to the following location and open the following file for editing "C:\Documents and Settings\Your Windows ID\Local Settings\Application Data\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
Now go down the page until you see the following lines in the XML file ...
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Automatic" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="23" />
Change the "Property name="FanSpeedAlgorithm" value=" from "Automatic" to "Manual"
Then change "Property name="Want" value=" from "23" to your desired fan speed.
Save the file then reload the Profile you just edited in the CCC. Done.
Zaboravih da kažem da sam probao na 3850 i radi .
Ili ja nesto ne radim kako treba ili nece ...
Znači napravi profil u ccc nađi fajl koji se zove kao tvoj profil na lokacijama gore navedenim , edituj fajl kako je opisano snimi ga i zatim otiđi u ccc i aktiviraj profil . Ako sve ovo uradiš radiće garantovano .
ATI Catalyst™ 9.10 Display Driver for Windows XP Professional/Home Edition
Ma uradio sam, treba samo dva parametra da se promene i da se aktivira profil, sve sam uradio, ali problem je i dalje tu, a i ne primecujem da se fan vrti na 60% kada stavim want na 60.
Jos jednu stvar sam primetio, meni na default want value na automatic stoji 0, a ne 23??
Probaj da falshujes bios, tipa skines sa neta za tvoju kartu neciji...mozda resi problem.
Ili sam edituj bios sa nekim od programa na techpowerup sajtu.
Vratio sam stari img wina i sve je ok ... Hvala svima na predlozima.
