sli/crossfire
Ivan985
CPU & Cooler
3770k, phanteks thcp 14 - r5 3600, esports duo 34
Matična ploča
GA-Z77X-UP4 TH - MPG B550 GAMING PLUS
RAM
2x4gb 1833mhz patriot- 2x16gb 3600mhz kingston
GPU
Asus hd7950 - Msi rtx3070 ventus 3x
Storage
120gb v300 kingston - 1tb kc3000
Zvuk
lusya dac- isk hf2010
PSU
Corsair hx850 - Antec NE850G M
Kućište
Cm stacker 830 - Antec performance ft1
Monitor
Hp x27q
Miš & tastatura
Lenovo legion - Razer DA essential
Pristup internetu
  1. Kablovski internet
Koje je najsabije napajanje potrebno za min g92 sli ili hd 48xx cross?
http://ixbtlabs.com/articles3/video/g92-6-part1.html
GeForce 9800 GTX contains two 6-pin PCI-E power connectors. The graphics card won't work, if you plug only one power cable. PSU requirements include a corresponding power capacity. A single GeForce 9800 GTX is recommended to be used with at least a 450 W power supply unit that can provide no less than 24 A along 12 V lines. What concerns SLI, you should use a 750-W PSU, 3-way SLI - 1000 W.
I gledaj da napajanje bude SLI Certified :trust:
EDIT:
Pogledao sam sta ti pise u Moja masina :smash:
http://www.techsupportforum.com/har...ort/279524-sli-8800gt-power-requirements.html
http://forums.nvidia.com/lofiversion/index.php?t53969.html
http://forums.slizone.com/lofiversion/index.php?t10214.html
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=26588805
http://www.anandtech.com/video/showdoc.aspx?i=3140&p=13
Google is your friend :trust:
