[SE K800] Fleshovanje
evo loga...
14:31:33| XS++ v3.1 (Darwin) Ready !
14:31:33| Executed on Microsoft Windows XP
14:32:31|
14:32:31| Attempting to open the interface...
14:32:31|
14:32:31| TURN OFF PHONE!
14:32:31| Hold 'C' button on phone and connect phone NOW.
14:32:31| You have 30 seconds...
14:32:31|
14:32:36| Baseband ID: 9900
14:32:36| Protocol Version: 3.1
14:32:37| Phone name detected!
14:32:37|
14:32:37| Profiling SEMC phone...
14:32:37| Platform: DB2020
14:32:37| OTP CID: 51
14:32:37| EROM CID: 52
14:32:37| EROM Color: Red
14:32:37| IMEI: 35457901xxxxxx
14:32:37| Phone ID: W830
14:32:37| Region: APAC
14:32:37| CDA: CDA102721/4 R3A
14:32:37| Firmware Version: R1KG001
14:32:37| EROM: R3A022
14:32:37| Ready for operation!
14:34:35|
14:34:35| Sending db2020_cid01_prodid_p3j.bin...
14:34:36| Applet ID: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J
14:34:36| This is a PRODUCTION_ID loader
14:34:36|
14:34:36| Sending db2020_mem_patcher_cid52_r2a006.bin...
14:34:36| Applet ID: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
14:34:36| This is a MEM_PATCHER loader
14:34:36|
14:34:36| Sending db2020_cid52red_flash_r2a005.bin...
14:34:36| Applet ID: 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
14:34:36| This is a FLASH loader
14:34:36| Now flashing firmware main...
14:34:36| Flashing c:\documents and settings\tihomir\desktop\w830_r1kg001_main_generic_ea_red52.mbn
14:34:36| Header type: BABE
14:34:37| 460 flashblocks
14:38:23| Finishing flash
14:38:23| Done flashing
14:38:23| Flashing was successful
14:38:25| Disconnected... Unplug the phone
14:38:29| Shutting down...
masamunea, po ovome je sve proslo ok :) Probaj opet flash, ali gledaj kako tece flashovanje 460 flashblokova.
joriq, moras i fs i custompack ubaciti za srpski :) main i nije toliko vazan.
Evo ti za w880, malo starija verzija, ali ima srpski :) (tebi ako treba noviji main zbog patcheva, onda samo flashujes novi main i kraj)
http://rapidshare.com/files/81724460/W880RIKG001_RED52.rar
najbitnije mi je da sam odradio debranding sa mreze "3", vodafone FW je zlatan pri ovome, ne dozvoljava da se ugasi 3g, desni softkey je "pianeta3" i jos tako neke gluposti :)
Sve je proslo ok, patchevi rade... samo jos da pronadjem neke elfove... :)
milane hvala jos jednom. :)
Nema na cemu ;)
Evo moj tutor za Elfove(ako ti trebaju noviji samo reci pa cu okaciti), postavljeni i opisani osnovni elfovi(zbog nedostatka vremena nisam radio update...)
http://www.mobilnisvet.com/forum/viewtopic.php?t=15301
SS mog k800i...
Vidi sto je predr*ano! :zgran:
Sad se kajem sto sam sje*o masku na svom K800i i sto mi bleji tamo bezveze, a furam ovaj tupavi samsung :(
@milana proradili mi i elfovi.... nego ne mogu da nateram missed events da radi kako treba, ustvari ne radi nikako (v2.06). skinuo sam ga i ubacio u zbin, a procitao sam da se konfigurise pomocu bcfg elfa, a ne preko ini fajla. skinuo sam i bcfg.elf, pokrenuo, al nista se ne desava. moze pomoc?
na mobilni svet ne mogu da se registrujem, tako da tamo ne mogu da te pitam. :)
Dorry, :p
masamunea, odlicno :)
Skini najnoviji bcgf elf pa probaj, http://perk11.info/elfse/BcfgEdit_main.elf
A stavio sam u att. najnoviji missed events ;) Takodje proveri da li si ubacio poslednji lib patch, i dyn_const, ako se ne snalazis mogu ti i to naci.
  • Missed_Events_v2.1_en.zip
    11.8 KB · Pregleda: 35
lib patch, i dyn_const sam skinuo odavde http://forums.se-nse.net/index.php?showtopic=31060&hl= valjda je to najnovija.
kad pokrenem BcfgEdit_main.elf restartuje mi se telefon, a pretpostavljam da missed events ne moze da se podesi bez bcfgedit-a ili ja to ne umem...
Cuj snalazim, pa ja sam prvi put flashovo telefon juce (3x), a patchovo i ubacio elfove sinoc. meni je sve ovo novo i konfuzno... :p
Pogledaj na moj 4shared acc(http://sedownloads.4shared.com/), sad sam updateovao libs, ubaci novi lib(prvo uklonis stari), i novi bcfg edit fajl pa onda probaj da podesis missed events.
Usput, kao i prosle godine 1.1.2008. kad je pocelo patchovanje DB2020 platforme, 1.1.2009. je pocelo patchovanje A2 platforme, skoro svih novijih SE modela, takodje i flashovanje/modovanje A2 platforme je moguce, ako nekom treba uputstvo/program za tako nesto, neka kaze.
Evo javljam se sa malim zakasnjenjem.
Prvo, Milane hvala za drivere za Vistu 64bit - RADE!Uspeo sam da lepo flashujem w810 sa fajlovima koji su bili na tvom 4shared accountu.
Ali sada mi se javlja novi problem na k660.Prilikom poziva dobijam poruku: ciphering not provided by operator.insecure transmission , i pojavljuje mi se neki znak upozorenja.
Googlovao sam po netu i vidim da dosta ljudi ima isti problem i to ne samo na k660...Ali nisam nasao resenje - nista konkretno nema.Da li si mozda cuo za ovo i znas li mozda resenje?
Hvala unapred ;)
Da cuo sam :) cak sam i video jednom na svom k800i(ali koliko imam kartica ne secam se tacno koja je bila :d), u pitanju je problem sa karticom(potrebno je uzeti novu da bi poruka nestala...)
Cak znam jednog koji je kad mu se pojavila poruka uzeo novi telefon, pa mu se pojavila i na tom novom, i tako je menjao telefone dok mu ja nisam rekao da promeni karticu :p
Zasto se desava? Iskreno, nemam pojma...
Aha znaci oko kartice je.Evo sad sam probao sa drugom, o5 isto :d
Ma dobro, nije neki veliki problem, ali zna da iritira malkice :-devil-:
Ako slucajno cujes za neko drugo resenje, javi ;)
Hvala i pozz :wave:
Imam problem sa ubacivanjem patcha, far manager mi stalno izbacuje error in line 1.
Jel ima neko nekakvu ideju?
Pa moze biti greska u patchu, ili se taj patch kaci sa nekim drugim i zato dobijas error.
Ljudi, imam SE k800i i imam problema sa fleshovanjem... da li nekako moze da se prebaci erom cid53 na neki stariji...? Da bih mogao da uradim flesh u XS++ :(
Moze :) Ali to kosta, mislim da je log oko 20e...
A jel mozes da stavis kako da napravim to sve sa tim programom, kao sto ste objasnili sa XS++?? Bio bi zahvalan :)
ewo flashujem k800i.poceo je u 2:39 ewo jos nikako da zawrsi samo je napisao sending loaders\db2020_cid01_prodid_p3j.bin i tu je stao zauzeo je procesor 100% na kompu i nista se ne desawa wec 30minuta.A program nije pukao,sta se desava?
Verzija:
Main:K800_R8BC004_MAIN_GENERIC_WI_RED52
FS:K800_R8BC004_FS_S_E_EUROPE_RED52
costum pack:HB1-06_Gen_CDA102568_3_R6A_GENERIC_S_E_EUROPE
koji je problem?
pozdrav svima!
jako mi je potrebna pomoć. radi se o sledećem. imam brendiran orangeov k800i. preko zvaničnog SE sajta sam odradio update softvera i naravno da sam dobio simlock.
trenutno imam cid53 R8BF003.
pokušavao sam da odradim neki unlock, koristio sam xs++ ali mi on ne dozvoljava iz nekog razloga da pokrenem unlock patch.
probao sam i preko FAR-a i jdflashera i stigao sam do koraka gde se uključuje telefon i pokreće executor.b.
problem je taj što kad uključim mob, upišem pin kod i dobijem "Insert correct SIM card" tako da posle ovog koraka ne mogu ništa da radim.
sve se nešto plašim da sam totalno upropastio mob i mogu da ga bacim.
ne znam više šta da radim...
Prvo, xs++ ne radi sa CID53 telefonima.
Drugo, far+jdflasher radi sa CID53, telefon se moze otkljucati samo ako imas karticu od operatera na ciju je mrezu zakljucan.
Poseti neki servis ili ako posedujes karticu neke banke sa kojom se moze placati preko interneta mozes da posetid wotanserver ili davinci i da ga otkljucas preko njih.
pozdrav svima!
Da,da , malo kesha resava tvoj problem.
pozdrav svima!
Odnesi telefon u neki servis. Za 800din tvoj problem ce biti resen.
Pozdrav!
Skroz neisplativo da otkljuca preko interneta. Bolje neka odnese u neki servis i da mu oni to urade ispravno, a nece izaci skuplje. :)
Hvala i pozz :wave:
Ako i dalje nisi resio svoj problem, javi se na PM.
Sto je neisplativo?? Cena za patch unlock je 10e, permanent unlock je 25e...
A 800din je u servisu, a to je manje od 10e. I jos ti je sigurno da ce ti otkljucati i da te nece prevariti (za sta postoji mogucnost ako se placa na nekim sumnjivim i nepoznatim sajtovima).
