Koja TV karta ?
Leadtech Winfast 2000XP
pronadje Win7 sam drajvere, ali ga zablokira jer navodno nije kompatibilan
Koja TV karta ?
All hell breaks loose when a Windows 7 Ultimate OEM DVD ISO from Lenovo been leaked and posted on Chinese forum. The ISO was quickly grabbed to retrieve boot.wim, which was then used to retrieve the OEM-SLP product key and OEM certificate for Windows 7 Ultimate
The trick is to have BIOS modded to include the SLIC 2.1. The SLIC 2.1 can be modded into BIOS physically (hardmod or biosmod) or been emulated or simulated during Windows boots up (softmod). Various SLIC 2.1 BIN has been retrieved from various notebook computer that shipped with new SLIC 2.1 in BIOS to support the free Windows 7 Upgrade Option from Windows Vista. The information can be used to mod the BIOS. If you’re not technically know-how, it’s possible to request for BIOS mod assistant, or wait for Windows 7 Loader or WoW7.
Last but not least (which makes no activation crack works properly so far) is OEM-SLP product key for Windows 7. So far no OEM-SLP product key required to activate Windows 7 as OEM offline instant activation been leaked yet as no machine has been officially ship in Windows 7 by OEM, until now.
^^ Viđao sam to i na Vista SP2 i na Win 7 RC.
Klikneš na ikonicu i pomeriš klizač za jačinu zvuka i odjednom to upozorenje nestane, pošto zvuk zapravo radi(!???!)
Tu ni meni nije htelo nego bas kad ides na Windows Update (npr iz Control Panela) onda on javi da ima update za zvucnu kartu. Ostalo, kako vidim, ti je sve isto kao i kod mene osim sto ti izgleda koristis 64bit a ja 32bit pa moguce da je tu kvaka.A kad u Device Manager idem na update driver za audio javi mi "Windows was unable to install your multimedia audio controller".
Verovatno trebas opet da pokrenes instalaciju guest addonsa kako bi instalirao drajver za drugi tip zvucne karte. Ako to ne radi onda jedino da instaliras ispocetka stim da odmah izaberes "Vista"evo slike i nista mi nije jasno zasto nece ovo je sada kao VISTA postavljeno i nece opet! hmmm help!
Verovatno trebas opet da pokrenes instalaciju guest addonsa kako bi instalirao drajver za drugi tip zvucne karte. Ako to ne radi onda jedino da instaliras ispocetka stim da odmah izaberes "Vista"A ako ni tada ne bude htelo onda uzmi instaliraj Sun-ov VirtualBox (subjetkivno deluje da je bar dva put brzi u radu sa Windows 7). A ako ni tada ne bude htelo onda je sila tvojih gremlina previse jaka
a tip koji ga je "opravio" sa samo 200 kilobajta se 'ladno "zove" Hazar. hehehe
Aj bas cu da probam, da vidim da li postoji razlika. Inace 1 pitaanjce skinuo sam sa micr. sajta win 7100, instaliao ubacio serijski,i posle mesec dana mi trazi ponovo aktivaciju? a ne prihvata monaj kljuc
da li je ta hazarova varijanta trajan nacin, ili moze da se desi nesto nezeljeno posle odredjenog vremena ili posle nekog update-a? ,)
