Ati Catalyst 9.7
  • Začetnik teme Začetnik teme spaad
spaad
Malo novog stajlinga.,)
Vista WHQL http://www.megaupload.com/?d=COO6B3QC
XP WHQL http://www.megaupload.com/?d=L8AIWSOP
:wave:
XP x86?
Koliko vidim "u paketu" bi trebalo da su obe verzije za xp, 32 i 64bit... Dosta su teski:zgran:
Ima li 9.7 mobility?
ovo je jos uvek beta verzija.Bice...
:laugh: Zanimljivo :laugh:
ATI Catalyst 9.7 WHQL Windows 7 | Vista 32-bit
ATI Catalyst™ 9.7 – AMD’s first official unified Windows7 / Windows Vista Microsoft WHQL certified graphics driver for the Windows 7 RTM
AMD has delivered its first official unified WHQL certified graphics driver designed for the Windows 7 RTM (Release To Manufacturing)
* ATI Catalyst™ 9.7 delivers a superior Windows 7 experience:
* Great gaming performance – superior performance compared to Windows Vista for single GPU configurations and ATI CrossFireX™ configurations
* Stability – through AMD’s WHQL certified, unified Windows 7 / Windows Vista graphics driver
* Leadership in Innovation – support for all the Windows 7 WDDM 1.1 features and AMD ATI Catalyst features on the ATI Radeon HD 4000 Series, ATI Radeon HD 3000 Series, and ATI Radeon HD 2000 Series of products
ATI Catalyst™ Control Center Updates
The ATI Catalyst™ Control Center now features:
* A newly designed Desktops & Displays Manager - enabling users to more quickly configure and arrange their displays
* Full support for HydraVision under Windows 7
* The new ATI Catalyst™ Control Center is supported under Windows 7 and Windows Vista
ATI Video encoder update – support for Windows 7
* ATI Catalyst™ 9.7 introduces support for the ATI Video converter under Windows 7 32-bit and Windows 7 64-bit
* Using ATI Stream technology, owners of ATI Radeon™ HD 4800 Series and ATI Radeon™ HD 4600 Series of graphics cards can take advantage of this video conversion tool (found in ATI Catalyst™ Control Center Basic View) to achieve substantial performance improvements when transcoding video files
Performance Improvements
Catalyst™ 9.7 brings performance benefits in several cases where framerates are CPUlimited. Some measured examples are:
* Crysis - performance at very high quality preset increases by up to 8% on HD4800 series products
* Lost Planet Colonies - performance increases by 7-11% when 8x Anti-Aliasing is used on the HD4800 series products
Kod:
http://downloads.guru3d.com/downloadget.php?id=2333&file=4&evp=cbb133e5c29e07ac6ca0a8978d1f8ce6
ATI Catalyst 9.7 WHQL Windows 7 | Vista 64-bit
Kod:
http://downloads.guru3d.com/downloadget.php?id=2332&file=4&evp=bcadfbe206921fe1b6878e3339b809d1
Ja sam imao problema da instaliram drajver na W7 RC 7100 64bit. Nisam siguran u čemu je tačno problem, možda je ovo posebno pravljeno za RTM, nisam siguran.
Napokon resen problem sa selektovanjem velike scene u Sketch Up-u
3D model (88 mb) na ati 3200 okrecem brze i tecnije nego na nvidia 9600 gt
@dejan.nikolic69
E kume, doceka ti i taj dan, iako si prestao da se nadas 🙂
