GPU Voltage Tuner
  • Začetnik teme Začetnik teme OCz
OCz
VIP član
Novi tool pa da objavimo i ovde:
Kod:
GPU Voltage Tuner v1.2
by AgentGOD
Home Page: http://www.ultimate-filez.com  http://www.epichardware.com
Donation : http://www.ultimate-filez.com/?page=donate
Description:
	This program allows easy GPU voltage adjustments on GPUs with volte
	rra-based voltage regulators and it uses the award-winning and criti
	cally acclaimed RivaTuner for these adjustments.
	WARNING! By using this program, you agree that the author is NOT
	responsible for ANY consequences as a result of using this program.
	You, the user, are liable for any damages occured. Be a smart overc
	locker and monitor those temperatures and voltage levels!
Compatibility:
	Most GT200 GPUs are supported, some G92 GPUs, and all RV770/790 GPUs
	above 4870, and several custom PCB boards. If you aren't sure, just
	try it and see if it works ;)
	Tested on: Visiontek Radeon HD 4870 X2, BFG GeForce GTX 295,
		   SAPPHIRE Radeon HD 4870 X2, ATI Radeon HD 4890,
		   ASUS EAH4870 X2 Tri-Fan, and more!
Requirements:
	- RivaTuner (v2.24 is the minimum version)
	- A compatible GPU with volterra-based voltage regulators
	- Latest GPU drivers
	- A modern Windows-NT based operating system (XP and above). Both x86 and x64 are supported.
	- Microsoft(R) Visual C++ 2008 Runtime (x86), can be found here:
  	  http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf
 	- Microsoft(R) .NET Framework v2.0 (minimum), can be found here:
  	  http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5
Instructions:
	First, you need to put the full path to RivaTuner in RivaPath.txt (with a
	trailing backslash [\]).
	I designed this program with automation in mind, so most settings should
	already be correct. But if they aren't you can correct them. For example,
	in the GPU Information section, if the selected voltage is not the "3D"
	performance voltage, please select the correct one. You can change the
	"Current GPU #" drop-down to anything you want, it's for your information.
	What you set under "GPU Voltage Tuning" for "Number of GPUs" will affect
	which GPUs' voltages get set. Again, it should be automatically detected.
	Voltages available range from 0.8625v to 1.6000v, so be careful what you set!
	If all of the voltage VIDs are displayed as "0xff", then you selected a
	non-existant GPU under "Current GPU #".
	* Note: Do not have RivaTuner running prior to running GPU Voltage Tuner, it
	  will refuse to work properly.
	* Also, if you are unsure whether the automatically detected and selected vo
	  ltage is correct, you can check by loading up a full-screen game with GPU-Z
	  or RivaTuner logging the GPU voltage in the background. If it is incorrect,
	  simply select the correct load voltage.
	* If you wish to set voltages higher than 1.45v, you'll need to unlock higher
	  voltages through the Advanced Settings menu by right-clicking the voltage
	  drop-down.
Credits:
AgentGOD    - coding this program, duh :D
Unwinder    - for RivaTuner, excellent GPU tweaking program
justageek95 - for originally exposing the ability to set voltages
3oh6	    - for writing an excellent in-depth guide on voltage setting
tommyk2005  - for testing on BFG GeForce GTX 295 :)
Screenshot:
XS forum tema
Download
@va milos: Pitanje je koje sve tacno kartice spadaju pod "all RV770/790 GPUs above 4870", mozda i ne radi na 4830...
pa treba lo bi da su podrzane sve RV770, a u to spadaju i 4830,4850. Gledam sad forum sa linka, i dosta ljudi ne moze da pokrene, tj izbacuje im istu gresku.
Sta znaci ovo 15h,16h,17h,18h?
To su VID registri, ne razumem ni ja a nije ni bitno. Tamo gde pise GPU Voltage Tuning pa Voltage, tu odaberes koliko zelis. Samo pazljivo da ne preteras, vidi prvo kolika ti je fabricka voltaza.
Ovo ne radi kod mene. Izbacuje mi gresku non-stop.
Pise above 4870, pretpostavljam da onda 4830 nije podrzan ..
Inace obavezno procitajte requirements i instructions ..
Radi na 4870 🙂
Samo nigde na netu ne mogu da nadjem default/max voltaze za moju GA 4870.
Na programu stoji 1.3v...
A ovo sto mi stoji 18h ne bi trebao da diram...te VID registre? 😀
Edit: Testirao sam malo na 1.350v na 820/1000 mhz i prosao je 3dmark. Sad isprobavam undervolting. 1.1750v na 750/900 mhz.
Dobar programcic. Temp. graficke u idle mi je sad 42 stepena na sobnih 25 stepeni, sa otvorenim kucistem, posto imam neko shnj kuciste.
Evo temp posle igranja gta 4:
@doggmania, skoro je sigurno da joj je onda tih 1.3v def. napon. Kod mene je "stiklirano" na 1.1875v sto je mojoj karti def. napon.
Znaci, ono sto je odma i obelezeno, to je i default 😀
Koja je verovatnoca da se ovim programom sprzi graficka usled povecanog napona?
Ne bi trebalo da bude nikakvih problema dokle god se ne preteruje. Malo cu dati sebi za pravo da kazem neku slobodnu procenu a neka to bude nekih ~1.45v. Znaci, ne bi trebalo ici preko toga sa stock hladjenjem. Za te 4870 pretpostavljam 1.35-1.4v za 24/7. Ne vise od toga.
Meni prepoznaje prethodnu kartu 3800 seriju, a imam 4870 sa 1Gb?
Program sam stavio u Riva Tuner-ov folder jer se drugacije nije mogao pokrenuti.
A 2.24 Rivu sam juce instalirao, na 4870 grafi.
Sa HWMonitor programom se takodje vidi def.voltaza GPU procesora.
Cisto za orijentaciju.
Znaci ovaj program nece da radi na HD4850?
Ja sam gruvao na 1.3750 moju 4870...Nije joj nista bilo. Temp su normalne...bar u 3d marku.
@filipos pa nije napon taj koji ubija graficku...temperatura je ta koja je ubije 😀
A kad krene da se pregreva onda trottluje/zabode da ti se ne bi pregrejala.
Na 3d marku 06 kad povecam sa 750/900 na 820/1000 mhz dobijem oko 5% bolji skor za graficku, to je po meni malo 😀
