ASUS MARS GTX295
  • Začetnik teme Začetnik teme nex999
Nije prvi put da rade ovako nešto.
Da li se neko seća EN7800GT DUAL/2DHTV/512M?
http://www.asus.com/product.aspx?P_ID=xIQ0you2gqLJE7ix&templete=2
http://www.hexus.net/content/item.php?item=3654
U svakom slučaju, podržavam entuzijazam ASUS-a!
Nije mi jasno zasto samo 1000 komada,mislim da bi za ovo moglo da se skupi 10000 kupaca u svetu 🙂
Ja recimo od GT300 ocekujem da bude barem brzi od ovog Marsa 🙂
bez obzira sto ce biti dx11 karte gtx mars ce biti brzi od gtx300 bar neke prve serije...mislim ko npr gtx360...moje misljenje
I ja mislim da ce GT300 biti brzi od ovog Marsa.
Zivi bili pa videli
Ja se secam... A kako je zaboraviti pored ovog eksternog adaptera za napajanje?:smoke:
Asus' 4GB Mars dual-GPU card up for pre-order, costs an arm, half a leg
If money is no problem then we, or better yet, Asus, has one more thing you can spend it on - the limited edition Mars graphics card which boasts no less than 4GB of GDDR3 memory, and two GT200 GPUs summing up to 480 Processing Cores, all one one PCB.
Seen below, the dual-GPU MARS/2DI/4GD3 has a 2x512-bit memory interface, features GPU, shader, and memory clocks of 648, 1476 and 2484 MHz, respectively, and is now available for pre-order at UK's Scan with a price tag of (brace yourself):
£1,030.98 or about $1,680 / 1,218 Euro. Any takers?
Izvor: TechConnect
:guitar:
Mo's Yuga da pazaris i za 200 evra... :d:d
Znao sam da su ovi bolesnici u Asusu nenormalni,ali ovakvo sta prevazilazi i moja ocekivanja.Ajde cak i ako uzmemo u obzir da dvije gtx285 kostaju 700 eura,otkud im racunica od 1200 E? Cestitam
exkluziva 😉 2x285 moze svako da kupi ko ima pare ali ovo bas i ne.
Upravo 😉
