Alpha Protocol
Hitman 47
Published by: SEGA
Developed by: Obsidian Entertainment
Release Date: Q3 2009
Genre: Action RPG
Platforms: Playstation 3,Xbox 360,PC
Alpha Protocol is an upcoming third-person action role-playing game, developed by Obsidian Entertainment and published by SEGA. The game revolves around the adventures of rookie CIA field agent Michael Thorton.
After a mission goes awry, Michael Thorton is cut off from all of his contacts and betrayed by his superiors and is being hunted by the United States government. In response, Michael uses the eponymous "Alpha Protocol", though it is normally reserved for more senior agents, and begins to operate undercover, to uncover the conspiracy.
Alpha Protocol is played from a third-person perspective, allowing the player to see Thorton and his surroundings at all times. As Thorton is a trained CIA operative, the tools at the player's disposal include numerous firearms, hand to hand combat using American Kenpo,[2] and spy gadgets.
In addition to the action elements, though, players also earn Advancement Points, which can be placed into any of the ten different skills in the game.[3] These skills will increase Thorton's ability to use certain weapons and grant different abilities to him. These abilities are free to use, but require a "cooldown" period before they can be used again. One ability that has been mentioned in previews allows Thorton to scan a group of enemies in slow-motion before popping out of cover and shooting each of them more rapidly than he would be capable of normally.[3]
The player can choose which skills to advance, allowing them to reinforce their play style. Examples include making Thorton more capable of stealth, more deadly in hand-to-hand combat, or better at gunplay.[3]
As with any RPG, Alpha Protocol features numerous characters to interact with. Conversations occur in real-time.[4] The dialog system in the game allows the player to choose from three different attitudes when speaking to an NPC. Obsidian has said that these options are based on the personalities of the "three J.B.'s": Jason Bourne of the Bourne Identity novels and films, James Bond of the eponymous film and book series, and Jack Bauer of the television series 24, although the game itself does not use these names. During dialog sequences, the player will be able to choose from options like "professional" (Jason Bourne), "suave" (James Bond), and "aggressive" (Jack Bauer).[3] Each NPC will react differently to these choices; one character might be intimidated by an aggressive stance, but another character may find an aggressive stance to be insulting or childish. The consequences of choices made during conversations may not be seen until much later in game.[5] As each conversation is experienced once per game, multiple playthroughs will be required in order to experience all of the game's content.
IGN PREVIEW 1
IGN PREVIEW 2
[YOUTUBE]<object width="480" height="295"><param name="movie" value="http://www.youtube.com/v/2_IW-XhSynM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2_IW-XhSynM&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="295"></embed></object>[/YOUTUBE]
Screenshotovi:
igra deluje zanimljivo,ali iz screenshotova, mogu samo reci: " koliko je MGS4 bolji u grafici, ajaaaooooo"
ma kakva grafika, važan je gameplay, zašto ljudi još igraju counter, zbog pixel-shadera?
Samo ne znam kako će da bude RPG TPS, nikad nisam igrao ništa slično.
Nisi igrao Mass Effect?
Ova igra verovatno nece imati ni R od RPG-a. Bice ovo klasicna GoW pucacina sa kao nekom spijunskom pricom koja je tu tek onako. 🙂
mene recimo mnogo podseća na bourne-a, po screenshot-ovima
Nisam igrao Mass Effect, moram da ga nabavim, znam da je odlična igra, ali sad igram Fallout 3 pa mi je dovoljan jedan RPG odjedared.
Pojavio se novi trailer.
Deluje mi zanimljivo,nadam se da ce akcioni i rpg elementi biti dobro izbalansirani...
Sad odgledah video.
Jel ovo za ps2 ili za next gen?Ako je za next gen,onda je jako lose(mislim na grafiku)
Prvo je bilo price da ce izaci samo za PC...ali next-gen.....ima i boljih igara od owe.....widecemo...........time will tell 🙂
Grafika i nije nesto, ali deluje da ce igra biti zanimljiva.
Slezem se da je grafika (ispod)prosecna za danasnje standarde,ali mi sam gameplay deluje vrlo obecavajuce.
Inace,igra je dobila zvanican realese date,u pitanju je oktobar ove godine.
Da se ja pitam svaka akciona igra bi izgledala ovako, prosto je neverovatno kako je vecini ljudi dovoljno da pucaju kao blesavi, nemaju mogucnost izbora ni u jednom trenutku i budu zadovoljni.
Slazem se u potpunosti,jednostavno obozavam kada u nekoj igri imate mogucnost izbora,ali ne volim kad se taj izbor svodi na crno-belo,vec volim kada postoji vise nijansi moralnih odluka koje donosite.
Sad se zna zasto je graficki ispod proseka.Ispeglace oni to do oktobra🙂
Sumnjam da ce igra izgledati drasticno bolje u oktobru,ali grafika u ovoj igri(a,i generalno) mi predstavlja potpuno sekundarni element,na koji ne obracam puno paznje.
zanimljivo skroz deluje
jel ovo rade oni sto su radili KOTOR 2 ?
sad sam video da jesu !
ova igra ce da izuva sigurno !
KOTOR 2 je neverovatna igra ! prodao bi gumeni bubreg za KOTOR 3 !
ova igra ce mozda biti shajze, ali bar deluje zanimljivije od onog prototipa..
Chris Avellone je sve rekao o sebi kada su ga pitali za FO3 i Troiku. Najobičniji vodonoša 🙂
"Deus Ex had some influence"
"In Alpha Protocol, you can get through the game without killing anyone"
"Also, there's a tracker in Alpha Protocol - as much as you can do research on the various NPCs in the game, they'll also do a lot of research on you."
Obecava.
Ovo je RPG isto koliko i Mass Effect 2. Nekima je to dovoljno da igru nazovu legendarnom a nekima je to dovoljno da uopšte ne probaju igru 😉
Nego jel ono Dennis Rodman na 00:21?
