Necrovision
Ma treba na kraju drugog chaptera da otvorim neka gvozdena vrata, jel zna neko kako ?
ne znam tacno koja vrata..nisi bas opisao dovoljno.....ali se sve vrata otvaraju ili razvaljuju oruzjem....i nema mnogo mozganja samo napred.....
Nasao sam resenje na youtube, trebalo je okrenuti neku rucicu na nekom zabacenom zidu.
Jel zna neko kako se iskljuchuje blur?? (ne mislim na motion blur) A i antialiasing uopste ne radi vec je samo blurovana slika.. :/
igra je super...upravo sam poceo da je igram...graficki lepo odradjena...i prilicno realisticno kretanje i pucanje...:wave:
NecroVisioN v1.1 Patch (22.66MB)
List of changes:
- rendering performance improved, especially for higher settings of dynamic shadows and ambient occlusion
- level loading times shortened as well as quick-save loading times
- playing online between users having different language editions is possible (Russian edition was incompatible with other versions)
- "Man of Courage" (Normal) difficulty level more balanced (easier)
- gas mask now works properly in Necromancer's Return mode and in Stronghold level
- possibility of crash after saving in paticular area in Trench Warfare level fixed
- minor menu options placement corrections
- problem with possible shotgun jamming while using 'Pure fatality' combo fixed
- bug, preventing player from placing Geballte ladung by the door in The Hill level, after loading the game, fixed
- possibility of crash after skipping the cutscene with the dragon on The Hill level in Necromancer's Return mode fixed
- minor formatting bugs and inconsistencies in the dialogues, grammar mistakes and single overlapings inside menus and cutscenes corrected
- added support for no-driver 16:9 format screens (thanks Sebastien "ztorm" Essel for help)
!! IMPORTANT !!
*** This patch works for all versions of the game with exception of special German (non-violent) edition and Czech and Russian editions ***
http://www.gamershell.com/download_41898.shtml
Igra buraz ovu igru i zaglavio na 4 chapteru,pa mi trebala mala pomoc.
U nekoj pecini kad prolazi kroz nju ima nekih otrovnih gasova i naravno treba stavti masku,ali kad stisne masku ona traje sekund ili 2 i onda nestane,ali drugacije nije uspeo da predje.Izgine posle nekoliko sekundi bez te maske.
Potrebna pomoc
zaglavio sam u 4 chapteru kad se silazi u onaj podrum pun gasa a nema gas maske dole su neka burad kad se upuca ventil ide neka tecnost . Krenem sa punim zivotom ali nije dovoljno sta dalje dosadilo mi je vise pokusavati
Nisam imao vise zivaca pa sam obrisao igru! (radi se o istom problemu i na istom mestu)
Ne mogu da verujem da sam za ovo dao 400rsd, bolje da sam ih bacio u Dunav
