monteboy
DFI LANparty DK 790FXB-M3H5
CPU
AMD® Phenom™ II processor
HyperTransport 3.0 (5200MT/s) HyperTransport 1.0 (2000/1600MT/s)
AMD OverDrive provides tuning options using the new “Advanced Clock Calibration” overclocking feature.
Socket 938 AM3 45nm
CPU Socket
Socket AM3
Chipset
AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB750
System Memory
Four 240-pin DDR3 DIMM sockets
Supports DDR3 1600(O.C.)/1333/1066 MHz
Delivers up to 21Gb/s bandwidth at 1333MHz
Supports dual channel (128-bit wide) memory interface
Supports non-ECC unbuffered DIMMs
Supports up to 16GB system memory Windows® 32-bit operating system is unable to accurately detect more than 4GB system memory. Therefore, if you are using this operating system, we strongly recommend that you install a less than 3GB system memory.
Expansion Slots
3 PCI Express (Gen 2) x16 slots - 2-way CrossFire at x16/x16 or x16/x4 bandwidth - 3-way CrossFire at x16/x16/x4 bandwidth
3 PCI slots
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM overclocking
CPU/DRAM/Chipset overvoltage
8Mbit SPI flash memory
Audio
Realtek ALC885 8-channel HD Audio Codec
High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN
Marvell 88E8056 PCIE Gigabit LAN controller
Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Serial ATA with RAID
Supports up to 6 SATA devices
SATA speed up to 3Gb/s
RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE
One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports
1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
1 optical S/PDIF-out port
1 coaxial RCA S/PDIF-out port
6 USB 2.0/1.1 ports
1 RJ45 LAN port
Center/subwoofer, rear R/L and side R/L jacks
Line-in, line-out (front R/L) and mic-in jacks
I/O Connectors
3 connectors for 6 additional external USB 2.0 ports
1 connector for an external COM port
1 front audio connector
1 CD-in connector
1 IrDA connector
1 CIR connector
6 Serial ATA connectors
1 40-pin IDE connector
1 floppy connector
1 24-pin ATX power connector
1 8-pin 12V power connector
2 4-pin 5V/12V power connectors (FDD type)
1 front panel connector
6 fan connectors
1 diagnostic LED
EZ touch switches (power switch and reset switch)
Power Management
ACPI and OS Directed Power Management
ACPI STR (Suspend to RAM) function
Wake-On-PS/2 Keyboard/Mouse
Wake-On-USB Keyboard/Mouse
Wake-On-Ring
Wake-On-LAN
RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system/chipset temperature
Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
Monitors the speed of the cooling fans
CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
ATX form factor
24.5cm (9.64") x 30.5cm (12")
Bios
http://img.lanparty.tw/Upload/BIOS/CM/D7SD306.zip
Dfi nastavlja svoju uspesnu pricu sa poznatom FXB serijom ali ovaj put za AM3 socket i podrsku za DDR3 memoriju sto ce verujem posebno obradovati korisnike Phenom II 720 Black Edition procesora.
Design se mnogo ne razlikuje od AM2 izvedbe stim predspostavljam da ce i ovaj model biti kvalitetan i pogodan za overclock sto je inacne tipicna karakteristika kad govorimo o DFI'u kao firmi
CPU
Socket 938 AM3 45nm
CPU Socket
Socket AM3
Chipset
System Memory
Expansion Slots
3 PCI slots
BIOS
Award BIOS
CMOS Reloaded
Audio
LAN
IDE
6 USB 2.0/1.1 ports
1 RJ45 LAN port
I/O Connectors
1 CD-in connector
1 IrDA connector
1 CIR connector
1 floppy connector
6 fan connectors
1 diagnostic LED
Power Management
Wake-On-Ring
Wake-On-LAN
Hardware Monitor
PCB
ATX form factor
Bios
