jozza
Zanima me koji bi procesor mogao da "sedne" umesto ubogog Celerona 520 (FSB 533MHz, 1,6GHz core clock)? Plocha je sa 945GM chipsetom, pa kontam da bi mogao bilo koji Core2Duo sa FSB-om od 667MHz. E sad, sve ovo je teoretski OK, ali Everest mi prijavljuje pod CPUID da je u pitanju socket 479, a negde na netu sam prochitao da se ti procesori teshko menjaju??? Jel zalemljen za plochu ili shta??? :wall: Evo i citat: If you've got a Core Duo notebook with a PGA Socket-M interface, all you should need is a BIOS update and a Core 2 Duo CPU to upgrade your notebook. If you've got a BGA CPU, then you're unfortunately out of luck as desoldering 479 balls from your motherboard without damaging it isn't for the faint of heart. Lap je FJS Amilo Li 1818, i vec me je smorio ovaj Celeron. 😡
