GeForce Forceware 182.06 WHQL
Zarkusi
Pristup internetu
  1. Kablovski internet
XP 32bit
XP 64bit
Vista 32bit
Vista 64bit
Windows Server 2003 x64
New in Release 182.06:
Recommended for the best experience in F.E.A.R. 2: Project Origin.
Boosts performance in several 3D applications. The following are examples of improvements measured with Release 182.06 WHQL drivers vs. Release 181.22 WHQL drivers (results will vary depending on your GPU, system configuration, and game settings):
Up to 8% performance increase in Fallout 3 at high resolution and AA.
Up to 10% performance increase in F.E.A.R. 2: Project Origin.
Up to 9% performance increase in Half-Life 2 at high resolution with AA.
Up to 11% performance increase in Left 4 Dead at high resolution with AA.
Up to 10% performance increase in Race Driver: GRID at high resolution and AA.
Includes full support for OpenGL 3.0 on GeForce 8-series, 9-series, and 200-series GPUs.
Automatically installs the new PhysX System Software version 9.09.0203.
Additional information on specific bug fixes can be found in the release documentation notes.
Existing Support:
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel X58-based motherboards.
Supports NVIDIA SLI Multi-monitor support, giving you the ability to use two monitors with your GeForce graphics cards in SLI mode. Learn more here.
Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory.
Supports GeForce Plus Power Pack #2. Download these free PhysX and CUDA applications now!
Supports CUDA.
Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
Cards supported:
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 260
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT
GeForce 9600 GS
GeForce 9600 GSO
GeForce 9500 GT
GeForce 9500 GS
GeForce 9400 GT
GeForce 9400
GeForce 9300 GS
GeForce 9300 GE
GeForce 9300
GeForce 9200
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS 512
GeForce 8800 GTS
GeForce 8800 GT
GeForce 8800 GS
GeForce 8600 GTS
GeForce 8600 GT
GeForce 8600 GS
GeForce 8500 GT
GeForce 8400 SE
GeForce 8400 GS
GeForce 8400
GeForce 8300 GS
GeForce 8300
GeForce 8200
GeForce 8100 / nForce 720a
GeForce 7950 GX2
GeForce 7950 GT
GeForce 7900 GTX
GeForce 7900 GT/GTO
GeForce 7900 GS
GeForce 7800 SLI
GeForce 7800 GTX
GeForce 7800 GT GeForce 7800 GS
GeForce 7650 GS
GeForce 7600 GT
GeForce 7600 GS
GeForce 7600 LE
GeForce 7500 LE
GeForce 7350 LE
GeForce 7300 SE
GeForce 7300 LE
GeForce 7300 GT
GeForce 7300 GS
GeForce 7200 GS
GeForce 7100 GS
GeForce 7150 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 620i
GeForce 7050 / NVIDIA nForce 630i
GeForce 7050 / NVIDIA nForce 610i
GeForce 7050 PV / NVIDIA nForce 630a
GeForce 7025 / NVIDIA nForce 630a
GeForce 6800 XT
GeForce 6800 XE
GeForce 6800 Ultra
GeForce 6800 Series GPU
GeForce 6800 LE
GeForce 6800 GT
GeForce 6800 GS/XT
GeForce 6800 GS
GeForce 6800
GeForce 6700 XL
GeForce 6610 XL
GeForce 6600 VE
GeForce 6600 LE
GeForce 6600 GT
GeForce 6600
GeForce 6500
GeForce 6250
GeForce 6200SE TurboCache™
GeForce 6200 TurboCache™
GeForce 6200 LE
GeForce 6200 A-LE
GeForce 6200
GeForce 6150SE nForce 430
GeForce 6150 LE
GeForce 6150
GeForce 6100 nForce 420
GeForce 6100 nForce 405
GeForce 6100 nForce 400
GeForce 6100
...Osim Photoshop CS4 akceleracije...i to u 64bit.Ps 32bit akceleracija radi.Drajveri identicni prethodnoj beti.Iako postoji taj peh sa Ps-om, drajveri su OK.
Jel se dobija neko poboljsanje u odnosu na 182.05?
Pošto sam nedavno sa ATI-ja prešao na nVidiju zanima me koji je najbolji i najpravilniji način instalacije novih drajvera nakon što izađu (sad imam 181.22), da li prethodno deinstaliram stare, i na koji način, sa njihovim uninstalerom ili na neki drugi način, možda nekim programom koji ih detaljnije obriše? Ili samo preko starih pokrenem instalaciju novih? Sad gledam u Add/Remove, stoji mi da nVidia drivers zauzimaju čak 955 MB (!), a nVidia PhysX 121 MB.
I zna li neko da li su ovi novi 182.06 riješili onaj problem da clockovi ostanu stalno u 3D režimu (max clockovi) za one koji imaju dva monitora, bez vraćanja na 2D clockove?
Samo pretumbas, nije ovo ati.
edit: nisu resili kolko znam.
edit1: kod mene na visti 64 zauzimaju nesto malo manje od 4GB 😀 to mora da je nesto sabrano sa jos nekim delovima OS-a ili ko zna sta...
Moja procedura je sledeca :
Add/remove starih drajvera > reset > install nove verzije > podesim par custom rezolucija po potrebi > enjoy ,)
Znači nema potrebe za programima tipa Driver Cleaner i Driver Sweeper kojima se nakon Add/Remove dodatno čisti iz Safe Moda?
I pretpostavljam da je ista procedura ako hoću da downgrade-ujem drajvere, da probam neku stariju verziju.
Ma, samo pregazi postojeće sa novim.
Pa, ako zelis da budes potpuno siguran da ne bude posle "nece da se instalira", neke anomalije, nema CP-a ili cak dva CP-a (nekima se i to desavalo), onda Driver Sweeper 🙂 S tim da se ide i sa AGEIA cekiranim, sa ovim novijim drajverima koji sadrze physx.
Your choice😛
Ma samo setup, kakvi bre uninstal instal, pa sta mislite sto se komp 2 puta mora restartovati posle pokretanja setupa?!
Ma nema potrebe za tim.. samo setup.exe i next/yes...
Dva puta resetuje kada se pokrene setup novih drajvera bez da se prije toga deinstaliraju stari? Onda sam setup možda prvo sam deinstalira stare, nisam probao ali sam mislio da bi bilo lijepo da su to tako napravili.
upravo to i radi, kod mene samo jedan restart do duse, ali pretpostavljam da ga zato i trazi.
Da ne otvaram novu temu, da li je normalno da grafička diže taktove kod gledanja filmova ili bi i tu trebala biti u 2D.
Sto se tice igara nisam proveravao ali ako ikoga zanima posto vidim da se mnogi odjednom gade na 3dmark05-06, sa novim drajverima kapiram da sam izvukao maksimum, i do sada sam ostvario najbolje rezove i stabilne klokove.3dmark05- 25505, 3dmark06-16464 :wave:
ovo je pod XP-om pretpostavljam?
elem, ja sam u odnosnu na prethodne WHQL dobio 300 markova u '06, kriza ratnoglava radi za 0.5fps (avg) bolje.
Vista x64.
pa da, pod Vistom je kod mene skor za 2000 markova manji :d (16800 sada sa ovim drajverima, u XP-u je bio 18500 sa starijim nekim)
Vista x64.
Koji su ti bili prethodni drajveri? Na onom testu je poredjenje sa 181.22 ,doduse koristili su 9600GT,pa je pitanje da li ce na drugim karticama biti dobitka.
A kakav ti je u Visti bio sa prethodnim u odnusu na ove nove? Ja sam još na XP-u i ne znam kako (nove) igre rade na njoj u odnosu na XP, i da li ima razlike u performansama između x32 i x64 Viste u igrama.
Kad testirate u 3dmark06 sa kojim podešavanjiima testirate? Ja sam ga sad instalirao, po defaultu vidim da mu nisu uključeni oni Feature i Batch Size testovi. Pošto vidm da poredite rezultate (ne samo za sebe nego i često sa drugima na forumu) pa kontam da morate svi raditi sa istim podešavanjima da bi poređenje imalo smisla 🙂. Na koliko stavite antialiasing?
Meni je sad defaultni test bez AA (što je isto po defaultu) dao 14626, na 1920x1200, sa 181.22 drajverima.
Vista x64.
Wooow ... covece! Zasto ne bi smo svi izma presli na nove drivere...
Pa perfomanse su kao da ste uzeli novu karticu najnovije generacije 😛
Sve ostavish na default i pokrenesh test. U krajnjem sluchaju imash topike pa mozhesh pogledati screenshot svakoga pa cjesh videti na kojim se podeshavanjima vrte testovi.
Ili ja greshim ili...
@DAS:
mislim da su bili bas ti WHQL .22
@Vader:
bio je ~16500.
Testiranje u 3Dmark, ukoliko nije drugacije naglaseno, uvek podrazumeva default. Dakle upalis i kliknes "run" 😉
@Markomaniax:
Mozda je razlika veca na nekim drugim modelima karti?! Probaj kod sebe! Na onom testu su dobili prilican boost u nekim igrama :wave:
Pretpostavio sam 🙂
Osim možda da se rezolucija stavi za sistemsku...ili ne? Default mu je 1280x1024 a pošto ja radim i igram na 1920x1200 stavio sam mu tu i dobio sam 14626. Mada pretpostavaljam da i rezoluciju treba ostavitii na defaultu da bi jedni sa drugima tačnije upoređivali, tako dobijem 15123, nije neka razlika između 12x10 i 19x12 rezolucije, čudno, gledao sam i razultate pojedinačnih testova, male su razlike.
Onaj CPU test ide jako sporo, dobijem 1.505 i 2.2220 fps. Jel' to OK?
default :smash: 😉
edit:
da, taj cpu test ide jako sporo, to je normlano.
Ajd cas samo neko da kaze koji je postupak zamene nvidia kartice za nvidiu...znaci samo softverski me zanima...prvo obrisem drajvere, izvadim staru, stavim novu, instaliram najnovije drajvere, ili one sa cda nove grafe? Pa posle najnovije?
