Microsoft Flight Simulator is dead
Jera
Počelo je otpuštanje 5000 ljudi (1400 odmah) u Microsoftu i među njima je otpušten ceo ACES Studio tim koji je bio zadužen za Microsoft Flight Simulator. Tako se završava razvoj najstarije (izašla 1982) i sigurno najuspešnije Microsoft-ove igre.
Tužan dan za flight simm-ere
Ekonomska kriza. Ali mozda nije kraj. Sad oni mogu da zasukaju rukave, urade jednu igru kako najbolje znaju i umeju i pod okriljem nekog drugog izdavaca izbace hit. Samo se nadam da to nece biti EA :p
Teško da će biti nastavka, od 100-tinak ljudi iz tima ostalo je samo 6 da arhiviraju kod i da ispune neke ugovorene obaveze. Kada se ceo tim razbeži po celom svetu tu nema više sakupljanja ekipe ni kada kriza prođe...
Najgore od svega je što je za sledeću verziju (FSXI) engine trebalo da bude napisan ispočetka da bi bio optimizovan za multicore okruženje, a ovako ostajemo sa FSX-om koji nikada neće raditi kako treba na max podešavanjima osim ako procesori ne dostignu bar 10-tak GHz jer ovaj engine opterećuje praktično samo jedno jezgro.
Или Амд не направи онај процесор што може да споји сва језгра у једно :D
Evo još malo detalja od čoveka koji razvija dodatke za FSX i ima jake veze u Microsoft-u:
The bottom line is Vista did not take off as they expected. The OEM was not much of a problem to influence home users to try and go with it but business/corps where the real money is would not touch or switch to it like they did with XP. This of course has progressed to the current path of change it, add some features to it, facelift it and most important 'rename it' job currently in production, with hopes it will then be accepted.
The economy going to mud was a catalyst but the bottom line is the layoffs probably would not have come, or at least not on the scale they are at MS had Vista actually been a success like XP.
So now they are in survival mode till the storm clears.
Zune remains because they are not going to lose their comp against Apple and Search has priority in projects because they are not willing to fall back to Google who is also now under the economic pressure as well. Those two have priority over a lot of other areas. I know how important Search is as I did some work with that a few years back and they were really gearing up at that time to go after Google.
So it is what it is. If W7 flubs, it’s probably not going to be pretty. If they can convince the market W7 is not Vista and can get the OS into places Vista would not go then they can probably pull out of the slump if they are careful and the economy does not crash.
They have not given up anything in the way of projects however they are not going to commit to anything at this point either. The news releases are there to help calm the storm but the bottom line is they really do not know what they are going to do.. this is a wait and see situation and a lot of it rests on upcoming product which has priority.
Znači, od uspeha Windows 7 i ishoda ekonomske krize zavisi dalja sudbina Microsoft-a
Sami su krivi. Prošli su kako su prošli zbog svoje arogancije. Mislili su da će tržiste da proguta svako sra*e koje plasiraju. Tako i treba kada svoje sopstvene mušterije smatraš glupima.
Nista da dodam ... ,)
siguran sam da sama FS franshiza nije ugasena ovime.
Polako... za koju godinu...
Jero - hvala za post! ;)
jasno ko dan ;) ...i sa svim tim milijardama u steku oni otpustaju ljude... :|
FlightSimulator je jedna od prvih igara koje sam igra '86. na ST-u :)
