video u igraonici
Što se tiče tvoje ideje, bojim se da je stvar u brzini 2.5 hdda i BD čitača. Mada nisam siguran u ovo što pričam, jer nisam dodatno ispitivao tu problematiku.
zbog toga ce KZ2 biti bez ikakve instalacije
Neko kupi ps3 ubaci br disk i pika killzone2😉
Mislim nema potrebe upgreat konzola zato i igram igrice na njima samo kupis ili svuces igricu i igras i to je to🙂
Nemam ja volje da se zezam oko instalacija programiranja i slicnog
prevod odlično radi na ps3, hvala na pitanju, ako to pitaš... što se tiče onog mučenja za igranje na PC... mislio sam na hardverske sklopove, biose, latencije, overklokovanja, drajvere, menjanje cfg fajlova, prizivanje kiše, nedostatak dll fajlova i ostalih rituala potrebnih za pokretanje igre na PC koja će na kraju raditi u razmacima između 9 i 22 fps 🙂
Kada krene ucitavanje igre izbacuje mi gresku 80010514, prica se po netu da je ovo kvar BD diode, jer zna neko nesto vise o ovome... ?
Since this error occurred, we obviously contacted Sony Support. We were informed that the code is not common, and a simple reset of the system, and restoral of factory settings should do the trick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
I can confirm the error 80010514 is caused by a defective BR lense. I just got this error last week. After trying to figure out what was going on I could find out the BR lense will not read the disc if it is a BR disc, I inserted a PS2 game and it worked, then inserted the BR disc once again and it was recognized by the PS3 but after trying to load the game I got the 80010514 error again.
I shut down the console and this time it didn't read any of the discs. I purchased the KES-400A replacement lense and replace it myself looking at some videos on youtube.
http://www.youtube.com/watch?v=bNW1IK0Gyt4
Right now the console is up and running and probably you would ask why I didn't send it back to Sony. The answer is simple.
My console is the 80GB Motor Storm version. As you may already know this version was discontinued and some features like the card readers, backward compatibilities with PS1 and Ps2 games were removed for the 40G version. If I send back my 80GB console to Sony, they'll send me back a 40G version without the features I just mentioned before, and I didn't pay for a 40G PS3. Another issue is I live in the Dominican Republic and send the console back to the US cost a lot of money, so I decided to fix it myself.
Fix the console isn't the big deal if you have a little knowlegde of electronics. Another thing to consider is to place the components separate so you don't confuse them when assembling the console back togehter.
Jeli samo sa jednom igrom problem ili sa svim?
Sa svim, probao i sa system resetom, ali nista sad mi cak ne izbacuje ni gresku, vec kao da nisam ni ubacio disk.... :wall:
Izgleda da je svoje odblurejisao😀
Bilo bi lepo bez ovakvih komentara jer verujem da njemu nije smesno ni malo... znam da meni ne bi bilo. Stefane baci pogled po google-u malo sta bi mogao da uradis i sta bi moglo da bude..
Nek' uvedu sa patchom opciju instaliranja SVIH igara na hard i skoro u potpunosti resen problem. 🙂
Bitno je da baksuziras sa pljuvanjem po X360, kanta za djubre i ostalo.. 😉
Naci zovem nekog ko ima jedno 10 ak igrica instaliram na hdd i vratim mu 🙂
Jedino da svaka igrica koja se instalira jednom na konzoli da vise nemoze na drugoj mada neznam kako bi to odradili japanci?
Ma ne sljaka to tako, mora da ti bude disk unutra dok igras, ali se ne vrti..
Eh sad tek nerazumem nista sve u svemu videcemo sta ce da budne ako izadje taj pec mada sumnjam🙂
Neznam za vas ali sve vise i vise se brinem za svoj ps3🙁 *** imam ga godinu dana i mesec dana🙂 a kolko vidim vec se ljudi zale na ucitavanja.Izgleda da je malo osetljiviji br laser🙁
