SSD - ima li gde?
Preoccupation
Može li se igde kupiti neki SSD u Beogradu? I ako da - gde?
2,5" SATA Solid state disk 32GB Transcend (TS32GSSD25S-M)
16.554,00 RSD
Microsystems d.o.o.
Super. Hvala.
Pogledaj na pcberzi, ali znaj da nisu ni malo jeftini. 32GB verzija košta između 165 i 185 evra, a nešto isplatljivija verzija od 64GB "svega" 233€. Ne znam ko bi se od PC korisnika opredelio za ovako nešto i iz kog razloga, ali eto...
Edit: Zakasnih... 🙂
Sada nešto gledam... Pa taj Transced je komedija od SSD-a! Evo samo nekih od komentara sa raznih sajtova i foruma:
Note that the Transcend 32GB device has read and write speeds less than half that of some of it's competitors!
If you plan on trying the SSD technology, review your products before buying. Stay away from the Transcend 32Gb SDD. Your money is spent better elsewhere.
A ovde možeš pročitati i ceo prikaz ovog proizvoda.
U zaključku prikaza se kaže:
The Transcend TS32GSSD25S-M obviously fails as a replacement for a laptop hard drive. With less than half the average read times of a traditional SATA hard disk and a claimed random write speed less than a tenth of that even, it's no wonder that Transcend recommends the SLC version of its drives for OS installations. The performance of the TS32G could be compared to that of a typical USB flash drive, and indeed likely uses the same chips inside its black plastic casing. There is no write cache buffer on this drive, something that all standard hard drives have, and NCQ is not supported either, although in this case I'm not sure if adding these features would even help.
OCZ SATA2 SSD od 64GB je mnogo bolja kupovina po odnosu cena/kapacitet, a o performansama da i ne govorim. Dok Transcend ne može da priđe čak ni najbuđavijem 4200 HDD-u, ovaj OCZ izuva čak i najbrže desktop modele. :eyebrows:
Zvao sam Microsystems. Neće uskoro dobijati 64GB modele bilo koje firme. A Transcend u životu ne bih kupio. Ni USB stick...
OCZ je O.K.
Bolje ti je da uzmeš dve (ili 4 ako imaš para i/ili ide portova) brze CompactFlash kartice i preko CF-IDE adaptera ih povežeš na ploču, a onda staviš u RAID mod.
Bolje je da uzmes VelociRaptor i ne zalis ni za cim (sem bukom 🙁)
Jedno noob pitanje: Jer postoji 2.5" ATA SSD? I ako postoji dali bi uredjaj koji koristi 2.5" ATA HDD mogao bez problema da prepozna isti???-Klavijatura konkretno.
Ima. U dotičnoj firmi je bilo da se nađe i IDE i SATA modela. Čak je do nedavno i bilo više ovih prvih. S obzirom da je interfejs realizovan preko adakvatnog kontrolera ne bi trebalo da ima problema sa kompatibilnošću, mada tu nema neke velike garancije.
SATA modeli često pate od nedostatka AHCI kompatibilnosti i NCQ podrške, a šta je sa IDE verzijama stvarno nemam pojma.
Ok,thanks! Palo mi je na pamet da bi mi to bilo odlicno resenje za klavijaturu u smislu sigurnosti podataka,jer je ista skoro svakodnevno pod stresom u transportu...
ronnie koliko si platio masinu ?
U bre, tek sam sad obratio pažnju na mašinu :zgran:
no prob, cena je bila vise nego povoljna.
@RCW: 'gratz, trenutno najjaca na Benchy. :smoke:
A imas i nesto kao na slici dole, samo neznam da li moze da se nadje kod nas...
Podrzava 6 HDSD kartica do 32GB znaci ukupno 192GB...
Najbolja stvar je sto je potpuno necujan i podatci se upisuju kao u RAID 0, sto znaci da je stvarno brzo...
Cena je oko 80e bez kartica.
    24 KB · Pregleda: 52
    30.6 KB · Pregleda: 62
u r joking 🙂 right 🙂
cime se bavis pa ti treba takva makina... ako nije tajna... 🙂
Gde ima da se nabave ovi adapteri?
netiks?
Nema potrebe da neko bude u zabludi... Ideja sa 6 HDSD kartica apsolutno ne može da se poredi sa SSD-om.
A cena? (ne mogu da nadjem na sajtu)
