Preoccupation
Može li se igde kupiti neki SSD u Beogradu? I ako da - gde?
Note that the Transcend 32GB device has read and write speeds less than half that of some of it's competitors!
If you plan on trying the SSD technology, review your products before buying. Stay away from the Transcend 32Gb SDD. Your money is spent better elsewhere.
The Transcend TS32GSSD25S-M obviously fails as a replacement for a laptop hard drive. With less than half the average read times of a traditional SATA hard disk and a claimed random write speed less than a tenth of that even, it's no wonder that Transcend recommends the SLC version of its drives for OS installations. The performance of the TS32G could be compared to that of a typical USB flash drive, and indeed likely uses the same chips inside its black plastic casing. There is no write cache buffer on this drive, something that all standard hard drives have, and NCQ is not supported either, although in this case I'm not sure if adding these features would even help.
Imam VelociRaptor.Bolje je da uzmes VelociRaptor i ne zalis ni za cim (sem bukom 🙁)
E onda je vreme da se vratiš na flopi, pa sve ispočetka. :dImam VelociRaptor.
Pričali smo preko MSN-a. Nemoj da se praviš lud... Kada si mi ti nabavio ploču. Hvala još jednom.ronnie koliko si platio masinu ?
u r joking 🙂 right 🙂
Bolje ti je da uzmeš dve (ili 4 ako imaš para i/ili ide portova) brze CompactFlash kartice i preko CF-IDE adaptera ih povežeš na ploču, a onda staviš u RAID mod.
cime se bavis pa ti treba takva makina... ako nije tajna... 🙂
netiks?
Gde ima da se nabave ovi adapteri?
