pomoc oko konfiguracije
  • Začetnik teme Začetnik teme boleg
boleg
konfa:
Matična ploča Gigabyte Gigabyte GA-EP35-DS3L LGA775, P35+ICH9, FSB1333,PCI-E X16,Dual Channel DDRII, 3PCI, 3PCI (81)
Procesor Intel CPU 775 Core 2 Duo E8400, 3.0 GHz, 6Mb L2 , 1333MHz (158)
Memorija Kingston DDRII 2GB 240pin 800MHz (PC2-6400), CL5 (25)
Grafička karta Gainward PCI-E 9600GT 512MB GDDR3 GeForce, Core 650 MHz, Memory 1,8 GHz,2xDVI, HDTV, TV-out, 256bit (115)
Modem Intex F/M/I 56k V.92 PCI Conexant (6)
CD ROM Pioneer Pioneer DVR-115 Black DVD +R/-R 20x, +RW 8x, -RW 6x, +R DL 10x, CDRW 40x32x40, Double (20)
Hard disk Western HDD 320 GB 7200rpm / Serial ATA II 3.0Gb/s / 16MB (50)
Floppy disk NEC NEC 1.44 MB, 3.5", black (6)
Kućiste Cooler master Miditower Case Centurion 590, 460W, Metal mash, ATX, Fan2x12cm,5x5,25, Black (83)
Zvučnici Logitech S-200 Speaker system 2.1 OEM (21)
Tastatura Logitech Deluxe 250 Keyboard PS/2 Black OEM (8,5)
Miš Logitech Logitech B58, USB/PS2, Optical, Black, OEM, garancija 3 godine (10)
Monitor Samsung Samsung 943N LCD 19", 1280x1024, TFT/TN, 5ms, kontrast 1000:1, ugao 160st, 300cd/m2, D-Sub, black, gar. 3 god. (158)
Ukupno 741.5 €
jel ovo ok, ili treba nesto da se menja
ovo je max. para(oko 700e)
svaka pomoc dobrodosla
hvala
Treba dosta da se menja:
DFI Blood Iron P35 ~80e
Mislim da e8400 moze da se nadje jeftinije.
Uzmi RAM na 1066MHz (Kingston HyperX, Kingmax)
Za 115e imas Palit Sonic 8800GT.
To napajanje koje ide uz taj CM nije nesto kvalitetno. Uzmi OCZ 500W ili LC Power LC6600GP.
Taj Samsung monitor je preskup. Sada se kupuju 22" za te pare (Viewsonic, Asus...)
Memorija Kingston 2xDIMM 1GB DDR2/1066MHz Kingston HyperX, 240-pin, PC2-8500, CL5 (5-5-5-15), 2.0V, LifeTime Warranty (35)
Grafička karta Palit GeForce 8800GT Sonic 512MB DDR3 (115)
CD ROM Pioneer DVD+-R/W drive Pioneer DVR-216D SATA black, max. 20xDVD+-R, 8x6xDVD+-RW, 12xDVD+-RDL, 40x32xCDR/RW, 2MB, OEM pack, S-ATA, gar. 1 god. (21)
Napajanje LC Power LC POWER SILENTGIANT600W LC6600GP V2.3 (53)
Kućiste Cooler Master CoolerMaster Centurion 534 (51)
Monitor Samsung Samsung 2243NW LCD 22" Wide, 1680x1050, TFT/TN, odziv 5ms, kontrast 800:1 (8000:1), 300cd/m2, 160/170st, black, D-Sub, gar. 3 god. (157)
jel ovako bolje?
jedino, probio sam budzet(770e) :-( da li mogu na necem da "zakinem" malo?!
sta fali ovoj ploci?
jel ovako bolje?
Evo odma sam nasao 12 eurica gde ces da gi skines. Floppy ti ne treba, a ne znam ni ovaj modem koji ce ti. Mozes uzeti neko od asusovih kucista. Dolaze bez napajanja, jeftina su, a nisu uopste losa. ta kucista su od 20-25e.
Slazem se za Asus kuciste. Ta Gigabyte ploca je solidna, ali je DFI ipak bolji. Jedino jos mozes da ustedis na procesoru, npr. da uzmes e7200 koga ces lako da overklokujes.
Je l' ovo treba da bude gaming konfiguracija?
konfa:
Ukupno 741.5 €
hvala
Kao prvo, za budzet od skoro 750 evra, mozes daleko bolju konfiguraciju da napravis. Prvo 22" monitor, bolju graficku kartu, plocu sa novijim chipsetom. Ama bas sve...
Maticna ploca: ASUS P5Q (100 evra)
Procesor: Intel E8400 (130 evra)
Ram memorija:GEIL 2GB (2x1GB) 1066MHz DDR2 Ultra (35 evra)
Graficka:ATI 3870 bilo koji proizvodjac (100 evra)
DVD: Pioneer bilo koji (20 evra)
HDD: Western Digital 320gb (45 evra)
Zvucnici:Logitech S-200 Speaker system 2.1 OEM (20)
Floppy: Standard (5 evra)
Tastatura i mis: Logitec neki po izboru (20 evra)
Napajanje:LC Power LC6550GP2 V2.2, max. 550W (50 evra)
Kuciste:Asus TA-863 (20 evra)
Monitor: ASUS TFT 22'' VW222S (175 evra)
Sve zajedno 720 evra.
Matična ploča Asus LGA775, ATX,Intel P45+ICH10R,FSB1600,DDR2 1200,1xPCIe x16,8 xSATAII RAID,GLan,SB 7.1,1394,eSATA (105)
Procesor Intel Intel Core2Duo E8400 (Dual) Box, LGA775, 3.0GHz, FSB1333, 6MB cache, 64bit, SSE4.1, Wolfdale dual-core (45nm), 65W, gar. 3 god. (148)
Memorija Geil DIMM 2GB (2x1GB kit) DDR2/1066MHz Geil Ultra Plus, 240-pin, PC2-8500, CL5 (5-5-5-15), dual channel, LifeTime Warranty (35)
Hard disk Western Digital 500GB Caviar SE16/Blue (WD5000AAKS), 7200rpm, 16MB buffer, S-ATA2 up to 3Gb/s, high perform., OEM, gar. 3 god. (55)
Floppy disk NEC 1.44 MB, 3.5", black (6)
Napajanje LC Power SILENTGIANT600W LC6600GP V2.3 (53)
Kućiste Asus TA-863, midi-tower, no PSU, 180x413x436mm, up to 10 drives, screw-less, side vents, air-duct, MM/USB, black, gar. 3 god. (19)
Miš Logitech B58, USB/PS2, Optical, Black, OEM, garancija 3 godine (10)
Monitor Samsung 2243NW LCD 22" Wide, 1680x1050, TFT/TN, odziv 5ms, kontrast 800:1 (8000:1), 300cd/m2, 160/170st, black, D-Sub, gar. 3 god. (157)
okvirno 760e, pokusacu da pronadjem jeftinije
jel ok, ili ima jos neka sugestija
hvala svima na pomoci
naravno, ploca je P5Q!
E7200 ~ 100 evra
DFI Blood Iron P35-T2RL ~ 75 evra
Palit 4850 ~ 140 evra
Kingston 2x1GB 800MHz ~ 25 evra
Western Digital 5000AAKS ~ 60 evra
Pioneer 215D/216D ili Samsung 203B ~ 20 evra
Antec Sonata III (+500W) ~ 100 evra
Samsung 223BW ~ 200 evra
Logitech S-220 ~ 20 evra
mis i tastatura po izboru (preporuka za jeftinu, a dobru tastaturu - A4Tech KB28G ~ 6 evra) ~10 evra
