Postoji Xbox 360 Memory Upgrade Program gde se za 30$ dobija 20GB hdd i 3 meseca Live (samo treba proveriti da li važi van USA...)sad josh samo hard da nabacim na moj arcade...
Ćuti, dobro si prošaoJa nisam nikakav bot a kamoli xbot ja samo predstavljam situaciju sa moje tacke gledista.
Cekaj hoces da kazes da ne moras da dajes pare za ms-ov hdd vec mozes da stavis i uhakovani obican???!!!
Ono što si ti bio do pre 5 danaNajjednostavnija definicija bota je neobaveshteni navijach.
Sada sam probao NXE, instalirao sam GTA IV, u toku brze voznje se teksture ucitavaju sporije, ali se to odmah ispravi u roku od 1-2 sekunde, za razliku od ucitavanja sa dvd-a, kde je to 5-6 sekundi. Samo nikako ne mogu da namestim rezoluciju 1680x1050 a da nemam dve crne linije gore i dole.
Get yourself a Western Digital SATA BEVS HDD. To use this tool, you need
a HDD security sector file ('hddss.bin'). If you don't have one, here's how
to create one from a valid xbox 360 HDD:
* Dumping the hddss.bin file *
Boot to dos from a writeable medium (like a floppy). Connect an *original*
xbox 360 HDD to your SATA controller. Make sure it is the only SATA device
that is connected. Now run 'hddhackr -d'. This will create a file 'hddss.bin'
and it will save it to the path you've started the hddhackr from.
* Modding your Western Digital *
Now turn off your PC and connect the Western Digital and boot to dos again.
Type 'hddhackr -f' from the same path you have saved the hddss.bin file to.
This will flash your FW. It will ask if you want to create an undo file. It
is advised to do so. This will create an 'undo.bin' file that you need if
you want to undo the hack.
* Check if it worked *
Shut down your pc, reboot again to dos and again type 'hddhackr -f'. It
should now tell you that the drive should work in your x360. If so, connect
it to your x360 and go to your dashboard/system/memory where you should be
able to format the drive.
* Restoring your WD to original state *
If you don't want to use your modded WD in your x360 anymore and you want to
flash it back to its original size, then you can now do so. Boot to dos again
and run 'hddhackr -u'. This will use the undo.bin file you created before to
restore the drive to its original state.
@driver
Jesi li siguran da je do 160GB, ja po netu vidim da svi stavljaju samo ove od 120GB.
Pa prekopiras na usb flash, kopletan SystemUpdate folder. Ubacis flash u xbox i on automatski kaze da ima update i da li zelis da ga instaliras. Instalacija je brza, restartuje se xbox i voila.
Jesi li vec koristio to?
Za one koji su zainteresovani Xbox live gold se moze kupiti na http://www.boxeddeal.com kao i MS poeni, ne šalju vaučere poštom već odmah salju kod na e-mail adresu.
Moguce je, preko WiFi addona koji kosta $100 (official, ne znam da li ima nelicencirana verzija).
