XBOX 360 - opšta diskusija i blic pitanja
Jer na xbox moze cela igra da se instalira ili samo neki odredjeni deo igrice kao na ps3 koji sluzi samo za brze ucitavanje?
Hvala unapred na odgovoru:)
sad josh samo hard da nabacim na moj arcade...
Postoji Xbox 360 Memory Upgrade Program gde se za 30$ dobija 20GB hdd i 3 meseca Live (samo treba proveriti da li važi van USA...)
http://www.xboxstorageupgrade.com/hh/web/home/hhauthentication.jsp;jsessionid=F5074A2133CCB64FB4E019644411CAF8?ssLocale=en_US
Ja nisam nikakav bot a kamoli xbot ja samo predstavljam situaciju sa moje tacke gledista.
Cekaj hoces da kazes da ne moras da dajes pare za ms-ov hdd vec mozes da stavis i uhakovani obican???!!!
Ćuti, dobro si prošao :). Nisu ti izbrisali post i nisu njegovi kerovi krenuli da te ismejavaju komentarima tipa hhhahahha-hhhoohoooh-omgomgomg.
Najjednostavnija definicija bota je neobaveshteni navijach.
Ono što si ti bio do pre 5 dana ;).
driveru a jel to hakovanje harda za xbox jednostavno za uraditi(da li moze svako) ili ce biti komplikovanije.
Get yourself a Western Digital SATA BEVS HDD. To use this tool, you need
a HDD security sector file ('hddss.bin'). If you don't have one, here's how
to create one from a valid xbox 360 HDD:
* Dumping the hddss.bin file *
Boot to dos from a writeable medium (like a floppy). Connect an *original*
xbox 360 HDD to your SATA controller. Make sure it is the only SATA device
that is connected. Now run 'hddhackr -d'. This will create a file 'hddss.bin'
and it will save it to the path you've started the hddhackr from.
* Modding your Western Digital *
Now turn off your PC and connect the Western Digital and boot to dos again.
Type 'hddhackr -f' from the same path you have saved the hddss.bin file to.
This will flash your FW. It will ask if you want to create an undo file. It
is advised to do so. This will create an 'undo.bin' file that you need if
you want to undo the hack.
* Check if it worked *
Shut down your pc, reboot again to dos and again type 'hddhackr -f'. It
should now tell you that the drive should work in your x360. If so, connect
it to your x360 and go to your dashboard/system/memory where you should be
able to format the drive.
* Restoring your WD to original state *
If you don't want to use your modded WD in your x360 anymore and you want to
flash it back to its original size, then you can now do so. Boot to dos again
and run 'hddhackr -u'. This will use the undo.bin file you created before to
restore the drive to its original state.
Sada sam probao NXE, instalirao sam GTA IV, u toku brze voznje se teksture ucitavaju sporije, ali se to odmah ispravi u roku od 1-2 sekunde, za razliku od ucitavanja sa dvd-a, kde je to 5-6 sekundi. Samo nikako ne mogu da namestim rezoluciju 1680x1050 a da nemam dve crne linije gore i dole.
Isti ovaj iz moja mašina, 22".
Ne mogu ni ja namestiti, imam isto Samsung 22" i uvek se vide crne trake ispod i iznad kad namestim 1680x1050. Ima li resenje za ovo?
sve ovo i nije tako tesko mislim na flesovanje firmvera ali sam imao komplikacija sa backapom sadrzaja sa 20 gb diska na novi od 120 i jos jedna stvar ne rade sejvovi od force mora novi profil da se pravi ostalo sto sam probao (a nisam sve) radi
Pa prekopiras na usb flash, kopletan SystemUpdate folder. Ubacis flash u xbox i on automatski kaze da ima update i da li zelis da ga instaliras. Instalacija je brza, restartuje se xbox i voila.
@driver
Jesi li siguran da je do 160GB, ja po netu vidim da svi stavljaju samo ove od 120GB.
niko ti ne brani da stavish i 250 ali tjesh motji da koristish samo onoliko koliko je najvetji hard za xbox trenuttno
Može i HDD od 500GB, ali će XBOX "videti" samo 20GB, 60GB ili 120gb zavisno od porekla hddss.bin (tako da onda propada višak GB-a).
120GB je za sada maksimum koji se moze iskoristiti kod WD BEVS HDD-a.
Ima li nacin da se sacuva stari ako nesto krene po zlu sa ovim novim. Nije da sam paranoican ali za svaki slucaj. Mislim, konzola mi je flesovana ne bih da se odreknem te blagodeti. ;)
Za one koji su zainteresovani Xbox live gold se moze kupiti na http://www.boxeddeal.com kao i MS poeni, ne šalju vaučere poštom već odmah salju kod na e-mail adresu.
Hmmm... nisam otvorio paypal... jel moze direkt Visa virtuon ili tako nesto...
U kuci imam wireless ruter preko koga izlazim na net. Da li je moguce bezzhicno spojiti i Xbox s ruterom i tako izaci na net?
Moguce je, preko WiFi addona koji kosta $100 (official, ne znam da li ima nelicencirana verzija).
Ja nigde nisam video nelicenciranu, a oficijelna se preko ebaya moze naci i za $30.
Ja sam umesto add-ona koji je skup kupio obican wireless ruter koji sam upario sa onim starim wireless ruterom i onda lan kablom spojio box i novi ruter i na taj nacin dobio internet. Vise sam se mucio ali jeftinije sam prosao...
Mada ako nadjes original za manje para, to je elegantnije resenje..
Odradio sam i ja HDD flash. WD 1200BEVS uspesno flashovan, pa sada umesto dosadasnjih 17.3GB imam 107GB. :)
Na 20GB imash 13GB, gde nadje 17 ;)
