Prckao sam u biosu da bi klokovao q6600 i treba mi samo odobrenje da li je dobro sve podeseno 🙂 Nisam vican overkloku a cilj mi je 3GHz i memorija da radi na 1066
ploca: Gigabyte x38-ds5 bios f4
ram: Kingstone 4x1Gb Hyper X KHX8500D2 (1066) 5-5-5-15
Robust Graphics Booster (Auto)
CPU Clock Ratio (9x)
CPU Host Clock Control (Enabled)
CPU Host Frequency (333)
PCI Express Frequency (100)
C.I.A.2 (Disabled)
Performance Enhance (Standard)
System Memory Multiplier (SPD) (3.20b)
Memory Frequency 800 (1066)
DRAM Timing Selectable (SPD) (Manual)
CAS Latency Time 5 (5)
DRAM RAS# to CAS# Delay 5 (5)
DRAM RAS# Precharge 5 (5)
Precharge delay(tRAS) 18 (15)
ACT to ACT Delay(tRRD) 3 (Auto)
Rank Write To READ Delay 3 (Auto)
Write To Precharge Delay 6 (Auto)
Refresh To ACT Delay 42 (0)
Refresh To Precharge Delay 3 (Auto)
tRD 6 (AUTO)
tRD Phase Adjustment 0 (Auto)
Command To #CS Timing 2 (Auto)
CPU/PCIEX Clock Driving Control (800mV)
CPU Clock Skew Control (Normal)
(G)MCH Clock Skew Control (Normal)
System Voltage Control (Manual)
DDR2 OverVoltage Control (+0.40)
PCI-E OverVoltage Control (Normal)
FSB OverVoltage Control (Normal)
(G)MCH OverVoltage Control (Normal)
MCH Reference Voltage Control (Normal)
DDR Reference Voltage Control (Normal)
DDR Terminator Voltage Control (Normal)
CPU Voltage Control (Normal)
Normal CPU Vcore 1.25000V
Uzeo bih ovih dana i neki cooler, za sada je stock cooler. Temperature su do 68C pod punim opterecenjem (Everest)
Ako vam nije smor pogledajte i dajte neki savet
Hvala
C.I.A.2 (Disabled)
tRD 6 (AUTO)
Hvala
