Asus P6T Deluxe Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
£239.99
- Supports Intel Core i7 Socket LGA 1366 Processors ONLY
- 16+2 Phase Power Design
- 8-layer PCB with "Platinum Circuit Layout" for what Asus refers to as "Best Layout Design for Extreme OC Record"
- A "Unique Wind-Flow Thermal Design"
- 8x USB2.0 Ports
- eSATA
- Optical & Digital S/PDIF
- 7.1 Surround Sound with DTS
- Two channel SAS (serial attached SCSI) RAID from the Marvell 88E6320-TFJ2 controller
- 6x SATA Ports
- 6x DDR3 Slots (Supporting Tri-Channel)
- ExpressGate hardware with fast booting Linux OS on an in-built USB stick.
- "5000 hour" Fujitsu capacitors, ferrite core chokes and Low RDS(on) MOSFETs.
Asus P6T Deluxe "OC Palm Edition" Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
£269.99
- 8x USB2.0 Ports
- eSATA
- 6x SATA Ports
- Supplied with OC Palm Device
Intel SmackOver Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
£199.99
- Memory Slots closer to CPU Socket than other designs for increased performance
- 8-layer PCB
- 8x USB2.0 Ports
- eSATA
- 6x SATA Ports
- 4x DDR3 Slots (Supporting Tri-Channel)
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=5&subid=1283
