Asus P5Q-E i Corsair memorija problem
zerbah
VIP član
Imam ASUS P5Q-E i Corsair TWIN2X2048-6400C4DHX (2x2GB DDR2 800 4-4-4-12 2.1V) i sledeci problem:
Naime memorija ne prolazi memtest86, zbog nje mi zakucava komp u igrama i slichno. E sad znam da treba da namestim timinge, voltazu u BIOS-u i da se iskljuchi USB Legacy Support, pa sam probao da to odradim ali bezuspeshno (i dalje ne prolazi memtest)...
Memorija inache prolazi memtest na Gigabyte P35 DS4 plochi, tako da nije riknula. A i nalazi se u spisku kompatibilnih memorijskih modula za P5Q-E...
Poshto nisam neki overclocker ako bi neko mogao da mi kaze shta bi trebalo da podesim u ASUS AI na ovim mestima:
1st Information: 5-5-5-15-3-36-5-3
The values vary depending on your settings of the following sub-items:
CAS# Latency [ 5 DRAM Clocks]
Configuration options: [3 DRAM Clocks] [4 DRAM Clocks] [5 DRAM Clocks]
[6 DRAM Clocks] [7 DRAM Clocks] [8 DRAM Clocks] [9 DRAM Clocks]
[10 DRAM Clocks] [11 DRAM Clocks]
DRAM RAS# to CAS# Delay [ 5 DRAM Clocks]
Configuration options: [3 DRAM Clocks] [4 DRAM Clocks] – [17 DRAM
Clocks] [18 DRAM Clocks]
DRAM RAS# Precharge [ 5 DRAM Clocks]
DRAM RAS# Activate to Precharge Time [15 DRAM Clocks]
Configuration options: [3 DRAM Clocks] [4 DRAM Clocks] – [33 DRAM
Clocks] [34 DRAM Clocks]
RAS# to RAS# Delay [Auto]
Configuration options: [Auto] [1 DRAM Clocks] – [15 DRAM Clocks]
Row Refresh Cycle Time [Auto]
Configuration options: [Auto] [20 DRAM Clocks] [25 DRAM Clocks]
[30 DRAM Clocks] – [65 DRAM Clocks] [70 DRAM Clocks] [80 DRAM
Clocks] [85 DRAM Clocks] [105 DRAM Clocks] [132 DRAM Clocks]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
A ovo dalje uopshte ne znam shta je:
2nd Information: 8-3-5-4-6-4-6
READ to WRITE Delay(S/D) [Auto]
Write to Read Delay(S) [Auto]
WRITE to READ Delay(D) [Auto]
READ To READ Delay(S) [Auto]
READ To READ Delay(D) [Auto]
WRITE To WRITE Delay(S) [Auto]
WRITE To WRITE Delay(D) [Auto]
3rd Information: 13-5-1-5-5
WRITE to PRE Delay [Auto]
Configuration options: [Auto] [1 DRAM Clocks] – [31 DRAM Clocks]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
Configuration options: [Auto] [1 DRAM Clocks] – [3 DRAM Clocks]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
Hvala unapred :wave:
P.S. Plocha je isto ispravna jer radi sa 2x1GB OCZ DDR2 800 memorijom... I ima poslednji bios.
"tajminzi" su ti ok, samo podigni malo voltazu, verovatno stoji na 1.8V a to joj je malo ;)
Da li ti je procesor klokovan i kako/koliko?
Probaj sledeća podešavanja u Ai Tweaker-u
Ai Overclock Tuner....................[Manual]
CPU Ratio Setting................................[x]
FSB Frequency....................................[x]
PCIE Freqency....................................[x]
FSB Strap to NB..................................[x]
DRAM Frequency.................................[x]
DRAM CLK Skew on Channel A1..............[Auto]
DRAM CLK Skew on Channel A2..............[Auto]
DRAM CLK Skew on Channel B1..............[Auto]
DRAM CLK Skew on Channel B2..............[Auto]
DRAM Timing Control............................[Manual]
1st Information:
CAS# Latency....................................[4]
DRAM RAS# to CAS# Delay...................[4]
DRAM RAS# Precharge.........................[4]
DRAM RAS# Activate to Precharge Time..[12]
RAS# to RAS# Delay...........................[Auto]
Row Refresh Cycle Time.......................[Auto]
Write Recovery Time...........................[Auto]
Read to Precharge Time.......................[Auto]
2nd Information:
READ to WRITE Delay(S/D).........[Auto]
Write to Read Delay(S)..............[Auto]
WRITE to READ Delay(D)............[Auto]
READ To READ Delay(S)..............[Auto]
READ To READ Delay(D)..............[Auto]
WRITE To WRITE Delay(S)..........[Auto]
WRITE To WRITE Delay(D)..........[Auto]
3rd Information:
WRITE to PRE Delay..................[Auto]
READ to PRE Delay....................[Auto]
PRE to PRE Delay......................[Auto]
ALL PRE to ACT Delay...............[Auto]
ALL PRE to REF Delay................[Auto]
DRAM Static Read Control..........[Disabled]
DRAM Read Training..................[Auto]
MEM. OC Charger.....................[Auto]
Ai Clock Twister.......................[Auto]
Ai Transaction Booster..............[Manual]
Common Performance Level........[10]
Pull-In of CHA PH1....................[Disabled]
Pull-In of CHA PH2....................[Disabled]
Pull-In of CHA PH3....................[Disabled]
Pull-In of CHA PH4....................[Disabled]
Pull-In of CHB PH1....................[Disabled]
Pull-In of CHB PH2....................[Disabled]
Pull-In of CHB PH3....................[Disabled]
Pull-In of CHB PH4....................[Disabled]
CPU Voltage............................[x]
CPU GTL Voltage Reference (0/2)[x]
CPU GTL Voltage Reference (1/3)[x]
CPU PLL Voltage.......................[x]
FSB Termination Voltage............[x]
DRAM Voltage..........................[2.10]
NB Voltage..............................[x]
NB GTL Reference....................[x]
SB Voltage.............................[x]
PCIE Sata Voltage...................[x]
Load-Line Calibration...............[Enabled]
CPU Spread Spectrum..............[Disabled]
PCIE Spread Spectrum.............[Disabled]
CPU Clock Skew.....................[Auto]
NB Clock Skew.......................[Auto]
CPU Margin Enhancement.........[Optimal]
Zashto bi stavljao 4-4-4-12 kad ni ovako nece da mu radi, nek proba prvo sa opushtenijim latencijama, mozda se kolju maticna i memorija pa otud problemi, a ako mu ne radi na 5-5-5-15 sa 2.0 - 2.1V onda bar zna na cemu je ;)
:wave:
Slazem se za voltazu.
Imam istu ploču i MUSHKIN RedLine PC8000 2x2GB.
E8600 je klokovan i ide 500x9 ili 450x10.
RAM na 2.1V nece 1000MHz stabilno nikako, pa čak ni sa jednom voltažom od 1.9-2.35V.
900MHz ide CL5 OK a može i CL4 ali samo ako postavim sledeca setovanja:
DRAM Read Training..................[Disebled]
MEM. OC Charger.....................[Enebled]
Ai Clock Twister.......................[Moderate]
Meni je taj RAM živce iskidao dok sam ga podesio...
A vidim
pa šteta da ne pokuša na 4-4-4-12 2.1V pa ako sistem zakucava lako će razlabaviti na 5-5-5-15 > 6-6-6-18 > 99-99-99-99999 ;)
Moja predlog je da malo popustis setovanja i dobijes stabilnost. :) 5-5-5-15 60.
Zategnutim setovanjima dobijas vrlo malo ??? i rizikujes nestabilnost. ;)
Poz
Koja ti je revizija taj Corsair?
Hvala na pomovi, probacu kada dodjem kuci s posla pa cu da vam javim da li sam uspeo da namestim sve da radi kako treba.
CM2X2048-6400C4DHX Ver 1.1
edit: proc za sada nije overclockovan, za sada mi je vaznija stabilnost...
Pa druzhe ako je 1.1 to su Micron D9 chipovi tako da sumnjam da je do memare, tj. da ne mozhe da izvuche 4-4-4-12 latencije, neshto drugo je onda problem.
Uspeo sam da namestim da radi stabilno posle dosta dugog podeshavanja raznih parametara, hvala vam puno za pomoc!
Koliko sam skapirao, plocha je dosta osetljiva na memoriju tako da je to uglavnom bio razlog za nestabilan rad...
Problem je do biosa koji nije ispeglan do kraja, ja sam izgubio dve nedelje menjajuci sve delove a ono samo jedna stavka u biosu treba da se promeni i to koja nema veze sa memorijom vec sa cpu, zadnja verzija biosa 1406 bi trebala da je ispravila sve ...
Na mojoj PC8000 MUSHKIN RedLine 2x2BG su takodje Mikroni pa nikako da proradi makar na 1000 CL5.
Ko sto rece xane fleshuj zadnji 1406 bios ili modovani 1402m sa XSa koji je meni resio problem.
Kao shto rekoh, ako su mikron chipovi onda nije to memare vec to ploche, biosa, podeshavanja i to treba da se podesi.:wave:
Kad cemo da se jednom svi slozimo da nema "onih dobrih" Micron D9 chipova na 2x2GB modulima zato sto su D9GMH i njemu slicni 512Mbit chipovi?
Ako se nesto promenilo na tom polju, molio bih za link ;)
My bad, nisam video da je u pitanju 2x2Gb kit.:wave:
Mada opet mi je chudno da taj Redline ne mozhe vishe od 1000MHz CL5, to mozhe fazon i najsocijalniji Geil...
Postovao sam link, a nisam ni gledao rezultate. Ni njima se nije bas posrecilo sa Redline-om.
link
@mad_skillz
Moze, moze al' vrrrlo malo preko. Za oc nikakva
Eto na fsb 500 1:1 radi kada se u biosu parametri podese a sa sve na auto nema ni govora (adj' neka je ploca osetljiva ali da nece stabilno preko 1020-1030mhz stvarno je katastrofa)
@mitarus
ma na nekim testovime na netu oce i 1116 sa 1.98v ili radi odlicno ali sa sumanutim voltazama
al' da mi je bio ovaj tvoj link ne bi je uzeo... a birao sam izmedju 2x2gb Mushkin RedLine cl5 i 2x1GB CellShock cl4 i posto dam drchan na kapacitet a iz pi sam zeznuo sam se :wall:
@mitarus
Bad luck :S:
I ja sam prvo naleteo na dobre rezultate, a onda sam izguglao onaj poljski review. Izgleda da ti je zapala losija serija...
P.S. Ovo sa linka mozda i ne treba da citas, smorices se...
Samo da se javim da je sistem stabilan i josh jednom zahvalim za pomoc :)
A sta si tacno podesio, odnosno u cemu je bio problem? U voltazi ili?
Proradilo je kako treba kada sam namestio sledece parametre:
DRAM Read Training..................[Disabled]
Ai Transaction Booster..............[Light]
