Potreban driver
tatomir.uros
Cao svima, greskom sam obrisao SoundMAX Sound driver :wall: sa laptopa LG LS50a centrino 1,6 GHz ( 4 god.star, izgubio sam fabricki cd sa driverima) ... Racunar sad neprepoznaje combo drive HL-DT-ST RW/DVD GCC-4243N mislim da je LG i ne radi multimedia audio controller (nema zvuka). Pokusao sam da pronadjem driver na netu ali bezuspesno... :mad: Nadam se da neko mozda ima ili zna odakle da skinem driver ...:banana:
Srdacan pzdrav!
Idi u podforum konzole i naci ces driver-a.:wave:
instaliran driver ali !!!!
Hvala !!!:wave: instalirao sam driver Sound MAX sad sve radi osim combo drajva prijavljuje gresku Code 39 pokusao sam deinstalaciju i ponovnu instalaciju uredjaja, ali nevredi...:smoke: Na (LG sajtu ,driverguide sajtu i jos nekim...)nemaju driver za ovaj tip HL-DT-ST RW/DVD GCC-4243N ...:S:
Je li drajv prestao da radi posle što si uninstalirao neki program za rezanje?
Probaj ovako:
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Srdacan pzdrav!
evo jedan interesantan torrent ;)
http://btjunkie.org/torrent/50000-U.../3834f3c5f248305a84f376c0a6f26861a652fa84e9ef
narezi i koristit ce i za mnogo drugih laptopova i desktop racunara... mnogo vremena se ustedi,vjeruj mi ;)
