IntelBurnTest
Puca li puca sa 4GB rama ako hocu na max ili ti prioritet 1.
Evo jedne informacije za sve one koji su imali problema za 1 nivom stres testa, tj. onima koji nisu mogli da ga odrade.
Radi se o tome da nivo 1 podrazumeva kompletno zauzece RAM-a, pa ako ga imate vise od 2GB treba vam 64-bitni OS.
Ja sam imao problema na XP-u SP3 i Visti SP1 32-bitnim, ali na Visti x64 SP1 je proslo bez ikakvih problema :)
Evo mojih rezultata, ali meni temperature nisu bile visoke... oko 56*C za CPU je bio max???
Je l' to ok? Vidim da je prošao test, ali nije se baš nešto namučio :)
Ovaj test stvarno przi intel proc... testirao sam sa Orthosom na 8 priority samo CPU tem oko 42-43C pri 3.85GHz pustiom sam ovaj IBT temp isla cak do 55C . Mada neznam koje programu da verujem RealTemp-u ili CoreTempu.
RealTemp kad udjem u OS mi odmah pokazuje 33C za jedno a za drugo isto ili 31 a Core temp oba 39C i isto tako pokazuje vecu temp u testovima.
Ovo ubija cpu. Na 3.6GHz se resetuje a inace je stabilan prime95 12 sati. Mrzi me da probavam frekvencije izmedju pa sam spustio mnozilac na 8. Na 3.2GHz nije dobro odradio test. Onda sam promenio transaction booster sa disabled na enabled level 0 i evo ga.
    316.5 KB · Pregleda: 89
Kod:
[B]IntelBurnTest v1.7[/B]
by AgentGOD
The original. All others are copycats.
Home Page: http://www.ultimate-filez.com
Donation : http://www.ultimate-filez.com/?page=donate
Description:
		Linpack by Intel(R) is an extremely stressful program that will
put even the most powerful X86/X64 CPU in the world at its knees. Load temp
under Linpack will be up to 22*C higher than the competing software Prime95.
This program will make usage of Linpack easier and more practical.
Keep in mind, use this program at your own risk. By using this program, you
agree that neither I nor Intel shall be responsible for including, but not
limited to: burned up CPU, fried motherboard, spontaneous room temperature
increase, hair loss, or mental stress.
Compatibility:
	Works with Intel(R) and AMD CPUs. Tested Intel(R) Core 2(tm) Quad
	Q6600, Intel(R) Pentium(tm) III 550 MHz, AMD Athlon 64(tm) X2 4200+,
	and AMD Opteron 165 (Working with AMD processors since v1.7).
	Tested on Microsoft(R) Windows XP Professional SP2, XP Professional
	X64 Edition SP2. Tested on Microsoft(R) Windows Vista(tm) X86/X64
	by many awesome users like yourself;)
Benefits of using Linpack:
1. More accurate than Prime95 Small FFTs/Blend.
2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually
   something like 8 minutes Linpack vs 40 hours under Prime95).
3. Use the same stress-testing engine that Intel uses to test their products
   before they are packed and put on shelves for sale.
Benefits of using IntelBurnTest:
1. Simplifies usage of Linpack.
2. Direct output of results to the screen.
3. Simplifies the process of selecting a test size to use.
4. Better appearance.
How to test CPU and RAM stability (summarized):
Pre. You need to extract everything from the archive to a single folder, while
	maintaining the original directory structure.
1. It is best to use a 64-bit OS with the 64-bit mode for the most accurate
   test result.
2. Use the most available RAM possible (IntelBurnTest can now do this on
   its own automatically). The more memory it uses, the more accurate.
3. Select the run # (should use at least 5).
4. Start running. Output should look something like this (unless if error detection is on*):
	Size   LDA	Align. Time(s)	GFlops   Residual	  Residual(norm)
	10000  10000  4	  15.979	 41.7337  1.012665e-010 3.570760e-002
	10000  10000  4	  15.119	 44.1087  1.012665e-010 3.570760e-002
	10000  10000  4	  15.216	 43.8254  1.012665e-010 3.570760e-002
   NOTE: Depending on the memory size selected, the testing size will be
	 different, so the Residual(norm) values will not be the same if you
	 ran this test each time with different amounts of memory selected.
5. Above indicates that the test ran fine so far without instability, but
   below indicates instability (the Residual(norm) values aren't the same
   throughout running the test):
	10000  10000  4	  15.245	 43.7434  1.525878e-005 5.380399e+003
	10000  10000  4	  15.250	 43.7303  2.460366e-010 8.675501e-002
	10000  10000  4	  15.162	 43.9816  1.012665e-010 3.570760e-002
   NOTE: Instability doesn't necessarily have to happen at the beginning, it
	 can happen in the middle, or at the end. It could be just ONE of
	 them that is inconsistent, but that DOES indicate instability. It is
	 highly recommended to use the most free memory possible for the most
	 accurate, and quick test. BSOD or freezing are signs of instability
	 as well.
* If error detection is on, the program will only output the results at the end of the
  run, and give a conclusion about whether or not your PC is stable. If it is off,
  you will see similar output as above during the testing.
Credits:
AgentGOD - Coding this program, duh :)
Cronos (from XS) - for the original the memory size equation
mikeyakame (from XS) - for notifying me of newer binaries
WoZZeR999 (from XS) - memory size suggestion
krille (from XS) - for the constructive criticisms
Intel - for Linpack and a Core 2(tm) Quad processor;)
IntelBurnTest, Copyright © 2008 Ultimate-Filez. Linpack, Copyright © Intel(R) Corporation.
Download link: http://www.ultimate-filez.com/files/IntelBurnTest.zip
Native 64-bit version for WinPE: http://www.ultimate-filez.com/files/IntelBurnTest-x64.zip
Zaintrigirao me test jer ne treba cekati previse da se vidi da li je masina nestabilna. S obzirom da drzim CPU na stock naponu, probao sam 10 prolaza, max stress test pod XP64, 4GB RAM. Napon je padao, sudeci po HWMonitoru sa 1.17 na 1.15V ali je proslo.
    205.4 KB · Pregleda: 94
Iako je ovaj test rigorzniji od primea i orthosa, sudeci po iznetim iskustvima, bas me zanima da li je i dalje neophodno testiranje tim programima posto testiranje moze da traje mnogo duze i da na taj nacin istakne nestabilnost? Sa druge strane, intelburntest za minut zagreje cpu 5-10 stepeni vise nego prime za 12 sati. Da li je neko video slucaj da je cpu ibt stabilan a prime nestabilan?
Ja sam imao taj slucaj i verovatno je to sto nije mogao da uposli svih 4G memorije . e sad ne znam da li ova poslednja verzija to resava ili mora da se instalira 64 OS
Mislim da i autor preporucuje da se testira na 64bitnom OS-u. Inace ne treba verovati samo jednom programu. Ja ih uvek probam sve (Prime, OCCT, S&M, IBT) i pod 64bitnim OS-om (jos 2005-te kada sam nabavio prvi 64bitni CPU, imao sam problema pod 64bitnim OS-om, Prime95 je pod njim pucao dok je pod 32bitnim radio OK).
Da ne pisem sve ponovo ;)
Probao sam verziju 1.8 na Duronu@840MHz. Test je prosao bez greske, na max opterecenju, a temperatura je otisla na 46C, mereno Speedfanom 4.34. Koriscenjem programa S&M v.1.8.1 (opcija "CPU (FPU)" temp je dosla do 51C. Da li je jos neko testirao max. temp. S&M-om?
