Thermaltake Xpressar RCS100 - kuciste/frizider
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700XT
Storage
1 TB SSDa + 3TB HDDa
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
Samo ubacis pivo i nabavis ovaj otvarac....:)
Thermaltake Reveals the XPRESSAR RCS100 Phase-Change Processor Cooling
Back in March 2008, Thermaltake introduced its first phase change cooling prototype. At the time, we were able to reveal only a few pictures, without knowing what was to come. Today Thermaltake said that after four years of research, the company's first DC inverter type micro refrigeration cooling system is finally ready to hit the market. The so-called Thermaltake XPRESSAR utilizes cyclic refrigeration method based on the vapor-compression refrigeration, to take away the heat produced by processors. Vapor-compression refrigeration systems use a circulating liquid refrigerant as cooling medium which absorbs and removes heat from the space to be cooled and subsequently reject that heat elsewhere. All such systems have four components: a compressor, a condenser, an expansion valve, and an evaporator. For now the XPRESSAR phase-change cooling will be paired with a Xaser VI case and sold as XPRESSAR RCS100. The total weight of both parts will equal to 22.2kg. Thermaltake ensures that such a system will result in 20ºC better temps than most liquid-based systems, and also be compatible with all Intel LGA775 and LGA1366 (Nehalem) processors (maybe an AMD kit will be released sometime later). More information on the XPRESSAR RCS100 can be found here. Pricing and availability are still to be announced. It's time for the reviews now.
Thermaltake turns PC case into a fridge
Ovo sam i sanjao godinama, najzad da su to i napravili i komercijalizovali. Svaka cast inzinjerima Thermaltake-a. Ako bude kod nas do 250 eur-a uzimam, ali cisto sumjam bar prvih 6-7 meseci.
Evo principa kako radi : http://www.xpressar.com/flash-demo.html
WTF???????? :shock: :zgran: :sceptic: :hair:
Ma ja sumljam da će biti do 250e.
TT Xaser VI je oko 165e, a vodena hladjenja su 80-100e. Teško da će TT dati svoj revolucionarni proizvod u rangu cene vodenih hladjenja. Pre bih očekivao 300-350e.
Mogu samo da kažem da je već poručeno 10-ak komada, a cena simpatičnih 500 evra ;)
20C nize od vodenog, stvarno impresivno. Znaci za nekih 2 god ocekujemo ovakva kucista u komercijalnim vodama...najs.
Kako li si dosao to te informacije da mi je znati (izgleda da mnogo brbljam okolo) :)
Cena ce biti oko 450-tak evra u MP. E8400 na 4050mhz temp je bio 29C u full load i u prodaji ce biti za 2 meseca.
Koja bi bila temperatura tog proca na toj freq,ali na vodi,zna li neko?
Koliko se odavde moze videti kuciste nije nista modifikovano u onosu na obicnog Xaser-a ?
Bilo bi lepo kad bi ovo fazno bilo i posebno da se uzme a ne samo pre-installed
