AMD based sub notebook/netbook
evo ja nadjoh nekoliko filmica vrlo zanimljiv lapic, bash minijatura
http://www.revver.com/video/948927/amd-netbook-amd-umpc/
http://www.youtube.com/watch?v=x_aeYNHS3mE
http://www.youtube.com/watch?v=6LsSE02pt5Y
Ima li kakvih najava da ce biti vishe netbookova sa AMD procesorima? Ili su se svi bash opredelili za Atom.
:wave:
AMD još nije izbacio procesor specijalno namenjen tom tipu računara, očekuje se tek početkom 2009. Koliko vidim ovo čudo koristi dual-core procesor namenjen klasičnim notebook računarima. Postavlja se pitanje kako su rešili hlađenje procesora sa TDPom deklarisanim na 25-35W u tako malom kućištu. Takođe, pitanje je kolika je autonomija uređaja pri radu na baterije.
CeleronM 420 ili C2D 5200 se u klasicnim laptopima hlade 5cm ventilatorom i toplotnom cevi sa hladnjakom manjim od pakovanja orbit zvaka...
skoro je CEO AMD-a demantovao najave o ovakvom projektu, bilo je na inquirer-u, nisam sto posto siguran ...
Shta onda ispadne, da smo osudjeni na Atom i Nano? Mislim nisu to loshi procesori, ali chipsetovi odnosno grafichke koje idu uz iste nisu bash neshto.... Mislim onaj GMA950 pored nekog ATI reshenja nema shta da trazi, a tek VIA grafichka reshenja.
Despite previous claims that AMD had no plans to enter the netbook CPU market, rumour has it that just such a chip is set to be announced late this week, according to APC Magazine. CEO Dirk Meyer had previously suggested such a CPU would hit in November, before being contradicted by Chief Marketing Officer Nigel Dessau, so presumably the company had a change of heart.
Is this AMD's rival to Atom?
The supposed chip will focus on two of the areas where netbooks have, to this point, still struggled a bit; namely video playback performance and battery life. Reports suggest AMD is aiming for an eight to nine hour battery life while still offering better performance that its rival, Intel's Atom CPU.
Should such claims be borne out it will be interesting to see what Intel does to counter. Dual-core Atom systems are expected to hit some time soon, although they're not necessarily intended for netbook-type systems. A pair of cores with Hyper Threading on top should definitely provide for some multi-tasking horsepower. Not that the average netbook user is likely to want for more performance from a single-core Atom chip, if you ask me.
Still, I definitely won't complain if we get faster chips drawing less power. No matter whose badge is branded into them.
http://www.trustedreviews.com/cpu-m...umour--AMD-Netbook-CPU-Launching-This-Week/p1
:type:
Kako ide sa snabdevenoscu netbookovima kod nas, izgleda da cu ja pre docekati taj amd, nego asus 901. A obzirom da bi baterija trebala duze da traje, da ima normalan cipset, plus malo zbog konkurencije padnu cene, mozda to i ne ispadne tako lose.
Ja kada sam o tome prichao malte ne svi su me "napushavali" ..
Zanimljivo u svakom sluchaju, mislim ovi youtube-ovi :wave:
AMD Athlon Neo: Cost Effective Powerful Mobility?
Manufacturer: AMD
It's like a marketing buzzword masterpiece, or mayhem, depending on which way you look at it, but having tried to sum up what AMD is aiming for in its new Athlon Neo product is difficult to say the least.
AMD didn't want to just "make an Atom" - jumping in an Intel bandwagon when it's never been strong in the mobile realm is not an idea that AMD seems to relish, and besides, most of the Silverthorne team designing the Atom CPU were reassigned from the fabled Tejas project in 2005. This would mean for AMD to design a "true" Atom-esq CPU, it would have to think three years ahead.
Regardless of this fact, AMD has good reason to avoid it: AMD is targeting the ultra-thin ten to 13-inch, $499 to $1,499 segment between sub-$499 netbook and big, clunky mainstream notebooks. It's a brave move, but we think it's a clever one - if you look at any cheap notebook now on sale it's either 15.4-inch brick with a mix of cheap parts or an ultra teeny netbook that's barely capable of running video, let alone do two things at once.
There's nothing "inexpensive" but also quite powerful - enough to be really productive: multitasking, editing photos (the one thing that has personally stopped me getting a netbook: Adobe Photoshop), and just the few things that are a bit more intensive than basic computing. To get a good ultra-thin solution it's either a netbook like the Samsung NC10 or Acer Aspire One or, at the other end of the scale, it's a Sony TZ, Lenovo ThinkPad X300 or Macbook Air - there is literally nothing inbetween.
AMD is attempting to carve the market up once more with its new Yukon platform, headed up by the Athlon Neo CPU and 690T northbridge. Note that I didn't use "new" for the CPU because it's still the same old K8 core, just respinned into a slightly new design. Since AMD was kind enough to give some good friends of ours their pink slips just before Christmas, we've been finding it difficult to hone down some of the finer details right now but what we do know is this:
AMD Athlon Neo MV-40:
1.6GHz single core with a 15W TDP
512k L2 cache, 64k L1 data and instruction caches
AMD Sempron 200U:
1.0GHz single core
256k L2 cache, 64k L1 data and instruction caches
AMD Sempron 210U:
1.5GHz single core
Built on the 65nm SOI process
Embedded design, not socket
AMD 690T northbridge and SB600 southbridge based on the UMC 65nm process - platform total TDP is 27W (for Athlon Neo)
HyperTransport 1.0
The launch speed matches the Intel Atom and the cache sizes are business as usual for an Athlon K8 CPU, however the 15W TDP is significantly more than the Atom's 4-8W, but remember the Neo has more cache, an integrated memory controller and importantly - out of order execution for much improved performance.
http://www.bit-tech.net/hardware/cpus/2009/01/06/amd-athlon-neo-the-new-ultra-thin-platform/1
http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_9484_15931,00.html
meni se mnogo sviđa touch screen na ovom malom čudu, i mislim da mu to daje lepu funkcionalnost... i ovaj optički mouse pointer je simpatična stvar... cool sve u svemu.... ovo tržište postaje baš bogato...
Processor: 1.6GHz AMD Athlon Neo 64-bit processor
Graphics: ATI Radeon HD 3410 (256MB dedicated memory)
Operating System: Windows Vista Home Premium with SP 1 (32-bit)
Screen: 12.1" HP BrightView Widescreen Display (1280 x 800)
Memory: 3GB (up to 4GB configurable)
Storage: 160GB HDD
Optical Drive: External Blu-ray Drive with Double Layer Support
Wireless and Communications: 802.11b/g WLAN
Battery: 4-cell Li-Ion
HP Pavilion dv2
Jel ima nekih novih najava kada bi ove masine mogle da se pojave na trzistu?
