Gigabyte (i sve ostale) 4850 - prvi utisci
Chinaski izvoli :d
Pentinjum E2180 @3GHz
GA-P31-S3
Cell Shock PC8000 cl 4-4-4-12
Sapphire HD4870 default :d
WIN XP SP3
ATI Catalyst 8.7 beta/ neka zameri koliko ko hoce, ali sam uradio ovako da se vidi koliki je benefit novog drivera :)
itd :)
7/5/2008 3:36:16 AM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 52.50s, Average FPS: 38.09
Min FPS: 19.71 at frame 148, Max FPS: 52.60 at frame 888
Average Tri/Sec: 37475160, Tri/Frame: 983753
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 44.20s, Average FPS: 45.25
Min FPS: 19.71 at frame 148, Max FPS: 52.88 at frame 1024
Average Tri/Sec: 44973076, Tri/Frame: 993960
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 44.16s, Average FPS: 45.29
Min FPS: 19.71 at frame 148, Max FPS: 53.13 at frame 979
Average Tri/Sec: 45055712, Tri/Frame: 994739
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 45.27
Assault Harbor 1280x1024 High + 4xAA + 4xAF
7/5/2008 3:47:46 AM - XP
Beginning Run #1 on Map-harbor, Demo-Assault_Harbor
DX9 1280x1024, AA=4x, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 5
TimeDemo Play Started , (Total Frames: 4100, Recorded Time: 132.23s)
Play Time: 167.01s, Average FPS: 24.55
Min FPS: 11.93 at frame 3571, Max FPS: 33.42 at frame 1312
Average Tri/Sec: 1806276, Tri/Frame: 73578
Recorded/Played Tris ratio: 0.19
Play Time: 153.30s, Average FPS: 26.74
Min FPS: 11.93 at frame 3571, Max FPS: 36.83 at frame 1969
Average Tri/Sec: 1223202, Tri/Frame: 45735
Recorded/Played Tris ratio: 0.30
Play Time: 152.63s, Average FPS: 26.86
Average Tri/Sec: 1289734, Tri/Frame: 48012
Recorded/Played Tris ratio: 0.28
Completed All Tests
Run #1- DX9 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 26.8
Assault Harbor 1280x1024 High + 8xAA+4xAF
7/5/2008 4:18:31 AM - XP
DX9 1280x1024, AA=8x, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=2, Time Of Day= 5
Play Time: 160.52s, Average FPS: 25.54
Min FPS: 18.63 at frame 2903, Max FPS: 34.99 at frame 1736
Average Tri/Sec: 1665443, Tri/Frame: 65204
Recorded/Played Tris ratio: 0.21
Play Time: 149.74s, Average FPS: 27.38
Average Tri/Sec: 1239910, Tri/Frame: 45282
TimeDemo Play Ended, (2 Runs Performed)
Completed All Tests
Run #1- DX9 1280x1024 AA=8x, 32 bit test, Quality: High ~~ Last Average FPS: 27.38
Ne znam Storme zaista, glup sam :d
:wave:
Jos nesto se da primetiti kakav je uticaj ostavio 4850. Mozda nije samo zbog njega, ali oglasi su puni do juce NVidia perjanica iz srednjeg segmenta (8800 9600). Drago mi je zbog konzumenata, ali i ATI-AMD sto je uspeo da izbaci ovakvu odlicnu karticu (cip). Jaka konkurencija uvek vodi ka stvaranju jos boljih resenja za jos manje pare ;)
Ugradio sam gomilu PE2xxx jos nisam naisao ni na jedan koji nece na +3GHz, pa i na ovoj bangavoj ploci koja nece preko 350FSB-a, sta im radite :)
:wave:
Nemam pojma, samo "obaveznih 3GHz" ne priznajem od kako sam ortaku probao da zbudzim klok. Sve kombinacije multi i FSBa. To je E2180 koji nece na preko 2.8GHz da radi sem na previsokim naponima >1.6V. Na 2.7GHz temperature su ~35 idle i ispod 50 load. Ploca GA-P35-DS3. Nije do ploce jer radi 340x8=2720. Stabilnost zavisna iskljucivo od kloka. Tu je taj zid - [email protected] i [email protected]. Jednostavno ima losih serija proceva...
Moj E2160 radi kako god mu naredim do 3.3GHz :), samo se preko 3GHz pregreva na ovom suntavom BOXu. Igrao sam se sa jos jednim E2180 i E2160 i oni su hteli +3GHz. Evo ni DarkHorus ne moze da dobaci do 3. Verujem da ne gresi ni u cemu, jednostavno bad luck...
EDIT: A da... Svaka cast za test cheers
EDIT2: Jel video neko test 4850, a da nije referentan dizajn/kuler? Nasao sam 100 testova, a sve iste kartice, samo druga slicica...
hvala Yoti :)
vidi se da je avg i max fps isti na E2180@3Ghz i E8200@3Ghz, samo je min fps malo veci u 2. slucaju. ja mogu da zivim sa tim :)
pozdrav
:wave:
@ Chinaski ...ovo za 4Ghz sa ti najvise pomenuo iz razloga da sam ja osetio razliku kada sam presao sa [email protected] na E8400@4Ghz u onim delovima Crysis-a gde najvise pada framerate (Core,Paradise Lost ...) znas i sam na koje mislim.
Mene licno zanima kako radi novi Ati 4850 u ovom Benchmark_CPU2.bat testu,jeste da je cpu test al cisto da vidim kakva je razlika
Hahahaha, 6x vise cache-a, a jedino je min. fps veci! (ok, nije sasvim zanemarivo, niko ne voli da framerate znacajno pada) Jos treba dodati da je E8200 radio na vecem FSBu, sto jelte znaci vecu memorijsku propusnost, obzirom da je memorijska propusnost ogranicena FSB-om. :D
Ima da E2xx0 jos dugo gura...
ali ne zaboravi da retko ko drzi e8200 na 3ghz, ili ga drzis na stock brzini ili na 3.6 - 4ghz
cisto kao napomena nekog ko se vec duze vreme druzi sa grafuljama i njihovim perfomansama, zar je moguce da josh neko shvata 3d mark kao relevantan podatak??? vec godinama je dokazano da samo realna upotreba u igrama moze dovesti do nekih uporedivih rezultata.... bez obzira ko bi bolji... cudo jedno da se 3d mark i dalje koristi u testovima posle toliko generacija u kojima je pokazano da je on jedna sprdnja...
pozdrav za sve, i mislim da realno posle jedne 8800 samo 4870 (i sve navise ;)) moze doci u bozir
OK to, ali evo u ovoj usporedbi, 3GHz E2180 vs. 3GHz E8200, zar nije dovoljna razlika 6x vise cache-a?
Niti na 3.6GHz ili 4GHz nece biti neke velike razlike u odnosu na E2180 @3GHz, jer proc nije kocnica.
strucnjaci... ajde misljenje.... imam dve opcije, prva da zamenim ovu moju grafu iz potpisa sa gigabajtovom 4850, i jos bolje, da zamenim i plocu sa jednom gigabajt x38 GA-EX38-DS4 i dve 4850 u crossfireu....... koliko ta druga u realnosti moze biti bolja od prve opcije?
poz i thx
poz i thx
Ako igras samo na monitoru 19'(1440x900) ne menjaj nista!!!
E sad,ako igras iskljucivo na LCD TV i on lepo skalira vece rezolucije onda druga opcija.
nekad igram na monitoru, a nekad na tv-u.... kad igram na tv, onda shibam u 1080p rezama(1920x1080) i sve izgfleda nenormalno dobro, mada i ova konfiguracija na tim rezama sve sem krize shiba sasvim solidno..... ali kad vec imam priliku da zamenim sve ovo po super ceni...... :)
Sapphire, Gigabyte i PowerColor ? To su koliko vidim za sada jedina 3 modela kod nas ?
Od ove tri najbolji je sapphire (oc, temp)? Mada sva tri modela se preterano zagrevaju... Da li da uzimam sada Sapphire ili ipak sacekati malo da se pojavi jos koji model sa iole boljim hladjenjem ?
Da li je neko probao PowerColor 4580 ?
Koliko sam dosada vidio, Sapphire ima bakreni cooler, dok Gigabyte i PC imaju aluminijski koji je ofarban u boju bakra, isto kao i na 3850. :d Taj sam zakljucak stvorio nakon nekoliko primjeraka, ne mogu tvrdit da je generalno tako.
MSI i Asus takodjer imaju bakreni.
hmmmm.... a koliko su dve 4850 u cross-u jace od jedne 4870 single?
Chinaski izvoli :d
GA-P31-S3
WIN XP SP3
itd :)
Wtf? Jel ovo greska ili nije?
Citam na gomilu mesta kako se singleslot 4850 karte greju i preko 100 stepeni a pre neki dan videh da im kuler radi na malom broju obrtaja. Posle sam video da kuler radi na oko 50% brzine (mozda 60 nisam siguran) i da moze da se ubrza. Koliko se kartica manje greje kada se kuler ubrza i da li bi bio problem da kuler radi na 80%? I koliko bi se onda klokovala bez menjanja biosa?
Meni licno buka ne smeta mnogo a ako ipak zasmeta stavicu slusalice pri igranju.
Može li još neko da potvrdi ovo?
Iskreno, dok sam skidao cooler sa grafike stekao sam utisak da je dosta lagan...
sto mu onda dodje da bolje ne menjam ni plocu, vec samo ovu grafu sa jednom 4870......?
Menjanje 8800GT zbog jedne igre sada nema mnogo smisla.
Za par meseci kad se slegnu cene i izadju karte sa boljim hlađenjem 4870 ili 4850 biće prava stvar, a sigurno sledi i nvidia odgovor.
Kada radi na 80% buka je nepodnosljiva,cuje se kao fen za kosu.(na 3850) a 4850 ima isti kuler.
