Hi
Ima li neki alat da prodje kroz disk/folder i resetuje ili po zelji namesti permissions i security. Recimo uzme ownership, shareuje network i everyone full control i ukine nepotrebne zabrane.
Imam par racunara po kuci i kako nesto shareujem ili "ne daj boze" iskopiram sa jednog na drugi tako mi fajlovi postaju nedostupni sa drugog racunara.
Zelim da par foldera na svakom racunaru budu "no worries".
C:\>xcacls
XCACLS filename [/T] [/E|/X] [/C] [/G user
😛erm;spec] [/R user [...]]
[/P user
😛erm;spec [...]] [/D user [...]] [/Y]
Description:
Displays or modifies access control lists (ACLs) of files.
Parameter List:
filename Displays ACLs.
/T Changes ACLs of specified files in
the current directory and all subdirectories.
/E Edits ACL instead of replacing it.
/X Same as /E except it only affects the ACEs that
the specified users already own.
/C Continues on access denied errors.
/G user
😛erm;spec Grants specified user access rights.
Perm can be:
R Read
C Change (write)
F Full control
P Change Permissions (Special access)
O Take Ownership (Special access)
X EXecute (Special access)
E REad (Special access)
W Write (Special access)
D Delete (Special access)
Spec can be the same as perm and will only be
applied to a directory. In this case, Perm
will be used for file inheritance in this
directory. By default, Spec=Perm.
Special values for Spec only:
T Valid for only for directories.
At least one access right has to
follow. Entries between ';' and T
will be ignored.
/R user Revokes specified user's access rights.
/P user
😛erm;spec Replaces specified user's access rights.
Access right specification as same as
/G option.
/D user Denies specified user access.
/Y Replaces user's rights without verify.
NOTE:
Wildcards can be used to specify more than one file.
More than one user can be specified.
Access rights can be combined.
Examples:
XCACLS /?
XCACLS TEMP.DOC /G ADMINISTRATOR:RC
XCACLS *.TXT /G ADMINISTRATOR:RC /Y
XCACLS *.* /R ADMINISTRATOR /Y
XCACLS TEST.DLL /D ADMINISTRATOR /Y
XCACLS TEST.DLL /P ADMINISTRATOR:F /Y
XCACLS *.* /G ADMINISTRATOR:F;TRW /Y
XCACLS *.* /G ADMINISTRATOR:F;TXE /C /Y
