Pa za neke programe moraš da odabereš da rade u tzv. Compatibility modu...
Desni klik na fajl, pa odaberi Properties / Compatibility i tamo čekiraj opciju "Run this program in compatibility mode:"
Odaberi: "Windows XP SP2" ili neku drugu verziju...
... i Windows DefenderIskljuci UAC i 99% ce raditi sasvim normalno.
Pokreneš HELP i ukucaš UAC i dobiješ odgovor (kao i za sve ostalo što te muči)...Ljudi, kako se iskljucuje taj j****i UAC na Visti ?
Turn User Account Control on or off
User Account Control (UAC) can help you prevent unauthorized changes to your computer. It works by prompting you for permission when a task requires administrative rights, such as installing software or changing settings that affect other users.
We don't recommend turning User Account Control off. If you do turn it off, you should turn it back on as soon as possible.
Click to open User Accounts.
Click Turn User Account Control on or off. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Select the Use User Account Control (UAC) to help protect your computer check box to turn on UAC, or clear the check box to turn off UAC, and then click OK.
