Ako ti set as defoult u trecem tebu nepomaze, onda stvarno nemam ideju :wave:
'vako
To get the profile to load with Windows XP, right-click the Start button » Open All Users, navigate into Programs » Startup folder. Put a shortcut to WinColor.exe here. Right-click the shortcut, click Properties, and add /L to the end of the Target field, so it looks something like this:
"C:\Program Files\Pro Imaging Powertoys\Microsoft Color Control Panel
Applet for Windows XP\WinColor.exe" /L
Don't copy and paste the above line into your Target field, since you may have installed the program to a different location. Just add a space, forward slash, and an L to the end so it looks like the above example. Also be sure you don't have any other gamma loaders in your Startup folder or otherwise set to start with Windows, such as Adobe Gamma or Powerstrip.
A jel nemoze klasican nacin...desni klik properties,settings,advanced,color managment, add,set as defoult?!
ali u Visti ne rade (po uputstvu za Vistu)...
moze da se shvati na vise nacinaali u Visti ne rade (po uputstvu za Vistu)...
Brate kakve to sisteme imas kad ti nigde nista neradi?!
