Crysis Benchmark CPU/GPU [HIGH]
GA 8800GT 512 turbo force@ 785/1980/950
[email protected] GHz
NEXT BENCH RUN- 2/24/2008 3:02:25 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 60.38s, Average FPS: 33.12
Min FPS: 16.47 at frame 154, Max FPS: 41.64 at frame 1001
Average Tri/Sec: -32202676, Tri/Frame: -972160
Recorded/Played Tris ratio: -0.94
!TimeDemo Run 1 Finished.
Play Time: 54.62s, Average FPS: 36.62
Min FPS: 16.47 at frame 154, Max FPS: 42.16 at frame 983
Average Tri/Sec: -35156644, Tri/Frame: -960075
Recorded/Played Tris ratio: -0.95
!TimeDemo Run 2 Finished.
Play Time: 54.63s, Average FPS: 36.61
NEXT BENCH RUN- 2/24/2008 3:09:15 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_cpu
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 47.63s, Average FPS: 31.49
Min FPS: 13.15 at frame 196, Max FPS: 46.50 at frame 124
Average Tri/Sec: 35091172, Tri/Frame: 1114281
Recorded/Played Tris ratio: 0.65
Play Time: 43.47s, Average FPS: 34.51
Average Tri/Sec: 38392336, Tri/Frame: 1112568
Play Time: 43.20s, Average FPS: 34.72
Average Tri/Sec: 38732232, Tri/Frame: 1115412
TimeDemo Play Ended, (3 Runs Performed)
GA 8800GT 512MB Turbo Force @785/1980/950
[email protected]
NEXT BENCH RUN- 2/24/2008 3:23:56 PM - XP
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 48.80s, Average FPS: 40.98
Min FPS: 18.82 at frame 154, Max FPS: 54.79 at frame 979
Average Tri/Sec: 40362000, Tri/Frame: 984801
Recorded/Played Tris ratio: 0.93
Play Time: 42.70s, Average FPS: 46.84
Min FPS: 18.82 at frame 154, Max FPS: 56.49 at frame 1013
Average Tri/Sec: 46640592, Tri/Frame: 995791
Recorded/Played Tris ratio: 0.92
Play Time: 42.59s, Average FPS: 46.96
Min FPS: 18.82 at frame 154, Max FPS: 57.55 at frame 999
Average Tri/Sec: 46824960, Tri/Frame: 997206
Vredi li sta ovaj rezultat!!!
XFX 8800GT 512 ddr 600/900/1500 je graficka!!
    195.7 KB · Pregleda: 74
    219.6 KB · Pregleda: 61
Vredi, ali mi i dalje nije jasno kako. izgleda da se ovaj test dosta razlikuje od ugradjenog bat fajla. ili imas neku zakrpu za igru ili bog zna sta. Uglavnom dolazis na slicno kao ja sa E4500 na 3.33Ghz i 8800GT na 700/1836/2000. Kako, nije mi jasno. Uglavnom nisu ovde vise "cista posla". mnogo su nam sareni rezultati. Nema nikakve logike. neki sa 8800GT na 750/2000 lagano dobijaju 47-48fps, kako i to je pitanje. Jedino ako quad core utice na rezultat. Svasta je moguce.
Da ali!!!
Garant OC i graficka u procesor. Meni je sve pod defaultu!!
Sigurno mu je q nasviran na 3.6 i kusur i graficka na 740/2050/1900 kao sto sam ja izvalcio sa Gainaward 8800GT PCX 600/900/1800 .
Svasta se ovde "mulja". Zato i volim 3Dmark
Evo sta meni prijavi taj tool.
    13.4 KB · Pregleda: 66
Da da!!
Bas svasta!! Ima dosta samo izbaci rezultat bez slike bez icega a ko zna koja su mu podesavanja dal je high dal je medium...
Isto ko lik na forumu postavio za 8800GTS u 3D mark 2001 99000 poena a u stvari kad pogledas bolje sliku lik postavio 1 od 8 testova pa ti vidi sad ali lik je neki vazan tip na forumu i njemu ne traze dlaku u jajetu. To care dobra OC dobar socre u 3D Mark....
STA DALJE RECI!!!!!!!!!!!
Zakrpa 1.1 donosi malo ubrzanje, 1.5-2 fps.
Ne donosi, barem ne u svim testnim uslovima. Testiranja koja sam ja obavio nisu donela apsolutno nikakvu razliku ako za rezoluciju uzmemo jedan frejm.
Kod mene ima razlike, bez ljutnje. Mozda je do verzije drajvera.
Ja sam izneo svoje zapažanje, i naravno da se ne ljutim zato što ti iznosiš svoje iskustvo ali se ljutim jer si tražio da se ne ljutim. :smoke:
Ni kod mene nema razlike sa novim driverima (do sad sam koristio 169.21). Nece preko 40fps-a, pa to ti je:D
Evo malo bolji skor, sad da li je zbog ovog novog clocka na shaderima ili je jednostavno komp bio u "boljoj formi" danas, min FPS je osetno bio bolji :trust:
Proc na 3GHz, grafa na 750/1700/2100 MHz
novi momenti
    442.7 KB · Pregleda: 80
evo
    121.2 KB · Pregleda: 83
    121.4 KB · Pregleda: 71
Nesto ne stima kod mene...Pimecujem da imam jedan od najslabihih rezultata za grafiku iz potpisa(Palit "sonic") i to solidno klokovanu, a kako ovaj test ne zavisi u tolikoj meri od CPU-a pocinjem malo da se brinem.Pogledajte rezultate pa kazite sta mislite?Da li ja malo umisljam ili ovde nesto stvarno nije u redu,osecam se kao Stevo Zigon u Majstorskoj radionici...:S:
Inace,instalirana je samo SP demo verzija igre(mozda je do toga nesto) ,drajveri 169.21,XPsp2.Pokretanjem bat fajla iz bin 32 dobijam skoro identicne rezultate.
3/1/2008 1:40:38 AM - XP
Play Time: 68.34s, Average FPS: 29.27
Min FPS: 13.63 at frame 151, Max FPS: 45.50 at frame 1658
Average Tri/Sec: 28820902, Tri/Frame: 984768
Play Time: 60.07s, Average FPS: 33.29
Min FPS: 13.63 at frame 151, Max FPS: 49.16 at frame 1745
Average Tri/Sec: 33151108, Tri/Frame: 995742
Play Time: 59.61s, Average FPS: 33.55
Average Tri/Sec: 33441698, Tri/Frame: 996713
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 33.42
3/1/2008 1:48:21 AM - XP
Play Time: 52.06s, Average FPS: 28.81
Min FPS: 14.61 at frame 196, Max FPS: 44.84 at frame 359
Average Tri/Sec: 28114310, Tri/Frame: 975813
Recorded/Played Tris ratio: 0.74
Play Time: 44.43s, Average FPS: 33.76
Min FPS: 14.61 at frame 196, Max FPS: 46.53 at frame 84
Average Tri/Sec: 33024802, Tri/Frame: 978268
Play Time: 45.62s, Average FPS: 32.88
Average Tri/Sec: 32126414, Tri/Frame: 977118
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 33.32
    328.4 KB · Pregleda: 51
    306.9 KB · Pregleda: 42
Brate, to bas ne valja, trebalo bi da imas +10 fps-ova vise, govorim za avg fps.
Testiraj neku drugu igru, vidi sta se desava.
I nabavi celu igru (Crysis) pa testiraj.
Jesi probao i 3dmark 06 pa da uporedis rezultat sa nekim ko ima slican procesor kao tvoj?
Hm,plasio sam se takvog odgovora...Sa slabim rezultatima u markovima sam se pomirio(hajde da kazemo da je CPU ogranicavajuci faktor) ali ovde sam se vec malo zamislio.U igrama primecujem znacajno ubrzanje u odnosu na 8600GT(pa bezmalo 100%) .Nista,videcu ovih dana da otvorim jednu temu gde cu malo detaljnije testirati karticu,mozda i izvucemo neki zakljucak,ovako je i suvise malo materijala...
Nije bitno kakvi su rezultati,jel rez bar kao kod ostalih koji imaju taj procesor?
U 3Dmark-u 06 sam najvise dobio oko 9300 poena sa procesorom na 2.8-2.9GHz.Otprilike to je to sa ovim athlonom G1 koliko sam ovih dana gledao po benchu(a veruj mi gledao sam dosta).Rezultat se minimalno smanjuje kada mark06 stavim na 16x10 i odvrnem AA i AF.
Sumnjam da je u tome problem ali,koliko brzina i latencije sist.memorije uticu na ovaj test.Evo kako moja memara sljaka ovih dana...:D
    42.2 KB · Pregleda: 60
Ne utice,kod mene je memorija na 640Mhz 5-5-5-15 (znaci uzas) tako je drzim posto ne utice uopste na igre (ili bilo sta sto je meni bitno) ja kako god da namestim memoriju imam rezultate slicne kao ti 1-2 frejma vise na klokovanom 3850.
Verovatno si vec video:
U ovoj temi sam nasao samo jedan test sa x2 4000+ na 2.8 i 8800gt-om,i ima 5-6 frejmova vise nego kod tebe:
clokovi 700/1750/2100mhz
Demo Loops=2, Time Of Day= 9
GPU
Play Time: 57.65s, Average FPS: 34.69
Min FPS: 17.32 at frame 138, Max FPS: 52.75 at frame 983
Average Tri/Sec: 34172524, Tri/Frame: 985069
Play Time: 49.12s, Average FPS: 40.72
Min FPS: 17.32 at frame 138, Max FPS: 54.47 at frame 993
Average Tri/Sec: 40519576, Tri/Frame: 995123
TimeDemo Play Ended, (2 Runs Performed)
CPU
Play Time: 44.57s, Average FPS: 33.65
Min FPS: 17.67 at frame 196, Max FPS: 51.51 at frame 124
Average Tri/Sec: 32895102, Tri/Frame: 977504
Play Time: 38.25s, Average FPS: 39.22
Average Tri/Sec: 38396492, Tri/Frame: 979114
Recorded/Played Tris ratio: 0.73
    38.9 KB · Pregleda: 45
