Pro Evolution Soccer 2008 - oficijelni thread
Izašao je Evolution patch, koji čini igranje svih ostalih verzija PES-a potpuno besmislenim :)
It's done!
The work on the E.V.O.L.U.T.I.O.N. Patch II is completed, and you'll eventually have the enjoyment to play the patch.
It has been a difficult and long job, and in spite of some setbacks, we always kept our goal in view and never strayed. As is generally known, a lot of roads lead to Rome, or to the E.V.O.L.U.T.I.O.N. Patch, respectively.
The patch comes with the following improvements:
* Completely new over-worked Optionfile with all transfers and new teams. About 90% of the stats revised
* 100% original Teams
* 100% original Names
* 100% original Kits
* complete Bundesliga (German League)
* correct League and Cup names
* correct Stadium names
* new Soundtrack
* new chants for many Teams
* Teams without own unique chants have adequate generic chants
* new Callnames
* new Balls
* up-to-date Bootpack
* new Faces for many Superstars
* new Menus
* misc. new graphics (countries, positions icons etc.)
* fan reactions (German Version only)
* fan banners
OF / Player Attributes
We did our best to give you a complete OF with accurate player attributes. However, we of course cannot guarantee flawlessness. Respecting player attributes, opinions sometimes even differ widely. This said, there are two possibilites for you to cope with "false" player attributes, 1. you can better them on your own, 2. you refrain from using the OF, or the patch itself, respectively.
Teams included in the patch
* Premier League
* Ligue 1
* Serie A
* Primera Division
* Bundesliga
* Others A / B:
Slavia Prag
Anderlecht
Club Brugge
Dinamo Zagreb
Copenhagen
Steaua Bukarest
Olympiacos
Panathinaikos
AEK Athens
Rosenborg
Wis³a Kraków
Benfica
Porto
Sporting Lisbon
Spartak Moscow
Zenit St. Petersburg
Celtic
Rangers
Red Star Belgrade
AIK Solna
CSKA Moskau
Shakhtor Donezk
Göteborg
Beºiktaº
Fenerbahçe
Galatasaray
Dynamo Kiev
Basel
River Plate
Sao Paulo
Boca Juniors
LA Galaxy
* Others C:
Eredivisie
For the great teamwork - a big thanks to the creators of the patch:
Bavaria_Zürich, Blue Stinger, DonCerveza, Fastdog, Fl@schb@ck, Fox, jedi_pereira, kyuss1, Lo$tY, PaulDiddy, Rechi, r!dl3r.de, Tommsen
Sincere thanks are given also to:
222, bstd, FCH, g@l@g@n, Hecke, Juce, LordMephisto, ninuzzu, Red_Phoenix, Roamer und "Friends", Robbie, TIFFOSI, $corp, sYn, allen Patchteams und Patchern, die uns dabei behilflich waren und PES 2008 verbessert haben.
Skinite ga sa http://www.pes-beat.com/board/showthread.php?tid=578
Napokon je izašao. Jos samo da se pojavi torent link pa da ga lagano posrchem.
Uf, kakva vest, odmah sam krenuo sa download-om, ali ići će teško, ako neko bude brži - nek iznese utiske.
Evo skida se, nadam se da cu do veceras sve lepo instalirati :)
Za sada, patch deluje super. Muzika je naravno neuporedivo bolja (čak se uredno prikazuju nazivi pesama), meniji su doterani, a posebno mi se sviđa kako izgleda ekran sa izborom reprezentacija. Naravno, naša zemlja ne izgleda ovako, sa ili bez Kosova...
Ipak, to je sitnica, naš nacionalni tim je urađen odlično, za razliku od Evolution patcha za PES6 prošle godine. Lica su takođe doterana, čak je i na Zvezdi koliko-toliko porađeno.
Što se tiče ocena, vidim samo da na našoj selekciji nije ništa posebno rađeno, mislim da je Vidić preskromno ocenjen.
Izgleda da su ubacili i nove stadione, odnosno zamenili ih za postojeće, na spisku su recimo Wembley (stari?) i Millenium u Cardiffu. Dok se ne napravi novi stadium server za kit server, ne može ih biti više od 15, nažalost :(
Što se tiče bagova, problem može da stvara CL scoreboard patch...autori tvrde da je moguće da on neće normalno da radi na rezolucijama preko 1680x1050 ali sam ja uspeo to da sredim ručnim importovanjem fajlova preko Game Graphics Studia. Primetio sam i neke sitnije probleme u options meniju, ali nije vredno pomena.
U svakom slučaju, apsolutno vredi skinuti ovo čudo, jer kao što rekoh, posle njegovog instaliranja, igranje bilo koje druge verzije je jednostavno besmisleno.
    214.8 KB · Pregleda: 64
    327.5 KB · Pregleda: 68
    141.6 KB · Pregleda: 69
    224.5 KB · Pregleda: 79
    227.1 KB · Pregleda: 96
Ima li gde drugde da se skine patch?
Ovaj...zašto? Na tom linku imaš gomilu linkova ka svim potrebnim fajlovima, postavljeni su na razne hosting servere, pa ih možeš brzo skinuti čak i ako nemaš nalog na nekom od njih.
zato sto sam jos jutros nalozio registraciju, a jos mi nema linka za aktivaciju.:S:
Da ne koristis gmail? Meni ga je bacio u spam pa nisam mogao da skinem iz thunderbirda, morao sam preko webmaila.
edit: vladabgd je bio brzi :)
Mali off - kako se uopšte formiraju te ocene ? :) Jel uzimaju od klubova stastiku ili... ?
Mislim na to kako Konami u startu odredi osobine igrača i timova (bez obzira što nisu licencirani), zato više volim neki ozbiljan neoficijelni patch jer tu ljubitelji fudbala i PES-a sami doteraju stvari na svoje mesto.
Bravo. aktivacija je zavrsila u spam-u.
Nego šta sve treba skinuti!!!
Spisak molim.:D
To i nije toliki problem. Imas edit, pa "nabudzis" kol'ko koga hoces. Meni vise smeta navijacko pravljenje patcha. Konkretno, par momaka je uradilo dosta dobar patch za Meridijan Super Ligu i Prvu Ligu, ali su negde bas preterali. Partizan je u rangu Valensije, Liona, Bajerna, a neki totalni raspadi od igraca, blago receno, precenjeni. Mada, nista sto jedan OF ne moze da resi. Btw, skinuo sam EVO Patch II, vredi svaki bajt!
Ovaj cs.img beše samo muzika ?
Da preskočim to, vuče mi se download ko prebijen ?
Šta Sve Treba Skinuti, Da Se Ne Skida Bez Veze Ono Što Ne Treba.
Tako je, cs.img je samo muzika, mada je i to odlicno odradjeno, ubaceno je navijanje za nneke klubove. Bez cs.img je 315mb, sto je prihvatljivije...
Pa koja je svrha igrati sa random nabudzenim igracima? Valjda je draz imati sto realniju igru...
Recimo, probaj onog Vidica odozgo pa reci koliko podseca na pravog ;)
Olos! Samo treba videti sliku Srbije iz patcha.
    7.4 KB · Pregleda: 392
Jel problem nekom da napise ili samo da prekopira linkove koji su potrebni za Engesku verziju patch-a.
I naravno da se napomene sta je neophodno a sta nije, kao sto je npr taj fajl sa novo muzikom.
Momcima sam skrenuo pažnju i to je već ispravljeno. Umesto teorija kako nas mrze, pre bih rekao da je reč o nemarnosti koja i nije toliko za čuđenje kada se zna da smo večito u nekakvoj izolaciji i sukobima.
Uglavnom, evo vam fix za taj problem
Insert with GGS in unnamed_8093.bin in cv_o
http://www.speedyshare.com/921692170.html
