Crysis Benchmark CPU/GPU [HIGH]
Ajd kad smo kod refresh-a...post #193..
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 36.44
C2Q E6600@3000Mhz
Gainward 8800GTS 512MB 750/2200/1875 GPU/MEM/SHADER
1280x1024
AVG = 50.8 fps
Refresh
GTS 320 by ja 39.70
GTS 320 by Zdravko 37.06
GTS 640 by Paradigma 37.10
GT by Jovyland 50.80
GT by Ppredrag 46
GT by Jera 44.75
GT by Miljko 43.38
GT by Panzer75 46.24
GT by Lanselot 40.72
GT by P$ycho 44.95
GTS 512 by Placebo 52.56
GTS 512 by Paradigma 50.80
GTX by BOX85 48.67
3850 by GoranM 30.44
3870 crossfire by Studiovpc 45.25 Vista OS
3870 by terzazak 36.40
2900pro 256 bit, 512DDR3 by Flight 32.27
2600XT by Dandy 13.41
7950GT by Jera 14.58
8600GTS 256MB by Homer nvfreak 13.31
Svi forumashi koji su ovde naveli rezultate, imaju dovoljno klokovane procesore (Intel C2D i C2Q, i X2), pa se moze reci da ne obuzdavaju graficke , tj. procesori nisu usko grlo grafickama, pa mozemo da malo rezimiramo (mada su naravno graficke svima drugacije klokovane, ali dobro):
AVG FPS:
1.) 8800GTS 512MB: 50,80 - 52,56
2.) 8800GT 512MB: 40,72 - 50,80
3.) 8800GTX 768MB: 48,67
4'.) 8800 GTS 640MB: 37,10
4''.) 8800 GTS 320MB: 37,06 - 39,70
5.) 3870 512MB: 36,40
6.) 3850 256MB: 30,44
Komentar ?
3870 iza starih GTS-ova ? Naravno treba napomenuti da je ovo ipak niza rezolucija i bez AA i AF, pa se stari GTS-ovi drze. Sigurno bi 3870 bio dosta bolji uz AA i/ili uz vecu rezoluciju, ili ne bi ?
ide 3870 bolje u visim rezolucijama od starog GTS-a (imao sam stari GTS i u 1680x1050 se davio jedva 3 fps-a) i to bas dobro tu je negde sa 8800 GT malo slabiji jer ipak igra je sponzorisana od nvidie
GTS 320 by ja 39.70
GT by Jovyland 45.29
GT by Ppredrag 46
GT by Jera 44.75
GT by Miljko 43.38
GT by P$ycho 44.95
GTX by BOX85 48.67
3870 by terzazak 36.44
Pa Naravno da je brza u velikim rezolucijama i sa aa/af ali ovo je tema 1280*1024 a tu je ko sto vidis GTS i dalje ispred 3870.
GTS 320 by ja 39.70
GT by Ppredrag 46
GT by Jera 44.75
GT by Miljko 43.38
GT by P$ycho 44.95
GTX by BOX85 48.67
moja 3870 je ispred moje GTS stare i to bas dobro skoro u rangu 8800 GT (imao sam i nju) pricam sad za single karticu iako imam CF testirao sam i single varijante
U cemu je ispred? Krizi? Koja rez, jel sa AA/AF? Koji OS? Daj malo vishe informacija:)
pa u krizi naravno i to za rez 1280x1024 sa AA 2x i za 1680x1050 gde je unistava samo tako, os naravno Vista x64 znate da ja to ne menjam, znaci po mom licnom iskustvu i testiranju ovako bih svrstao ove tri kartice po jacini u SINGLE varijanti za Crysis GTS 320 - 3870 - 8800 GT, jednostavno GT je pravljena za ovu igru i tu 3870 kao single karta ne moze da prismrdi, sem mozda kad se klokuje posto ima mnogo vecu OC marginu od GT-a, u CF je druga prica, za SLI ne znam iz prve ruke jer nisam probao
Hehe cifre ispred govore koja je brza u 1280*1024 bez AA/AF:)
ma te cifre uopste nisu merodavne jer se test uvek vrsi na budjavom prvom nivou, tu maltene sve kartice imaju visok broj FPS-a a kasnije krecu da stucaju, mozda u mom slucaju je drugacije a kod ostalih nije, zato sam i rekao da iz LICNOG testiranja izvodim zakljucak i rangiram kartice kako sam ih rangirao
Pa cifre jesu merodavne.
Ako u prvom nivou 3870 ima slabije performanse od GTS 320MB, zasto bi se ta situacija menjala u kasnijim niovima.
A i zavisi kakav si ti primerak GTS-a imao ;) ?
Mozda nije bio ovako overklokabilan kao whip-ov i moj primerak :type:.
moze se reci da sam imao onako dobar primerak isao je do 685-690 MHz sto i nije lose, ali ljudi bre kad ja golim okom primecujem da 3870 radi bolje nemojte da pokusavate da me ubedite u nesto sto mozda niste videli, a i ne ponasa se svaka kartica isto na svakom nivou, drugacije radi nvidia drugacije ati
Pa j.ebi ga onda, za sta sluzi uopste ovaj benchmark :smoke:.
Ajde da skapiram da ti je na nekom drugom niovu imao 4-5 frejmova vise, ali i to se ne moze golim okom oceniti (razlika izmesju 35 i 40), tako da mislim da si malcice preterao :d, valjda si previse zavoleo taj CF ;). Skini ti jednu pa lepo nama daj rezultate za ovaj benchmark :type:.
haha mozda i jesam zavoleo CF nije ovo losa stvar, ali bre govorim sve vreme o ponasanju SINGLE kartice 3870 u odnosu na GTS, pa i budala bi znala da 512 naspram 320 MB igra ovde kljucnu ulogu, u radu se oseca kako se GTS davi, daleko od toga da je to losa kartica ali za ovu igru ona jednostavno stuca. Dok recimo za 8800 GT mogu da kazem da je kartica skrojena po meri Crysis-a i da ona u SINGLE varijanti sije 3870 samo tako, cini mi se da sam vec stavljao testove ovde i za single i za CF
AVG FPS:
Komentar ?
Ima tu jos kombinacija...Treba pomenuti da je 3870 veoma klokabilna kartica,kao sto se zna, i da su ovi rezultati postignuti sa najvecim mogucim (dozvoljenim) klokom 860/1350 sa temperturom kartice od samo 45c (fan na 100%).Ja pretpostavljam da bi rezultat bio sigurno preko 40 fps kada bi se flesovao bios i preskocila ona blokada na 860 za gpu jer bi tada 3870 radila na otprilike 890/1400.Samim tim bi i fps skocio..i stari GTS-ovi ostaju iza..:D
Nije da nesto branim ATI , ali je 3870 stvarno OK kartica.Kriza sve na high i 4xAA i uopste ne stuca..:)
moj rezultat
rezultat u attachmentu, dakle oko 43.5fps sa ovim sporetom iz potpisa...
    68.7 KB · Pregleda: 61
Evo jos jedan GT. Clockovi iz moje masine.
2/19/2008 2:35:33 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 49.81s, Average FPS: 40.15
Min FPS: 22.65 at frame 150, Max FPS: 55.72 at frame 984
Average Tri/Sec: 38338856, Tri/Frame: 954883
Recorded/Played Tris ratio: 0.96
!TimeDemo Run 1 Finished.
Play Time: 43.14s, Average FPS: 46.36
Average Tri/Sec: 44783864, Tri/Frame: 966039
Recorded/Played Tris ratio: 0.95
!TimeDemo Run 2 Finished.
Play Time: 42.80s, Average FPS: 46.73
Average Tri/Sec: 45072476, Tri/Frame: 964549
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 46.545
sto mi potcenjujete CF, jel sam ja rekao da ce sa novijim driverima da bude bolje? E pa ne znam sta su im uradili ali Crysis mi je podivljao, zaci Vista x64 sa SP1, patchovan Crysis, Catalyst 8.2 i average FPS 66.415, konfiguracija je iz potpisa sa istim setovanjima nista nije dizano niti spustano
    104.3 KB · Pregleda: 73
8800GT(700MHz\2000MHz) i [email protected]
2/19/2008 2:48:05 PM - XP
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 63.81s, Average FPS: 31.34
Min FPS: 17.58 at frame 144, Max FPS: 42.31 at frame 972
Average Tri/Sec: -31615548, Tri/Frame: -1008690
Recorded/Played Tris ratio: -0.91
Play Time: 55.98s, Average FPS: 35.73
Min FPS: 17.58 at frame 144, Max FPS: 42.43 at frame 981
Average Tri/Sec: -35606220, Tri/Frame: -996623
Recorded/Played Tris ratio: -0.92
Play Time: 55.56s, Average FPS: 36.00
Min FPS: 17.58 at frame 144, Max FPS: 42.53 at frame 980
Average Tri/Sec: -35923048, Tri/Frame: -997953
Completed All Tests
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 35.865
Ooooo svaka chast, to je vec za respect:Klanjanje *** gotovo 2x brze od jedne.
Update
GTS 320 by ja 39.70
GT by Ppredrag 46
GT by Jera 44.75
GT by Nenad22 46.54
GT by Miljko 43.38
GT by Chinaski 43.5
GT by Bane87 48,97
GT by P$ycho 44.95
GTX by BOX85 48.67
3870 crossfire by Studiovpc 66.41 Vista OS
nego znas sta mi cudno i pre mi se tako desilo da mi podivlja isto, znaci stojim recimo na onom nivou kad se prvi put vidi alien kad ga onaj general povezuje na struju, i po onim hodnicima ladno imam preko 100 fps-a izadjem napolje padne na 50 pa onda kako koji dolazi pada sve vise do nekih 35 i onda posle ide polako gore-dole gore-dole, nikad nemam uopste konstantni FPS, u proseku igrivo je uvek i jos ga ja sve igram na 1680x1050
vjerovatno zbog loshih drivera?
moguce moguce, nego ove 8.2 sam odradio na clean install tako da eto vidi se napredak, ocisceni stari driveri sa driver cleanerom pa onda posle instalirani novi. Vise i ne igram Crysis presao sam ga tri puta, vise me smorio, stoji mi na masini sad samo za testiranje novih drivera, u ostalim igricama sve mi uvek radi u fullu nema da stucne
ma jok, takav je engine sigurno. meni je i FEAR varirao od 20-200fps na staroj grafickoj...
evo moj skor konfa iz potpisa, 1680x1050, ATi 3870 CrossFire, Catalyst 8.2 igra se preporodila pici kao ludo, average FPS 57.725
    104.2 KB · Pregleda: 111
Auuuuu sta je bre ovo:smoke: extra!
Koliko si imao sa drajverima pre ovih?
na 1280x1024 benchu sam dobio skoro pa duplo ali podizali se fps-ovi sa svakom novijom verzijom drivera, na 1680x1050 razlike ima isto i varira od nivoa do nivoa, znaci na ovom pocetnom na kome se inace i radi benchmark imam najveci fps a kasnije zavisi kako gde mada nikad ne pada ispod 30 ono kad se nakupi dosta neprijatelja odjednom, u proseku igram je uvek na nekih 40-45 fps-a, to je neki prosek povadjen iz cele igre kako ja izvaljujem jer ovaj test uopste nije merodavan za celu igru samo za prvi nivo
Ne mogu da se setim dal sam stavio moj rezultat ranije,pa evo ga sad.
@Bane87:Nisi mogao da izdrzis sa 8600 vise,jel da? ;) Pre neki dan sam video kako Crysis radi na oc-ovanom 8600Gt-u: skoro sve na low i secka,znaci koliko je teoretski 8800GT brzi toliko je i vizuelno. Nego,jel mozes da odradis test iz benchmark_GPU.bat fajla?
    89.8 KB · Pregleda: 61
Imao sam pogodnost da uzmem sad jacu karticu... Sve je na 8600gt sljakalo ko podmazano, sem crysisa... ;) nista ti ne brini :D
Zasto da odradim preko gpu.bat fajla ?
Update
GTS 320 by ja 39.70
GT by Ppredrag 46
GT by Jera 44.75
GT by Nenad22 46.54
GT by Miljko 43.38
GT by Chinaski 43.5
GT by Bane87 48,97
GT by P$ycho 44.95
GTX by BOX85 48.67
A sad imas 45,43 :d.
