Jel moze neko da provali?
activated1
Imam neki dokument u ekeslu (vrlo prost), ali ne mogu da provalim po kojoj formuli dobija reshenja. Pa ako neko ima ideju kako da mi pomogne oko ovoga nek baci pogled na attach.
  • 8.rar
    2.2 KB · Pregleda: 78
Na žalost, sheet je zaštićen šifrom.Da nema šifre i sam bi video formulu.
(x2+x1)*(x2-x1)
@DariusIII
onaj prog ne funkcionishe :D ali u svakom sluchaju hvala za trud.
@amd_mad
hvala za reshenje. kak si ga provalio? :d
:wave:
Nema potrebe za bilo kakvim programima...
za svaki pass (sem onih koji onemogucavaju pokretanje dokumenta) funkcionise sledeci postupak
Tools>Macro>Visual Basic Editor (ili precica Alt+F11)
Insert>Module
ovde insertovati sledeci code
Kod:
    Public Sub AllInternalPasswords()
        ' Breaks worksheet and workbook structure passwords. Bob McCormick
        '  probably originator of base code algorithm modified for coverage
        '  of workbook structure / windows passwords and for multiple passwords
        ' Norman Harker and JE McGimpsey 27-Dec-2002 (Version 1.1)
        ' Modified 2003-Apr-04 by JEM: All msgs to constants, and
        '   eliminate one Exit Sub (Version 1.1.1)
        ' Reveals hashed passwords NOT original passwords
        Const DBLSPACE As String = vbNewLine & vbNewLine
        Const AUTHORS As String = DBLSPACE & vbNewLine & _
                "Adapted from Bob McCormick base code by" & _
                "Norman Harker and JE McGimpsey"
        Const HEADER As String = "AllInternalPasswords User Message"
        Const VERSION As String = DBLSPACE & "Version 1.1.1 2003-Apr-04"
        Const REPBACK As String = DBLSPACE & "Please report failure " & _
                "to the microsoft.public.excel.programming newsgroup."
        Const ALLCLEAR As String = DBLSPACE & "The workbook should " & _
                "now be free of all password protection, so make sure you:" & _
                DBLSPACE & "SAVE IT NOW!" & DBLSPACE & "and also" & _
                DBLSPACE & "BACKUP!, BACKUP!!, BACKUP!!!" & _
                DBLSPACE & "Also, remember that the password was " & _
                "put there for a reason. Don't stuff up crucial formulas " & _
                "or data." & DBLSPACE & "Access and use of some data " & _
                "may be an offense. If in doubt, don't."
        Const MSGNOPWORDS1 As String = "There were no passwords on " & _
                "sheets, or workbook structure or windows." & AUTHORS & VERSION
        Const MSGNOPWORDS2 As String = "There was no protection to " & _
                "workbook structure or windows." & DBLSPACE & _
                "Proceeding to unprotect sheets." & AUTHORS & VERSION
        Const MSGTAKETIME As String = "After pressing OK button this " & _
                "will take some time." & DBLSPACE & "Amount of time " & _
                "depends on how many different passwords, the " & _
                "passwords, and your computer's specification." & DBLSPACE & _
                "Just be patient! Make me a coffee!" & AUTHORS & VERSION
        Const MSGPWORDFOUND1 As String = "You had a Worksheet " & _
                "Structure or Windows Password set." & DBLSPACE & _
                "The password found was: " & DBLSPACE & "$$" & DBLSPACE & _
                "Note it down for potential future use in other workbooks by " & _
                "the same person who set this password." & DBLSPACE & _
                "Now to check and clear other passwords." & AUTHORS & VERSION
        Const MSGPWORDFOUND2 As String = "You had a Worksheet " & _
                "password set." & DBLSPACE & "The password found was: " & _
                DBLSPACE & "$$" & DBLSPACE & "Note it down for potential " & _
                "future use in other workbooks by same person who " & _
                "set this password." & DBLSPACE & "Now to check and clear " & _
                "other passwords." & AUTHORS & VERSION
        Const MSGONLYONE As String = "Only structure / windows " & _
                 "protected with the password that was just found." & _
                 ALLCLEAR & AUTHORS & VERSION & REPBACK
        Dim w1 As Worksheet, w2 As Worksheet
        Dim i As Integer, j As Integer, k As Integer, l As Integer
        Dim m As Integer, n As Integer, i1 As Integer, i2 As Integer
        Dim i3 As Integer, i4 As Integer, i5 As Integer, i6 As Integer
        Dim PWord1 As String
        Dim ShTag As Boolean, WinTag As Boolean
        Application.ScreenUpdating = False
        With ActiveWorkbook
            WinTag = .ProtectStructure Or .ProtectWindows
        End With
        ShTag = False
        For Each w1 In Worksheets
                ShTag = ShTag Or w1.ProtectContents
        Next w1
        If Not ShTag And Not WinTag Then
            MsgBox MSGNOPWORDS1, vbInformation, HEADER
            Exit Sub
        End If
        MsgBox MSGTAKETIME, vbInformation, HEADER
        If Not WinTag Then
            MsgBox MSGNOPWORDS2, vbInformation, HEADER
        Else
          On Error Resume Next
          Do      'dummy do loop
            For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
            For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
            For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
            For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
            With ActiveWorkbook
              .Unprotect Chr(i) & Chr(j) & Chr(k) & _
                 Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
                 Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
              If .ProtectStructure = False And _
              .ProtectWindows = False Then
                  PWord1 = Chr(i) & Chr(j) & Chr(k) & Chr(l) & _
                    Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
                  MsgBox Application.Substitute(MSGPWORDFOUND1, _
                        "$$", PWord1), vbInformation, HEADER
                  Exit Do  'Bypass all for...nexts
              End If
            End With
            Next: Next: Next: Next: Next: Next
          Loop Until True
          On Error GoTo 0
        End If
        If WinTag And Not ShTag Then
          MsgBox MSGONLYONE, vbInformation, HEADER
          Exit Sub
        End If
          'Attempt clearance with PWord1
          w1.Unprotect PWord1
        Next w1
        On Error GoTo 0
        ShTag = False
          'Checks for all clear ShTag triggered to 1 if not.
        Next w1
        If ShTag Then
              With w1
                If .ProtectContents Then
                  Do      'Dummy do loop
                      Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
                    If Not .ProtectContents Then
                      MsgBox Application.Substitute(MSGPWORDFOUND2, _
                      'leverage finding Pword by trying on other sheets
                      For Each w2 In Worksheets
                        w2.Unprotect PWord1
                      Next w2
                    End If
                  Loop Until True
                  On Error GoTo 0
                End If
              End With
            Next w1
        End If
        MsgBox ALLCLEAR & AUTHORS & VERSION & REPBACK, vbInformation, HEADER
    End Sub
Zatvoriti Visual Basic Editor i pokrenuti novokreirani Makro "AllInternaPasswords". Ovo ce ukloniti sve sifre i zastite iz dokumenta
BTW...amd_mad je bio u pravu
veruj mi iz mate sam imao 2, ali zasluženu :) u tom trenutku sam imao neki push up i win calc, samo od sebe se rešilo :D
Pa i nije nešto teško... kvadrat binoma. Onaj ko ima iskustva, čim vidi odredjenu kombinaciju brojeva, zna šta je u pitanju. :)
Pa i nije kvadrat binoma, nego razlika kvadrata.
Razlika kvadrata je a^2-b^2 = (a+b)*(a-b)
Dok je kvadrat binoma (a+b)^2=(a^2+2ab+b^2)
Nego, nebitno, bitno da je covek resio problem... aj slucajno primetio tvoj komentar tako da sorry za nepotrebni spam al' reko da kazem da ne zivite u zabludi do kraja zivota :p
Ma nema frke ;). Setio sam se kasnije, ali mi je net bio pukao, a ovo pišem sa moba. :wall:
