Kako narezati 6.5GB na 2 DVD-a
kambodza
Nabavio sam igru koja je teska 6.5GB
Mene interesuje kako da je narezem na 2 DVD-a
Jel mogu da pustim da se snima,pa kad zavrsi sa prvim DVD-om,trazice mi drugi sam i nastaviti sa snimanjem
    5 KB · Pregleda: 124
Label of DVD1: COD4_MW_DVD_1
Files on DVD1 :
0x0409.ini
CoD4MW.msi (Replace this file CoD4MW.msi by This one CoD4MW.msi
FirewallInstallHelper.dll
ISSetup.dll
PB.cab
Setup.ini
WindowsInstaller-KB893803-x86.exe
autorun.inf
instmsia.exe
instmsiw.exe
pbsvc.exe
setup.exe
version.inf
DirectX\*.*
Docs\*.*
Extras\*.*
Setup\Data\cod4.ico
Setup\Data\Mods\ModWarfare\*.*
Setup\Data\main\iw_00.iwd
Setup\Data\main\iw_01.iwd
Setup\Data\main\iw_02.iwd
Setup\Data\main\iw_03.iwd
Setup\Data\main\iw_04.iwd
Setup\Data\main\iw_05.iwd
Setup\Data\main\iw_06.iwd
Setup\Data\main\iw_07.iwd
Setup\Data\main\iw_08.iwd
Setup\Data\main\iw_09.iwd
Setup\Data\main\iw_10.iwd
Setup\Data\main\iw_11.iwd
Setup\Data\main\localized_english_iw00.iwd
Setup\Data\main\localized_english_iw01.iwd
Setup\Data\zone\english\village_defend.ff
Setup\rsrc\*.*
Label of DVD2: COD4_MW_DVD_2
autorun.inf
Setup\Data\binkw32.dll
Setup\Data\cod4.ico
Setup\Data\iw3mp.exe
Setup\Data\iw3sp.exe
Setup\Data\localization.txt
Setup\Data\mss32.dll
Setup\Data\main\localized_english_iw02.iwd
Setup\Data\main\localized_english_iw03.iwd
Setup\Data\main\localized_english_iw04.iwd
Setup\Data\main\localized_english_iw05.iwd
Setup\Data\main\localized_english_iw06.iwd
Setup\Data\main\video\*.*
Setup\Data\miles\*.*
Setup\Data\zone\english\*.* (except this file village_defend.ff)
Edit Autorun.ini with notepad and put it like this way next :
[autorun]
open=0
icon=Setup\data\CoD4.ico
Instalation Sequence : DVD1-DVD2-DVD1
DVDS structures :
COD4_MW_DVD_1 = 2.33 GB (2.513.072.729 bytes) 142 files, 16 folders
COD4_MW_DVD_2 = 3.95 GB (4.248.969.216 bytes) 134 files, 7 folders
google je cudo ?????
Drug ja ovo nista ne kapiram,moze li pojasnjenje. A isto ovo ce mi trebati za Crysis i Gears of war
Odradio sam ovo za COD
Sad bi da narezem Gears Of War ali ovo ne kapiram,jel moze neko pojasnjenje ali na nasem jeziku.
Ja to reshavam tako shto taj file shto je veci od 4.5 GB rar-ujem pa podelim na jednaka dela i u radim Self Extrasing Archive..... I stavim najmanju kompresiju nek ide brze...
Ili jednostavno uzmesh dual layer koji koshta 120 din :)
pa to zna svako
ali tako zauzima mnogo vise mesta i vremena ...
a stalja je burzuj on sve na dl reze
He, he, ako hoćete da snimite COD4 ( ili MOH Airborne, ili još nekoliko desetina igara ) na 2 DVD-ja, jednostavno iskopirajte već instaliranu igricu.
Znači, iz direktorijuma gde je igrica instalirana izaberete fajlove do veličine 4 GB ( ili nešto više ) i narežete na prvi DVD a ostatak na drugi
Provereno tako rade navedene igrice a i FEAR, Quake4, Far Cry, Doom 3, itd.
To je ubedljivo najgori način. Osim ako nemaš iskustva u ripovanju igara i pratiš i disk i registry tokom instalacije.
Pratite www.cd-2-dvd.com, tamo ima sve.
90 dindzi kosta dual layer (trenutno najjeftiniji koji sam nasao, RICOHJPN D01), ne razumem grbu koju izbacujete sa ovom pricom ... Ustedecete neku ozbiljnu kintu?
A i mnogo je lepse instalirati sa DL diska, odes da klopas, k.njas, vadis krmelj iz oka, nesto radis, i on u medjuvremenu zavrsi, a ovako bi te cekao sa porukom Please Insert DVD2 :D
ovo je najgluplje moguce resenje
pa to zna svako
Taj file od 6.5 GB je zapakovalo za oko 1 sat i neznam kako rar-ovani file moze da zauzima vishe mesta od onog nerarovanog... ( u najgorem sluchaju bice isti ) tako da tvoja priha nestoji.....
:wave:
Nemoj koristiti "normal" ili "best" kompresiju već samo "store".
:wave:
da si razmislio svatio bi da ne zauzimaju rarovani fajlovi vise nego da je potrebno vise mesta da bi se instalirali
nerarovani fajlovi 6 gb stane na 2 dvda instaliram 7Gb i radi 6+7=13
rarovani zauzimaju 5.5(primera radi) kad se otpakuju zauzimaju 6 pa jos da se instalira 7 .... 5.5+6+7>>13
ne mozes ti da rarujes instaliranu igricu .Mislim mozes ali ....
Nisam dobro skontao..... Ali meni ni onih 6+7=13 Gb neprave problem....
:wave:
pa kad rarujes moaras to da otpakujes na hdd pa tek onda da instaliras
ovako sam instaliras sa cda- manje vremena i prostora potrebno
